Bus Pirate 5 auto build: main branch
Here’s a fresh compile: “enable PWM/FREQ in IO0/1 for REV10 only.”
ci-buspirate5-main-66ab520.zip
Build time: 43.52 seconds
Git pull log @66ab520:
Updating 0a5dc67…66ab520
commands/global/freq.c | 2 ++
commands/global/pwm.c | 2 ++
2 files changed, 4 insertions(+)
Here’s a fresh compile: “test push”
ci-buspirate5-main-02ad064.zip
Build time: 46.71 seconds
Git pull log @02ad064:
Updating 66ab520…02ad064
commands/global/pwm.c | 2 ±
Here’s a fresh compile: “Link to last forum post with most recent firmware”
ci-buspirate5-main-9dee6d6.zip
Build time: 43.72 seconds
Git pull log @9dee6d6:
Updating 02ad064…9dee6d6
commands/global/cmd_mcu.c | 2 ±
Here’s a fresh compile: “Fix shift speed error. Fix bug where PSU over current interrupt happens after PSU is disable.”
ci-buspirate5-main-2eeed3b.zip
Build time: 44.54 seconds
Git pull log @2eeed3b:
Updating 9dee6d6…2eeed3b
commands/global/w_psu.c | 2 ±
pirate.c | 5 ++±-
pirate.h | 3 +++
pirate/psu.c | 3 +±
pirate/psu.h | 2 ++
pirate/shift.c | 6 +++±-
6 files changed, 15 insertions(+), 6 deletions(-)
Here’s a fresh compile: “fix sle4442 set new passcode”
ci-buspirate5-main-fd8455f.zip
Build time: 40.75 seconds
Git pull log @fd8455f:
Updating 2eeed3b…fd8455f
commands/2wire/sle4442.c | 108 +++++++++++++++++++++++++++++++++++++++++±----
1 file changed, 97 insertions(+), 11 deletions(-)
Here’s a fresh compile: “flash command add override and force dump with 0x03 command.”
ci-buspirate5-main-dabc999.zip
Build time: 42.07 seconds
Git pull log @dabc999:
Updating fd8455f…dabc999
commands/spi/flash.c | 27 +++++++++++++++++±-----
commands/spi/spiflash.c | 55 +++++++++++++++++++++++++++++++++++++++++++++++++
commands/spi/spiflash.h | 1 +
pirate/hwspi.c | 4 +±-
pirate/hwspi.h | 2 ±
5 files changed, 80 insertions(+), 9 deletions(-)
Here’s a fresh compile: “fix SPI read not return value”
ci-buspirate5-main-8b2a76b.zip
Build time: 41.71 seconds
Git pull log @8b2a76b:
Updating dabc999…8b2a76b
pirate/hwspi.c | 2 ±
Here’s a fresh compile: “SPI mode read with write”
ci-buspirate5-main-6b15f34.zip
Build time: 42.32 seconds
Git pull log @6b15f34:
Updating 8b2a76b…6b15f34
bytecode.h | 3 ±-
mode/hwspi.c | 11 ++++++++±-
mode/hwspi.h | 1 +
modes.c | 4 +±-
syntax.c | 5 +++++
5 files changed, 18 insertions(+), 6 deletions(-)
Here’s a fresh compile: “mode commands in global help”
ci-buspirate5-main-db1c6f7.zip
Build time: 40.89 seconds
Git pull log @db1c6f7:
Updating 6b15f34…db1c6f7
commands/global/h_help.c | 14 ++++++++++++++
mode/hiz.c | 10 ++++±----
mode/hiz.h | 3 +++
modes.c | 4 +±-
ui/ui_help.c | 14 +++++++++++±-
ui/ui_help.h | 3 +±
6 files changed, 38 insertions(+), 10 deletions(-)
Here’s a fresh compile: “fix uart mode command help text”
ci-buspirate5-main-131bf80.zip
Build time: 40.98 seconds
Git pull log @131bf80:
Updating db1c6f7…131bf80
mode/hwuart.c | 4 +±-
Here’s a fresh compile: “bug in SLE4442 command”
ci-buspirate5-main-8cf5f01.zip
Build time: 40.71 seconds
Git pull log @8cf5f01:
Updating 131bf80…8cf5f01
commands/2wire/sle4442.c | 1 +
Here’s a fresh compile: “Fix storage hex command dump format typo”
ci-buspirate5-main-20cdd1f.zip
Build time: 41.64 seconds
Git pull log @20cdd1f:
Updating 8cf5f01…20cdd1f
commands/global/disk.c | 65 ++++++++++++++++++++++++++++++++++++++±----------
1 file changed, 51 insertions(+), 14 deletions(-)
Here’s a fresh compile: “fix I2C ack/nak detection”
ci-buspirate5-main-7899052.zip
Build time: 41.26 seconds
Git pull log @7899052:
Updating 20cdd1f…7899052
mode/hwi2c.c | 13 +++++++++++±
1 file changed, 12 insertions(+), 1 deletion(-)
Here’s a fresh compile: “readme”
ci-buspirate5-main-d9201d8.zip
Build time: 40.84 seconds
Git pull log @d9201d8:
Updating 7899052…d9201d8
img/bp5rev10-cover-angle.jpg | Bin 0 → 118726 bytes
img/teraterm-done.png | Bin 0 → 43641 bytes
readme.md | 32 ++++++++++++++++++++++++++++++++
3 files changed, 32 insertions(+)
create mode 100644 img/bp5rev10-cover-angle.jpg
create mode 100644 img/teraterm-done.png
create mode 100644 readme.md
ci-buspirate5-main-0e72e1f.zip
Build time: 45.14 seconds
Git pull log @0e72e1f:
Updating d9201d8…0e72e1f
readme.md | 5 +++±
1 file changed, 4 insertions(+), 1 deletion(-)
ci-buspirate5-main-5e45d6c.zip
Build time: 44.74 seconds
Git pull log @5e45d6c:
Updating 0e72e1f…5e45d6c
readme.md | 2 ±
Here’s a fresh compile: “Added hex command help arguments and strings”
ci-buspirate5-main-4802ab6.zip
Build time: 41.67 seconds
Git pull log @4802ab6:
Updating 5e45d6c…4802ab6
commands/global/disk.c | 9 ±
translation/base.h | 779 ++++++++++++++++++++++++±-----------------------
translation/bs-ba.h | 771 +++++++++++++++++++++++±-----------------------
translation/en-us.h | 5 ±
translation/en-us.json | 759 ++++++++++++++++++++++±-----------------------
translation/pl-pl.h | 771 +++++++++++++++++++++++±-----------------------
translation/zh-cn.h | 771 +++++++++++++++++++++++±-----------------------
7 files changed, 1943 insertions(+), 1922 deletions(-)
Here’s a fresh compile: “add macro command. Move macro things into macro command. non-working.”
ci-buspirate5-main-91fb52d.zip
Build time: 40.54 seconds
Git pull log @91fb52d:
Updating 4802ab6…91fb52d
CMakeLists.txt | 1 +
commands.c | 2 +
commands/global/macro.c | 208 ++++++++++++++++++++++++++++++++++++++++++++++++
commands/global/macro.h | 1 +
hacks/macro.mcr | 18 +++++
ui/ui_parse.c | 26 ++++++
ui/ui_parse.h | 2 +
ui/ui_process.h | 3 ±
8 files changed, 260 insertions(+), 1 deletion(-)
create mode 100644 commands/global/macro.c
create mode 100644 commands/global/macro.h
create mode 100644 hacks/macro.mcr
Here’s a fresh compile: “remove flash help from macro command”
ci-buspirate5-main-17d508e.zip
Build time: 39.98 seconds
Git pull log @17d508e:
Updating 91fb52d…17d508e
commands/global/macro.c | 4 +±-
Here’s a fresh compile: “Added Italian translation”
ci-buspirate5-main-b782332.zip
Build time: 41.02 seconds
Git pull log @b782332:
Updating 17d508e…b782332
translation/base.c | 8 ±
translation/base.h | 1 +
translation/bs-ba.h | 1 +
translation/en-us.h | 1 +
translation/en-us.json | 1 +
translation/it-it.h | 388 +++++++++++++++++++++++++++++++++++++++++++++++++
translation/it-it.json | 382 ++++++++++++++++++++++++++++++++++++++++++++++++
translation/pl-pl.h | 1 +
translation/zh-cn.h | 1 +
ui/ui_config.c | 8 ±
10 files changed, 788 insertions(+), 4 deletions(-)
create mode 100644 translation/it-it.h
create mode 100644 translation/it-it.json
