USB Sniffer & PS2 Sniffer Plank + Firmware for BP
@ian As for the plank’s PCB, I went through its KiCad files (development/adapter-kaybee-plank-1REV1) and it all looks good to me.
A few small things for the next order:
  • BOM: C1-C3 say 47uF, but the part (C602037, CL21A226MAYNNNE) is 22uF.
  • BOM: D2 (the PWR LED) and J2 have no LCSC number, so add one for an assembly order.
  • R408, R410 and R412 carry a second LCSC field, szlcsc_partnumber, with 0402 parts (C25779, C25744, C25741), and C25779 is 33K where R408 is 68K. plots/bom.csv reads the right field, szlcsc_partnum (0805 parts), but a BOM tool that reads the other one would order the wrong parts. I’d delete that field.
  • I’d leave as much as possible in 0805 so that if something needs to be changed the user has it easier.
  • plots/ is from before the last PCB change (ba8b214, R3), so make the gerbers from the current PCB. The position file in plots/ still matches the current PCB.
  • C1-C3 put 66uF (nominal) straight on VBUS, and USB 2.0 (7.2.4.1) allows at most 10uF at plug-in unless the device limits its inrush current. BUT I’d leave them as they are (66uF nominal): hosts keep at least 120uF on VBUS for the plug-in surge, plenty of USB gadgets carry more than 10uF, and it worked fine on my bench. The ports that could complain are the ones with a current-limit switch, where Windows shows “Power surge on the USB port”. If anyone hits that, one 10uF capacitor instead of three 22uF should fix it.
  • No ESD protection on VBUS, D+/D-, trigger, DAT/CLK… ← Since we don’t want to raise the price or complexity much, maybe we can skip this.
As far as I’m concerned you can put it on sale already, the firmware is good enough for the launch and I’ve tested it for quite a few hours with lots of tests.
