I just add more posts under /docs/_posts, following the specific naming convention for dates specified, and they will show up anywhere I have that little snippet that loops through categories.
Other than the metadata at the start of the file, I can just toss markdown files in, and they get auto-converted to static HTML pages.
Are there any gotcha’s I should be aware of? I imagine folks who’ve been using this for a while may have a list of tips, tricks, and best practices.
If you can help me by sharing those, I will appreciate you even more!
I am mostly annoyed by the fact GitHub is using another (modified, not really known) version of the layout files. So it is a little hard to develop local and push online. You will get headache while working with tables. My workaround is embedded html instead of markdown.
First you create a repo at http://github.com/username with the name `username.github.io`, which is available at the same direct domain. But It can be redirected to a known CNAME, for a more professional look.
As I see you are already over this steps.
I have a Debian VM with a clone of my repo. I am using a local jekyll build to test changes with a nginx virtual directory … as said before, it looks a little different, but close enough.
<details>
<summary>SPOILERS - Second stage skills</summary>
The second stage is actually almost trivial, once you understand how the “ECB” mode of AES works:
- Each 0x10-byte block is independently encrypted / decrypted.
- Only the last block is required to have the PKCS7 padding.</details>
</details>
The auto convert works, as I see at your page. But I think I prefer the local jekyll build way.
One of the best features is to write in markdown at any terminal, and still get the complete layout.
One issue I hit was that including embedded HTML in markdown can prevent the text in those elements from being converted to HTML.
## Section Title
<details><summary>Section Title</summary><P/>
This should be a list, but is not:
* Foo
* Bar
* Baz
</details>
I actually am disappointed by that, since I have used those extensively in my write-ups. My “how to use SPI” post originally used those for each section … but I had to quickly commit an edit to remove all those collapsible sections.
That’s painful, because I really want folks to be able to browse without seeing the actual spoiler text, but I don’t want to have to reformat everything to HTML.
I see. I will take a look, but I can’t test it before tomorrow.
I hoped the more complex solution 2 in the linked article would help. But I have not tested it myself. And as said before, sometimes the GitHub pages are a little quirky.
But in general, they are developing and react to feedback.
Here’s a test page that shows how it just munges everything in a markdown file that uses <details>. I even tried various options to put stuff into <P>, <DIV>, or none of the above. Every option so far has resulted in the details being put as unmodified text … no markdown → html conversion.
I’ll ask Claude next, but I’m starting to think I’ll be forced to transition from markdown to full HTML.
The issue is Kramdown (Jekyll’s default Markdown parser) doesn’t process Markdown inside block-level HTML elements by default. The fix is the markdown="1" attribute on the <details> tag, which tells Kramdown to process the inner content as Markdown.
This will be a huge help in reducing spoiler fatigue.
Woo-hoo! The collapsible sections are confirmed working now. I’m ready to start pushing more content. Thank you for the help!
# Sample workflow for building and deploying a Hugo site to GitHub Pages
name: Deploy Hugo site to Pages
on:
# Runs on pushes targeting the default branch
push:
branches: ["main"]
# Allows you to run this workflow manually from the Actions tab
workflow_dispatch:
# Sets permissions of the GITHUB_TOKEN to allow deployment to GitHub Pages
permissions:
contents: read
pages: write
id-token: write
# Allow only one concurrent deployment, skipping runs queued between the run in-progress and latest queued.
# However, do NOT cancel in-progress runs as we want to allow these production deployments to complete.
concurrency:
group: "pages"
cancel-in-progress: false
# Default to bash
defaults:
run:
shell: bash
jobs:
# Build job
build:
runs-on: ubuntu-latest
env:
HUGO_VERSION: 0.124.1
steps:
- name: Install Hugo CLI
run: |
wget -O ${{ runner.temp }}/hugo.deb https://github.com/gohugoio/hugo/releases/download/v${HUGO_VERSION}/hugo_extended_${HUGO_VERSION}_linux-amd64.deb \
&& sudo dpkg -i ${{ runner.temp }}/hugo.deb
- name: Install Dart Sass
run: sudo snap install dart-sass
- name: Checkout
uses: actions/checkout@v4
with:
submodules: recursive
- name: Setup Pages
uses: actions/configure-pages@v5
- name: Install Node.js
uses: actions/setup-node@v3
with:
node-version: '16'
- name: Install Node.js dependencies
run: |
npm install -g postcss postcss-cli autoprefixer
[[ -f package-lock.json || -f npm-shrinkwrap.json ]] && npm ci || npm install
- name: Build with Hugo
env:
HUGO_ENVIRONMENT: production
HUGO_ENV: production
run: |
hugo \
--minify \
--baseURL "${{ steps.pages.outputs.base_url }}/"
- name: List files in public directory before rename
run: ls -l public/
- name: Rename offline search index
run: |
for file in public/offline-search-index*.json; do
mv -f "$file" public/offline-search-index.json
break # This ensures only the first matching file is copied
done
- name: Upload artifact
uses: actions/upload-pages-artifact@v3
with:
path: ./public
# Deployment job
deploy:
environment:
url: ${{ steps.deployment.outputs.page_url }}
needs: build
steps:
- name: Deploy to GitHub Pages
uses: actions/deploy-pages@v4
I’ve added posts up to the initial evaluation of stage3, and I’ve published my (sos_helper)[GitHub - henrygab/sos_helper · GitHub] python-based sword of secrets helper. Made it SO much easier to interact with the sword, even by just having up arrow / down arrow history. Of course, also adds programmatic access.
Hope to post the remaining bit about Stage 3 this weekend…
The sos_helper library has grown into an indispensible tool, wrapping the SPI functionality into easily used commands (and python functions).
I put up stage 4 last week or so, and I started thinking about just how deep I wanted to break into this device.
Things I could still write about (done already):
expanding the AES-CBC oracle into a full-blown arbitrary code execution (ACE) exploit
extracting the AES key (without even using the ACE exploit) that all the challenges used
creating a location-agnostic firmware dumping function, hacks used to make it fit in 0x80 bytes (in order to easily load/run within the challenge framework), encrypting it with the AES key, and … profit!
Same as above, but now dumping the bootloader of the device … or the vendor options, etc.
Extracting a different AES key that is only used to encrypt the firmware updates…
The author of this kickstarter campaign said I could write whatever I wanted, but I feel like publishing either of those two AES keys would be … in poor taste.
What do you folks think?
Given the author’s explicit “OK”, should I include the AES keys directly in my library and/or posts?
In my opinion, it would be poor taste to include the AES keys directly. If users want them, they can follow the information you write to extract them themselves (and get the sense of accomplishment from actually doing something directly instead of just downloading the defeated end boss).
For the challenge key, anyone doing the CTF would already have the data to verify the key (all the challenges used that key for encryption/decryption). While the firmware decryption key could be heuristically determined, a hash there sounds good. I could probably also include hashes of the firmware and the bootloader.
