Here’s a fresh compile from ‘main’: “SPI Flash command: error if erase and read/verify”
ci-buspirate-main-93a5a09.zip
Build time: 145.29 seconds
Git pull log @93a5a09
Updating 9fa22b1..93a5a09
src/commands/spi/flash.c | 7 +++++++
1 file changed, 7 insertions(+)
Here’s a fresh compile from ‘main’: “Flash command confirm destructive actions”
ci-buspirate-main-f5528c7.zip
Build time: 146.9 seconds
Git pull log @f5528c7
Updating 93a5a09..f5528c7
src/commands/spi/flash.c | 19 ++
src/translation/base.h | 2 +
src/translation/bs-ba.h | 2 +
src/translation/en-us.h | 2 +
src/translation/it-it.h | 2 +
src/translation/pl-pl.h | 644 +++++++++++++++++++++++±----------------------
src/translation/zh-cn.h | 4 +
7 files changed, 355 insertions(+), 320 deletions(-)
Here’s a fresh compile from ‘main’: “EEPROM command: Confirm destructive action”
ci-buspirate-main-7c1f7a4.zip
Build time: 153.33 seconds
Git pull log @7c1f7a4
Updating f5528c7..7c1f7a4
src/commands/eeprom/eeprom_1wire.c | 6 ++++++
src/commands/eeprom/eeprom_base.c | 20 ++++++++++++++++++++
src/commands/eeprom/eeprom_base.h | 8 ++++++±
src/commands/eeprom/eeprom_i2c.c | 6 ++++++
src/commands/eeprom/eeprom_spi.c | 6 ++++++
5 files changed, 45 insertions(+), 1 deletion(-)
Here’s a fresh compile from ‘main’: "linenoise half way implemented.
(cherry picked from commit 12021cd5bf2d6a739a90af266199230d61d17cf1)"
ci-buspirate-main-a112128.zip
Build time: 155.64 seconds
Git pull log @a112128
Updating 7c1f7a4..a112128
.claude/settings.local.json | 8 +
CLAUDE.md | 84 +
arg_has_arg_migration_analysis.md | 557 ++
check_translations.py | 301 +
check_translations_README.md | 140 +
docs/args_parse_migration.md | 215 +
docs/binary_mode_guide.md | 244 +
docs/bio_pin_guide.md | 212 +
docs/board_abstraction_guide.md | 175 +
docs/bp_cmd_data_types.md | 324 +
docs/bp_cmd_developer_docs_outline.md | 322 +
docs/bp_cmd_linenoise.md | 178 +
docs/bp_cmd_migration_prompt.md | 482 ++
docs/bp_cmd_parsing_api.md | 203 +
docs/bp_cmd_patterns.md | 211 +
docs/bp_cmd_prompting.md | 162 +
docs/build_system_guide.md | 162 +
docs/command_setup_migration_prompt.md | 667 ++
docs/dead-code-analysis.md | 317 +
docs/dead_code_analysis_prompt.md | 227 +
docs/developer_docs_outline.md | 269 +
docs/developer_docs_prompt.md | 252 +
docs/display_mode_guide.md | 131 +
docs/dual_core_guide.md | 160 +
docs/error_handling_reference.md | 148 +
docs/mode_setup_migration_prompt.md | 407 +
docs/new_command_guide.md | 680 ++
docs/new_mode_guide.md | 706 ++
docs/storage_guide.md | 176 +
docs/syntax_bytecode_guide.md | 249 +
docs/system_config_reference.md | 214 +
docs/system_monitor_guide.md | 147 +
docs/testing_guide.md | 191 +
docs/translation_guide.md | 211 +
docs/usb_communication_guide.md | 160 +
src/CMakeLists.txt | 39 ±
src/binmode/legacy4third.c | 39 ±
src/bytecode.h | 10 ±
src/command_struct.h | 28 ±
src/commands.c | 112 ±
src/commands/1wire/demos.c | 15 ±
src/commands/1wire/demos.h | 4 ±
src/commands/1wire/scan.c | 15 ±
src/commands/1wire/scan.h | 4 ±
src/commands/2wire/hw2w_sniff.c | 21 ±
src/commands/2wire/hw2w_sniff.h | 4 ±
src/commands/2wire/sle4442.c | 133 ±
src/commands/2wire/sle4442.h | 2 +
src/commands/eeprom/eeprom_1wire.c | 122 ±
src/commands/eeprom/eeprom_1wire.h | 2 +
src/commands/eeprom/eeprom_base.c | 26 ±
src/commands/eeprom/eeprom_base.h | 12 ±
src/commands/eeprom/eeprom_i2c.c | 149 ±
src/commands/eeprom/eeprom_i2c.h | 2 +
src/commands/eeprom/eeprom_spi.c | 104 ±
src/commands/eeprom/eeprom_spi.h | 1 +
src/commands/global/a_auxio.c | 42 ±
src/commands/global/a_auxio.h | 4 +
src/commands/global/bug.c | 32 ±
src/commands/global/bug.h | 2 +
src/commands/global/button_scr.c | 67 ±
src/commands/global/button_scr.h | 2 +
src/commands/global/cls.c | 13 ±
src/commands/global/cls.h | 1 +
src/commands/global/cmd_binmode.c | 71 ±
src/commands/global/cmd_binmode.h | 1 +
src/commands/global/cmd_convert.c | 88 ±
src/commands/global/cmd_convert.h | 3 +
src/commands/global/cmd_mcu.c | 37 +
src/commands/global/cmd_mcu.h | 5 ±
src/commands/global/cmd_selftest.c | 35 ±
src/commands/global/cmd_selftest.h | 1 +
src/commands/global/disk.c | 396 ±
src/commands/global/disk.h | 10 ±
src/commands/global/dummy.c | 453 ±
src/commands/global/dummy.h | 2 +
src/commands/global/dump.c | 30 ±
src/commands/global/dump.h | 1 +
src/commands/global/flat.c | 159 -
src/commands/global/flat.h | 11 -
src/commands/global/freq.c | 144 ±
src/commands/global/freq.h | 3 +
src/commands/global/h_help.c | 195 ±
src/commands/global/h_help.h | 2 +
src/commands/global/hex.c | 41 ±
src/commands/global/hex.h | 3 ±
src/commands/global/i_info.c | 22 ±
src/commands/global/i_info.h | 4 ±
src/commands/global/image.c | 39 ±
src/commands/global/image.h | 3 ±
src/commands/global/jep106_lookup.c | 32 ±
src/commands/global/jep106_lookup.h | 2 ±
src/commands/global/l_bitorder.c | 37 +
src/commands/global/l_bitorder.h | 5 ±
src/commands/global/logic.c | 219 ±
src/commands/global/logic.h | 3 ±
src/commands/global/macro.c | 53 ±
src/commands/global/macro.h | 3 ±
src/commands/global/otpdump.c | 75 ±
src/commands/global/otpdump.h | 3 ±
src/commands/global/ovrclk.c | 32 ±
src/commands/global/ovrclk.h | 2 +
src/commands/global/p_pullups.c | 59 ±
src/commands/global/p_pullups.h | 5 ±
src/commands/global/pause.c | 29 ±
src/commands/global/pause.h | 3 ±
src/commands/global/pwm.c | 164 ±
src/commands/global/pwm.h | 3 +
src/commands/global/script.c | 68 ±
src/commands/global/script.h | 3 ±
src/commands/global/smps.c | 62 ±
src/commands/global/smps.h | 3 ±
src/commands/global/v_adc.c | 41 ±
src/commands/global/v_adc.h | 3 +
src/commands/global/w_psu.c | 108 ±
src/commands/global/w_psu.h | 3 +
src/commands/hdplxuart/bridge.c | 27 ±
src/commands/hdplxuart/bridge.h | 3 ±
src/commands/i2c/ddr4.c | 148 ±
src/commands/i2c/ddr4.h | 3 ±
src/commands/i2c/ddr5.c | 105 ±
src/commands/i2c/ddr5.h | 3 ±
src/commands/i2c/demos.c | 104 ±
src/commands/i2c/demos.h | 9 ±
src/commands/i2c/i2c.c | 76 ±
src/commands/i2c/i2c.h | 3 ±
src/commands/i2c/mpu6050.c | 22 ±
src/commands/i2c/mpu6050.h | 3 ±
src/commands/i2c/scan.c | 23 ±
src/commands/i2c/scan.h | 3 ±
src/commands/i2c/sniff.c | 31 ±
src/commands/i2c/sniff.h | 3 ±
src/commands/i2c/usbpd.c | 68 ±
src/commands/i2c/usbpd.h | 3 ±
src/commands/i2c/usbpdo.c | 29 ±
src/commands/i2c/usbpdo.h | 1 +
src/commands/i2s/sine.c | 230 ±
src/commands/i2s/sine.h | 3 ±
src/commands/i2s/wav.c | 125 +
src/commands/i2s/wav.h | 2 +
src/commands/infrared/irtxrx.c | 61 ±
src/commands/infrared/irtxrx.h | 5 ±
src/commands/infrared/tvbgone.c | 14 ±
src/commands/infrared/tvbgone.h | 4 ±
src/commands/jtag/bluetag.c | 82 ±
src/commands/jtag/bluetag.h | 4 ±
src/commands/spi/flash.c | 113 ±
src/commands/spi/flash.h | 4 ±
src/commands/spi/sniff.c | 14 ±
src/commands/spi/sniff.h | 4 ±
src/commands/spi/spiflash.c | 6 ±
src/commands/spi/spiflash.h | 4 ±
src/commands/uart/bridge.c | 24 ±
src/commands/uart/bridge.h | 4 ±
src/commands/uart/glitch.c | 296 ±
src/commands/uart/glitch.h | 2 +
src/commands/uart/monitor.c | 20 ±
src/commands/uart/monitor.h | 4 ±
src/commands/uart/nmea.c | 14 ±
src/commands/uart/nmea.h | 4 ±
src/commands/uart/simcard.c | 11 ±
src/commands/uart/simcard.h | 4 ±
src/debug_uart.c | 4 -
src/deprecated/queue.c | 171 -
src/deprecated/queue.h | 183 -
src/display/background_image_v4-orig.h | 8094 --------------------
src/display/robot16.h | 8093 -------------------
src/fatfs/ffsystem.c | 2 ±
src/lib/bp_args/bp_cmd.c | 1622 ++++
src/lib/bp_args/bp_cmd.h | 556 ++
src/lib/bp_args/bp_cmd_linenoise.c | 138 +
src/lib/bp_args/bp_cmd_linenoise.h | 23 +
src/lib/bp_expr/bp_expr.c | 319 +
src/lib/bp_expr/bp_expr.h | 68 +
src/lib/bp_expr/bp_expr_test | Bin 0 → 56152 bytes
src/lib/bp_expr/bp_expr_test.c | 292 +
src/lib/bp_expr/bp_expr_test.mk | 21 +
src/lib/bp_linenoise/linenoise.c | 2151 ++++++
src/lib/bp_linenoise/linenoise.h | 200 +
src/lib/bp_linenoise/ln_cmdreader.c | 61 +
src/lib/bp_linenoise/ln_cmdreader.h | 91 +
src/lib/bp_number/bp_number.c | 207 +
src/lib/bp_number/bp_number.h | 150 +
src/lib/sigrok/pico_sdk_sigrok.c | 1387 ----
src/mode/SW2W.c | 237 -
src/mode/SW2W.h | 53 -
src/mode/SW3W.c | 436 –
src/mode/SW3W.h | 34 -
src/mode/SWI2C.c | 212 -
src/mode/SWI2C.h | 23 -
src/mode/binloopback.c | 1 -
src/mode/dummy1.c | 402 ±
src/mode/dummy1.h | 25 ±
src/mode/hw1wire.c | 15 ±
src/mode/hw2wire.c | 94 ±
src/mode/hw2wire.h | 1 +
src/mode/hw3wire.c | 150 ±
src/mode/hw3wire.h | 1 +
src/mode/hwhduart.c | 191 ±
src/mode/hwhduart.h | 3 ±
src/mode/hwi2c.c | 185 ±
src/mode/hwi2c.h | 1 +
src/mode/hwled.c | 97 ±
src/mode/hwled.h | 3 ±
src/mode/hwspi.c | 226 ±
src/mode/hwspi.h | 1 +
src/mode/hwuart.c | 299 ±
src/mode/hwuart.h | 1 +
src/mode/i2s.c | 122 ±
src/mode/i2s.h | 5 ±
src/mode/infrared.c | 196 ±
src/mode/infrared.h | 1 +
src/mode/jtag.c | 7 ±
src/mode/sw1wire.c | 705 –
src/mode/sw1wire.h | 41 -
src/mode/usbpd.c | 3 ±
src/modes.c | 14 ±
src/modes.h | 1 +
src/nand/nand_ftl_diskio.c | 3 +
src/pirate.c | 142 ±
src/pirate/bio.c | 20 -
src/pirate/bio.h | 6 -
src/pirate/file.c | 29 ±
src/pirate/file.h | 25 ±
src/pirate/hw1wire_pio.c | 1345 +±-
src/pirate/hwi2c_pio.c | 1 +
src/pirate/hwuart_pio.c | 2 +
src/pirate/psu.c | 4 ±
src/syntax.c | 771 –
src/syntax.h | 7 +
src/syntax_compile.c | 240 +
src/syntax_internal.h | 96 +
src/syntax_post.c | 314 +
src/syntax_run.c | 230 +
src/toolbars/logic_bar.c | 135 -
src/translation/base.h | 33 +
src/translation/bs-ba.h | 33 +
src/translation/en-us.h | 37 ±
src/translation/history/en-us (2).json | 3378 ++++++++
src/translation/history/en-us.json | 14 ±
src/translation/it-it.h | 33 +
src/translation/pl-pl.h | 33 +
…/proposed_positional_descriptions.txt | 27 +
src/translation/zh-cn.h | 33 +
src/ui/ui_cmdln.c | 460 ±
src/ui/ui_cmdln.h | 186 ±
src/ui/ui_config.c | 19 ±
src/ui/ui_config.h | 3 ±
src/ui/ui_display.c | 162 ±
src/ui/ui_display.h | 4 ±
src/ui/ui_format.c | 298 ±
src/ui/ui_format.h | 9 ±
src/ui/ui_help.c | 133 ±
src/ui/ui_help.h | 43 ±
src/ui/ui_hex.c | 15 ±
src/ui/ui_hex.h | 22 ±
src/ui/ui_init.c | 2 -
src/ui/ui_mode.c | 407 ±
src/ui/ui_mode.h | 6 ±
src/ui/ui_parse.c | 306 ±
src/ui/ui_process.c | 26 ±
src/ui/ui_prompt.c | 237 ±
src/ui/ui_prompt.h | 28 ±
src/ui/ui_term.c | 314 -
src/ui/ui_term.h | 18 ±
src/ui/ui_term_linenoise.c | 280 +
src/ui/ui_term_linenoise.h | 98 +
tests/test_spsc_queue | Bin 21512 → 0 bytes
tools/helpcollect.py | 251 +
tools/helpref-snip.txt | 138 +
translation_report.txt | 203 +
271 files changed, 26149 insertions(+), 26932 deletions(-)
create mode 100644 .claude/settings.local.json
create mode 100644 CLAUDE.md
create mode 100644 arg_has_arg_migration_analysis.md
create mode 100644 check_translations.py
create mode 100644 check_translations_README.md
create mode 100644 docs/args_parse_migration.md
create mode 100644 docs/binary_mode_guide.md
create mode 100644 docs/bio_pin_guide.md
create mode 100644 docs/board_abstraction_guide.md
create mode 100644 docs/bp_cmd_data_types.md
create mode 100644 docs/bp_cmd_developer_docs_outline.md
create mode 100644 docs/bp_cmd_linenoise.md
create mode 100644 docs/bp_cmd_migration_prompt.md
create mode 100644 docs/bp_cmd_parsing_api.md
create mode 100644 docs/bp_cmd_patterns.md
create mode 100644 docs/bp_cmd_prompting.md
create mode 100644 docs/build_system_guide.md
create mode 100644 docs/command_setup_migration_prompt.md
create mode 100644 docs/dead-code-analysis.md
create mode 100644 docs/dead_code_analysis_prompt.md
create mode 100644 docs/developer_docs_outline.md
create mode 100644 docs/developer_docs_prompt.md
create mode 100644 docs/display_mode_guide.md
create mode 100644 docs/dual_core_guide.md
create mode 100644 docs/error_handling_reference.md
create mode 100644 docs/mode_setup_migration_prompt.md
create mode 100644 docs/new_command_guide.md
create mode 100644 docs/new_mode_guide.md
create mode 100644 docs/storage_guide.md
create mode 100644 docs/syntax_bytecode_guide.md
create mode 100644 docs/system_config_reference.md
create mode 100644 docs/system_monitor_guide.md
create mode 100644 docs/testing_guide.md
create mode 100644 docs/translation_guide.md
create mode 100644 docs/usb_communication_guide.md
delete mode 100644 src/commands/global/flat.c
delete mode 100644 src/commands/global/flat.h
create mode 100644 src/commands/i2s/wav.c
create mode 100644 src/commands/i2s/wav.h
delete mode 100644 src/deprecated/queue.c
delete mode 100644 src/deprecated/queue.h
delete mode 100644 src/display/background_image_v4-orig.h
delete mode 100644 src/display/robot16.h
create mode 100644 src/lib/bp_args/bp_cmd.c
create mode 100644 src/lib/bp_args/bp_cmd.h
create mode 100644 src/lib/bp_args/bp_cmd_linenoise.c
create mode 100644 src/lib/bp_args/bp_cmd_linenoise.h
create mode 100644 src/lib/bp_expr/bp_expr.c
create mode 100644 src/lib/bp_expr/bp_expr.h
create mode 100644 src/lib/bp_expr/bp_expr_test
create mode 100644 src/lib/bp_expr/bp_expr_test.c
create mode 100644 src/lib/bp_expr/bp_expr_test.mk
create mode 100644 src/lib/bp_linenoise/linenoise.c
create mode 100644 src/lib/bp_linenoise/linenoise.h
create mode 100644 src/lib/bp_linenoise/ln_cmdreader.c
create mode 100644 src/lib/bp_linenoise/ln_cmdreader.h
create mode 100644 src/lib/bp_number/bp_number.c
create mode 100644 src/lib/bp_number/bp_number.h
delete mode 100644 src/lib/sigrok/pico_sdk_sigrok.c
delete mode 100644 src/mode/SW2W.c
delete mode 100644 src/mode/SW2W.h
delete mode 100644 src/mode/SW3W.c
delete mode 100644 src/mode/SW3W.h
delete mode 100644 src/mode/SWI2C.c
delete mode 100644 src/mode/SWI2C.h
delete mode 100644 src/mode/sw1wire.c
delete mode 100644 src/mode/sw1wire.h
delete mode 100644 src/syntax.c
create mode 100644 src/syntax_compile.c
create mode 100644 src/syntax_internal.h
create mode 100644 src/syntax_post.c
create mode 100644 src/syntax_run.c
create mode 100644 src/translation/history/en-us (2).json
create mode 100644 src/translation/proposed_positional_descriptions.txt
create mode 100644 src/ui/ui_term_linenoise.c
create mode 100644 src/ui/ui_term_linenoise.h
delete mode 100644 tests/test_spsc_queue
create mode 100644 tools/helpcollect.py
create mode 100644 tools/helpref-snip.txt
create mode 100644 translation_report.txt
Here’s a fresh compile from ‘main’: "hduart: add listen mode for passive bus monitoring
Add a “Bus mode” option to half-duplex UART with two choices:
  • Master (default): BP drives the line idle-high, same as before
  • Listen: BP releases the pin (open drain), allowing passive monitoring
    of traffic on the bus (e.g. SRXL2 from a receiver)
In listen mode, the TX PIO state machine releases the data pin direction
so RX can read incoming data without TX holding the pin as output. When
writing in listen mode, the pin is temporarily claimed for TX then
released back to input.
Usage: m hduart -b 115200 -l listen"
ci-buspirate-main-7eeadf8.zip
Build time: 151.44 seconds
Git pull log @7eeadf8
Updating a112128..7eeadf8
src/mode/hwhduart.c | 41 ++++++++++++++++++++±------
src/pirate/hwuart_pio.c | 72 ++++++++++++++++++++++++++++++++++++++±---------
src/pirate/hwuart_pio.h | 3 +±
src/translation/base.h | 3 +++
src/translation/bs-ba.h | 3 +++
src/translation/en-us.h | 3 +++
src/translation/it-it.h | 3 +++
src/translation/pl-pl.h | 3 +++
src/translation/zh-cn.h | 3 +++
10 files changed, 111 insertions(+), 24 deletions(-)
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-93aefde.zip :arrow_down: :arrow_down: :arrow_down:
Build time: 176.74 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-f324867.zip :arrow_down: :arrow_down: :arrow_down:
Build time: 176.68 seconds
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-e01a360.zip :arrow_down: :arrow_down: :arrow_down:
  • e01a360: Allow button to execute scripts when a host is not attached. Flush TX queue when host not attached.
Build time: 176.81 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-d821f13.zip :arrow_down: :arrow_down: :arrow_down:
  • d821f13: fix vt100 size detect (>500 now allowed) and ascii failure path
Build time: 176.9 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-b6ffbba.zip :arrow_down: :arrow_down: :arrow_down:
  • b6ffbba: 2wire sniff respect LSB setting
Build time: 157.3 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-1e7aa66.zip :arrow_down: :arrow_down: :arrow_down:
  • 4481610: Legacy binary mode: fix flashrom and avrdude support
  • d25e61c: Merge branch ‘main’ into legacy-binmode-flashrom
  • 1e7aa66: Merge pull request #307 from DangerousPrototypes/legacy-binmode-flashrom
Build time: 159.62 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-1cda2c3.zip :arrow_down: :arrow_down: :arrow_down:
  • 1cda2c3: additional fix to tvbgone codes.
Build time: 160.38 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-0f66f47.zip :arrow_down: :arrow_down: :arrow_down:
  • a9e2a50: add ps2 & usb modes
  • 0f66f47: Merge pull request #306 from DangerousPrototypes/ps2_usb_sniffer
Build time: 158.76 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-6710c6d.zip :arrow_down: :arrow_down: :arrow_down:
  • 6710c6d: SPI honor LSB/MSB setting
Build time: 167.15 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-f8ccc1c.zip :arrow_down: :arrow_down: :arrow_down:
  • b9bb245: irtoy-air: initialize mod_freq
  • f8ccc1c: Merge pull request #310 from JohnAZoidberg/ir-fix
Build time: 158.47 seconds | compare
