Updating to the latest Bus Pirate 5 firmware
The docs have been refreshed with more obvious info on how to download the firmware, which file to use and what happens when the wrong firmware is programmed.
Latest Firmware
The latest bleeding edge firmware is auto-compiled and posted in the forum. Get the latest and greatest.
Upgrade process
See the firmware update tutorial for detailed instructions
  • Grab the latest and greatest auto-build firmware from the forum
  • Open the .zip archive and extract your firmware
  • If your Bus Pirate came in a case (most boards), use bus_pirate5_rev10.uf2
  • Type $ and press enter in the Bus Pirate terminal to enter bootloader/upgrade mode
  • A USB drive called RPI-RP2 will connect to your computer
  • Drag a .uf2 firmware file into the RPI-RP2 drive
The file copies, the Bus Pirate resets, and you’re good to go!
Help! Bus Pirate blinks red!
Recent versions of the Bus Pirate firmware detect the hardware revision at startup. It will blink red if there is a revision mismatch.
Enter the bootloader manually (plug in the USB cable while pressing the button on the bottom side) and try the other file.
