Parallel NAND flashing support
No worries. Thanks for coming back so quickly! Interesting to hear where you got to with it. Quality of the clips is something I’m also cautious of. The only other thread I’ve found on using the 360 clips as general NAND readers was here, where someone ten years ago seemed to have some success using a Raspberry Pi and the 360 clip: https://forums.raspberrypi.com/viewtopic.php?t=16775#p326224
Codebase:
Im actually still waiting on delivery for the kit, but once it arrives I’ll try and pick up your mantle. Will update the thread on how I get on.
Got it working with the raspberry pi :slight_smile:
Wrote a blog up on it here which includes links to ‘nandtap’, a tool I created to work with it: https://x-originating-ip.hashnode.dev/building-nandtap-dumping-a-cisco-meraki-z1-nand-via-raspberry-pi-gpio-without-removing-chip-from-board
Nice! Can you link the kit you used? Did you always used the same clip? I understand you had couple of them.
EDIT: Oh i see you linked it on github. Thanks!
