Bus Pirate 6 is shipping now (update)
if its done on the secondary interface it should also use the “usual” way for baudrate choosing then on the port attach
There is access to the second uart via the flatbuffers interface using the python library. That’s not straight forward though.
The easiest thing I guess is to add a new binary mode for UART pass-through, and respect the speed/config as set by the opened port. This would lock the main terminal though, so there’s not a huge advantage over the current bridge command.
