Hi, today I’ve added some flags to the hex storage command: -d to show address offset, -a to dump in ascii and -s to set the line size (i.e. 8 or 16, etc)
If this could be useful I can send a pull request.
PS: also yesterday I sent a micro-pull request to fix a small typo in the hex dump (it was dumping in decimal instead of hex)
Sorry, I forgot that github adds same branch commits to an existing pull request, so the yesterday small pull request has been updated to include also the new code shown here. Sorry for the noise. Ignore the pull request or cherry pick only the needed parts
I’ll accept your requests. I’m sorry, I no longer have access to the email for our github so I don’t see notifications (it’s a long story involving national firewalls and load bearing laptops).
I did not yet update the help and translations because I didn’t know if you prefer do it yourself or if I can do it directly. If you want I can update the help and English strings and put them in the same pull request.
I would appreciate any help! Feel like I’m drowning at the moment For the translations: you just alter the us-en.h, then run the json2h.py script and it will update all the translations and the main header file. I’m realizing now this isn’t in the docs yet, I’ll add it.
I was thinking about adding pagenation and x to exit to the HEX viewer. I sometimes need to check a very long file and it’s unpleasant being stuck through a 8mb dump.
I could move the hex dump code from disk_hex_handler into its own function and add two new parameters: start dump offset and dump bytes len.
I can also return true if there are more data, and false if EOF.
The disk_hex_handler should be modified to repeatedly call the new hex_dump function until there are new data available.
I think that’s really nice. I currently have several different “any key to continue, x to exit” functions floating around, i will consolidate that into something more universal.
These are really fantastic updates, thank you so much. I created a new branch “contrib” and created a new pull request there. Everything looks good, so I’ll merge it into main now.
