Bus Pirate 5 auto build: main branch
Here’s a fresh compile from ‘main’: “Added long-press button functionality with button codes. Added bulong command. Replaced button_check_irq with button_check_press. Moved button_exec to button.c”
ci-buspirate5-main-cac1152.zip
Build time: 39.58 seconds
Git pull log @cac1152:
Updating add9c1b…cac1152
commands/global/button_scr.c | 104 +++++++++++++++++++++++++++++++±----------
commands/global/button_scr.h | 3 ±
pirate.c | 9 +±-
pirate.h | 3 ++
pirate/button.c | 46 +++++++++++++±----
pirate/button.h | 11 +++±
6 files changed, 135 insertions(+), 41 deletions(-)
Here’s a fresh compile from ‘main’: “added help to button command”
ci-buspirate5-main-6a2842f.zip
Build time: 39.38 seconds
Git pull log @6a2842f:
Updating cac1152…6a2842f
commands/global/button_scr.c | 17 ++++++++++±-----
translation/base.h | 6 ++++++
translation/bs-ba.h | 6 ++++++
translation/en-us.h | 8 ++++++±
translation/en-us.json | 8 ++++++±
translation/it-it.h | 6 ++++++
translation/pl-pl.h | 6 ++++++
translation/zh-cn.h | 6 ++++++
8 files changed, 55 insertions(+), 8 deletions(-)
Here’s a fresh compile from ‘main’: “Volatile because modified in IRQ handler”
ci-buspirate5-main-2ca1250.zip
Build time: 45.94 seconds
Git pull log @2ca1250:
Updating 6a2842f…2ca1250
CMakeLists.txt | 1 +
bytecode.h | 19 ++++++++±----
commands/global/cmd_selftest.c | 7 ++±-
display/default.c | 9 ++±—
mode/logicanalyzer.c | 7 ++±-
msc_disk.c | 8 ++++±
pirate.c | 37 ++++++++++++++±-----------
pirate/button.c | 7 +±–
pirate/intercore_helpers.c | 57 +++++++++++++++++++++++++++++++++++++++++
pirate/intercore_helpers.h | 58 ++++++++++++++++++++++++++++++++++++++++++
pirate/mcu.c | 1 +
ui/ui_process.c | 18 +++++±------
12 files changed, 178 insertions(+), 51 deletions(-)
create mode 100644 pirate/intercore_helpers.c
create mode 100644 pirate/intercore_helpers.h
Here’s a fresh compile from ‘main’: "Enable 2Gbit rev10 board firmware
  • Add new target in CMakefiles.txt
  • Change NAND terms to use ERASE_BLOCK instead of simply BLOCK
  • Use #define to select between two flash chips for firmware
  • Pass row_address_t to additional nand functions to support multi-plane
  • Fix for cross-plane copy (less efficient, but required until command found that copies from one plane’s cache register to the other plane’s cache register…)"
    ci-buspirate5-main-51a9bbc.zip
Build time: 57.43 seconds
Git pull log @51a9bbc:
Updating 2ca1250…51a9bbc
CMakeLists.txt | 29 ++++++++++±—
nand/attic/shell_cmd.c | 4 ±-
nand/nand_ftl_diskio.c | 4 ±-
nand/spi_nand.c | 97 ++++++++++++++++++++++++++++++++++++±------------
nand/spi_nand.h | 39 +++++++++++±-------
5 files changed, 124 insertions(+), 49 deletions(-)
Here’s a fresh compile from ‘main’: “Remove dead (per Ian) code”
ci-buspirate5-main-420aa88.zip
Build time: 38.57 seconds
Git pull log @420aa88:
Updating 51a9bbc…420aa88
CMakeLists.txt | 11 –
nand/attic/fifo.h | 75 -------
nand/attic/led.c | 25 —
nand/attic/led.h | 35 ----
nand/attic/mem.c | 35 ----
nand/attic/mem.h | 33 ----
nand/attic/shell.c | 192 ------------------
nand/attic/shell.h | 41 ----
nand/attic/shell_cmd.c | 518 -------------------------------------------------
nand/attic/shell_cmd.h | 18 –
nand/attic/uart.c | 144 --------------
nand/attic/uart.h | 35 ----
nand/nand_ftl_diskio.c | 12 ±
nand/spi_nand.c | 168 +++++++++±-----
nand/spi_nand.h | 39 +±-
pirate/mem.c | 2 ±
pirate/mem.h | 2 ±
pirate/storage.c | 2 +
18 files changed, 131 insertions(+), 1256 deletions(-)
delete mode 100644 nand/attic/fifo.h
delete mode 100644 nand/attic/led.c
delete mode 100644 nand/attic/led.h
delete mode 100644 nand/attic/mem.c
delete mode 100644 nand/attic/mem.h
delete mode 100644 nand/attic/shell.c
delete mode 100644 nand/attic/shell.h
delete mode 100644 nand/attic/shell_cmd.c
delete mode 100644 nand/attic/shell_cmd.h
delete mode 100644 nand/attic/uart.c
delete mode 100644 nand/attic/uart.h
Build Failed! Logs are attached. Happy debugging!
ci-buspirate5-main-97ec6f0.zip
Build time: 47.31 seconds
Git pull log @97ec6f0:
Updating 420aa88…97ec6f0
commands/global/dummy.c | 4 ++++
1 file changed, 4 insertions(+)
ci-buspirate5-main-6d383ad.zip
Build time: 16.63 seconds
Git pull log @6d383ad:
Updating 97ec6f0…6d383ad
mode/hw2wire.c | 6 ±
mode/hwhduart.c | 10 ±
mode/hwi2c.c | 6 ±
mode/hwled.c | 6 ±
mode/hwspi.c | 12 ±
mode/hwuart.c | 10 ±
pirate/rgb.c | 640 +++++++++++++++++++++++++++++++++++±------------
pirate/rgb.h | 23 ±
pirate/storage.c | 79 ++±–
pirate/storage.h | 15 ±
system_config.c | 73 ±----
system_config.h | 11 ±
translation/base.h | 2 +
translation/en-us.h | 2 +
translation/en-us.json | 2 +
ui/ui_config.c | 194 ++++++++++±—
16 files changed, 749 insertions(+), 342 deletions(-)
Looks like the build server is having a problem. Looking into it.
Here’s a fresh compile from ‘main’: "No code changes … yet
  • Improve the name of first parameter to rgb_assign_color() to reflect it’s a bitmask of which LEDs to assign the color to.
  • Formatting changes to more easily compare similar code."
Build time: 39.84 seconds
Already up to date.
Here’s a fresh compile from ‘main’: “only need six hex digits printed”
ci-buspirate5-main-fc0b9c9.zip
Build time: 39.97 seconds
Git pull log @fc0b9c9:
Updating 6d383ad…fc0b9c9
pirate/storage.c | 2 ±
Here’s a fresh compile from ‘main’: “uart monitor”
ci-buspirate5-main-fc8f968.zip
Build time: 39.6 seconds
Git pull log @fc8f968:
Updating fc0b9c9…fc8f968
CMakeLists.txt | 3 +
commands.c | 4 +
commands/global/cls.c | 26 ++++++
commands/global/cls.h | 1 +
commands/global/pwm.c | 2 ±
commands/global/smps.c | 90 +++++++++++++++++++
commands/global/smps.h | 1 +
commands/uart/monitor.c | 228 ++++++++++++++++++++++++++++++++++++++++++++++++
commands/uart/monitor.h | 1 +
mode/hwuart.c | 3 +
10 files changed, 358 insertions(+), 1 deletion(-)
create mode 100644 commands/global/cls.c
create mode 100644 commands/global/cls.h
create mode 100644 commands/global/smps.c
create mode 100644 commands/global/smps.h
create mode 100644 commands/uart/monitor.c
create mode 100644 commands/uart/monitor.h
