AP33772SDKZ USB-C Power delivery management
Continuing from the USB PD Plank thread.
When I tested the AP33772S I ran into an issue where the chip expectes to be powered from the USB source, not independently as we do with the Bus Pirate. The causes the chip to hang after USB C is attached and removed once, a power cycle is needed to get it back online. This isn’t great for a design where we want the chip to be an always-on device for testing USB supplies.
The datasheet mentions that the V5V 5 volt LDO output can be used to power the chip when USB isn’t attached. It doesn’t say anything else though, such as does the external supply need to be removed to avoid damage to the on-chip LDO regulator? I wrote Diodes INC to ask, but I rarely hear anything back from chip companies.
This is a bodge wire from the V5V capacitor to the 3.3V in pin of the breakout board. The 3.3v in pin is safe for 3.3-5volts, so we can feed it in there.
It does seem to work. Previously without USB attached the chip was unpowered. Now it responds to an I2C scan. That’s great.
Status, temperate, etc all available without the USB supply attached. Okay, let’s attach a USB supply and see what happens…
It didn’t blow up, but it also doesn’t recognize when the cable is detached.
After some extended use, powering externally doesn’t seem to instantly degrade the chip. However, I am unable to send the USB PD hard reset request. It just doesn’t do anything.
It’s going to take some thought to figure out if and how this chip is useful for a plank.
Here is one possibility
  • Change pull-up power from Bus Pirate VOUT to the AP33772 internal 5volt regulator. Now the chip will properly power cycle when USB supply is inserted or removed
  • Add 100K pull-down to the I2C interrupt pin
The Bus Pirate can sit and wait for the I2C_INT pin to go high, accessing the chip only after a USB supply is attached.
I’ll make these changes to the board and we’ll scrap the previous version.
Making some progress with the hacked board. Will probably have something substantial tomorrow.
I got stuck on the above yesterday. Can read the PDOs but they don’t display. Even my printf debug statements didn’t display. What on earth?
Line break issue. The code used \n only without \r, so each line just wiped the last and the prompt cleared the rest. :squinting_face_with_tongue: Easy fix at least.
i think you mean \r without \n. \r is the carriage return which causes the output to start at same line. but thats a classic to mix that up
Actually I think it was something else. I had to move all the print functions to the local file or they just didn’t get run. Not sure what is going on, but I wanted to customize them anyways so it makes sense to have a local copy.
Now we’re getting the basic status info, and the list of profiles.
Todo:
  • Request profile
  • Set V and I for PPS and AVS profiles
  • USB PD hard reset and acknowledge
  • Protection?
Framework charger.
Cheap-o emergency charger from a supermarket.
The USB C port on my cheap bench supply.
This seems to be the explination. The voltage leaking through the pull-ups is coming out on VOUT and raises the voltage above 0.8V and then the USB source will not deliver power. The solution is a hefty resistor between VOUT and ground, which is not a really great solution at 20+ volts.
Getting close:
  • request profiles, with voltage and current for PPS and AVS profiles
  • USB hard reset
  • Get device status
Todo:
  • Requested current is calculated incorrectly for some reason
  • Help menu
Fixed the bug where Requested Current (I) was giving the wrong values. The driver I used was treating requested V and I as 8 bit registers, when in fact they are 16 bit registers. Fixed this and made a pull request to the upstream project.
It’s looking nice. Now I just have to write the help text.
Done with this one for now. Pushed to main. Will write docs when I have a working plank.
Have you considered looking at raw manipulation of the CC line? Looks like it shouldn’t be too difficult according to https://web.archive.org/web/20161220102831if_/http://www.usb.org/developers/presentations/USB_DevDays_Hong_Kong_2016_-_USB_PD.pdf
This would let you do fuzz testing of PD sources and sinks, which would be interesting.
If you had a dummy load connector and a voltage measurement facility in the plank, I think there are lots of interesting possibilities.
I’ll keep looking for a reference design for a CC phys transceiver - “DC coupled … nominal voltage… “ is not quite enough info for me to grok the electrical interface needed
