COBS should definitely not cause that amount of slowdown. There is likely something else at play.
There is a way to avoid the secondary buffer for COBS encoding.
In-place encoding concept
This presumes the buffer is large enough for the encoding overhead, max of which can be pre-calculated for any given message size. The following is pseudo-code … not actually tested.
uint8_t * buffer = ...;
// move the buffer foward for maximum overhead bytes
size_t overhead = calc_cobs_overhead(message_length);
// don't use memcpy ... pointers are restricted there
memmove((uint8_t*)buffer, ((uint8_t*)buffer)+overhead, message_length);
// walk each byte ... cpu-specific optimizations possible here
// such as reading / writing in native word size
uint8_t * next_zero = buffer; // may point up to 254 bytes back...
uint8_t * next_output = buffer + 1;
uint8_t * to_encode = buffer + overhead;
uint8_t bytes_until_next_zero = 1;
size_t bytes_encoded = 0;
while (bytes_encoded < message_length) {
if (*to_encode == 0) {
*next_zero = bytes_until_next_zero;
next_zero = next_output;
++next_output;
++to_encode;
++bytes_encoded;
} else if (bytes_until_next_zero == 254) {
// overhead ... was a long stream without zero data
*next_zero = 0xFFu;
++next_output;
// does not increase bytes_encoded nor to_encode
} else {
*next_output = *to_encode;
++next_output;
++to_encode;
++bytes_encoded;
++bytes_until_next_zero;
*next_zero = 0xFFu; // overhead ... not actually zero
next_zero = next_data;
bytes_until
</details>
I'll try to scan the API / docs of that library to see what they require for in-place encoding. Most likely, it's just having the buffer large enough when it's first allocated, but maybe it also requires a memmove() before calling the encoding API.
I've got a full schedule today, but if you have a supported version of JLink, Segger has some profiling tools that may be helpful to understand where the time is coming from.
[quote="robjwells, post:19, topic:1298"]
If you’re using 0x00 as the end-of-packet byte, I wonder if it would help to change it to something else?
[/quote]
Unfortunately, because COBS was originally defined to use zero byte as the sentinel, it seems few libraries expose the ability to use a different sentinel byte. Thus, changing it would make it more difficult for clients (unfortunately). Besides, more zeros makes it encode more space efficiently....
