Arcade Pirate - retro games in the latest experimental build
Arcade
White-knuckle action at terminal speed.
Snake — snake
Pilot a colossal circuit-trace serpent through cyberspace, devouring food pellets to grow ever longer. The board wraps toroidally — fly off one edge and you come screaming out the other. One wrong turn into your own tail and it’s game over.
Run snake
Controls WASD or arrow keys to steer, q quit
Objective Eat as much food as you can without self-collision
Bricks — bricks
Wield an electrified paddle and smash through a towering wall of electronic components. Capacitors explode, resistors shatter, ICs crack in showers of sparks. Don’t let the ball hit the floor.
Run bricks
Controls A/D or left/right arrows to move paddle, q quit
Objective Clear all bricks without losing the ball
Worm — worm
BSD worm gone nuclear. Food pellets are numbered 1–9 — eat a 9 and your worm explodes in length like a freight train. Plan ahead or get buried in your own tail.
Run worm
Objective Eat numbered food and survive as long as possible
Wire Trace — trace
Race your probe through a labyrinth of glowing copper PCB traces. Collect solder blobs like treasure, dodge screaming magic smoke monsters with glowing eyes, and punch through vias to teleport across the board. The maze grows deadlier every level.
Run trace
Controls WASD or arrow keys to move, q quit
Objective Reach the goal (G) from the start (S), collect solder blobs for bonus points, avoid sparks
Protocol Invaders — invaders
Formations of corrupted data packets — 0xDEAD, NAK, CRC! — descend from the sky toward your crumbling capacitor barriers. Fire your beam cannon upward and blast them into pixel explosions before they land. The barriers are degrading. The packets are winning. Almost.
Run invaders
Controls Left/right arrows to move, space to fire, q quit
Objective Destroy all enemy packets before they land
Side-Scrollers & Runners
The world is moving. You react or you’re dead.
PCB Run — pcbrun
Hurtle across the surface of a massive PCB at breakneck speed. Resistors, capacitors, and ICs come screaming toward you — jump or get flattened. Speed increases until your reflexes give out.
Run pcbrun
Controls Space or Up to jump, q quit
Objective Survive as long as possible
Signal Rider — sigride
Surf a rolling wall of oscilloscope waveform energy. Dodge erupting EMI spike towers, crackling ground fault geysers, and noise artifacts that strike like lightning. Grab clean signal pickups to keep your score climbing.
Run sigride
Controls Up/down arrows to change lane, left/right to nudge, q quit
Objective Ride the signal as far as possible without hitting hazards
Display — An oscilloscope-style screen with a scrolling grid. Three signal lanes labeled on the left:
  • HI (yellow) — logic high
  • Z (dim) — tri-state / mid
  • LO (green) — logic low
Waveform — A digital signal trace (_) scrolls continuously leftward, transitioning between lanes with vertical edges (|, +). Scope grid dots appear in the background.
Player — You’re @ (white, bright), surfing on the waveform. Ride the signal to score points. Staying on the correct lane earns bonus points.
Hazards to dodge:
Hazard Char Color Threat
Noise spike ~ red Hurts if you’re on that lane
Ground fault G red Deadly only on LOW lane
Ringing W yellow Deadly only on HIGH lane
EMI burst # + : magenta Fills entire column — dodge it!
Bonus edge + green +25 pts pickup
Controls: UP/DOWN = switch lanes, LEFT/RIGHT = nudge position, q = quit
Mechanics: Speed increases every 100 points. Getting hit gives 20 frames of blinking invulnerability. Drift off the left edge = lose a life. Game over screen: “SIGNAL LOST — Waveform flatlined.”
Crossflash — xflash
Dodge between roaring lanes of protocol traffic on a logic analyzer battlefield — SPI clocks like freight trains, I2C bursts like electric eels, UART packets like screaming rockets. Reach the golden target columns or get clocked.
Run xflash
Controls Arrow keys to move, q quit
Objective Cross all bus lanes and reach every target column
Platformer
Stack Overflow — stkover
Bounce skyward through an endless vertical gauntlet of PCB platforms — decoupling caps, test points, solder pads, moving headers stretching up through a neon stratosphere. Your probe auto-bounces on landing; steer left and right to climb. Miss a platform and you plummet into the void.
Run stkover
Controls Left/right arrows to move (auto-jump on landing), q quit
Objective Climb as high as you can
Roguelike
Rogue Probe — rogue
Descend into a procedurally generated dungeon carved from silicon inside an IC die. Battle towering latch-up demons crackling with ESD lightning, explore rooms connected by glowing circuit traces, find the firmware dump, and fight your way out through the bond pad. Turn-based. Permadeath. No mercy.
Run rogue
Controls WASD or arrow keys to move/attack, space to wait, q quit
Objective Find the firmware dump on the final floor and escape alive
Puzzles
2048 — 2048
Slide numbered tiles across a 4×4 grid in a spiral of mathematical transcendence. Matching tiles collide, merge, and double. Reach the blazing 2048 tile to win — or keep pushing into the infinite.
Run 2048
Controls WASD or arrow keys to slide, r restart, q quit
Objective Merge tiles to reach 2048
Mine Sweep — mines
Sweep an enormous minefield honeycombed with hidden explosives. Numbers are your only clue — each reveals how many mines lurk in adjacent cells. One wrong click and the whole board detonates. Cold sweat. Pure logic.
Run mines
Controls WASD or arrow keys to move cursor, space/enter to reveal, f to flag, r restart, q quit
Objective Reveal all safe cells without hitting a mine
Board & Strategy
Tic-Tac-Toe — ttt
Face off across a 3×3 grid against an unstoppable minimax AI — a cold calculating colossus that has already computed the outcome. It knows you can’t win. You play anyway.
Run ttt
Controls 1–9 (numpad layout) to place your mark, r restart, q quit
Objective Get three in a row
Drop Four — drop4
Hurl glowing discs into a 7-column arena in an orbital bombardment of strategy. Connect four in a row — horizontal, vertical, or diagonal — before the CPU opponent’s look-ahead AI does it first. The grid hums with competitive electricity.
Run drop4
Controls 1–7 to drop in column (or arrows + enter), r restart, q quit
Objective Connect four discs in a row
Fleet — fleet
Call coordinates into the void and pray for a hit. Five enemy ships lurk somewhere on a 10×10 ocean grid. Torpedoes blaze through the water. Explosions dot your previous shots. The hunt is almost over — sink them all.
Run fleet
Controls Arrow keys to aim cursor, space/enter to fire, r restart, q quit
Objective Sink all 5 ships
Educational
Logic Gates — gates
A countdown timer blazes overhead like a red sun. Truth tables materialize and you must conjure the matching logic expression from four choices — AND, OR, XOR, inverted gates orbiting like arcane sigils. Logic is your only weapon. Difficulty escalates.
Run gates
Controls 1–4 to pick answer, q quit
Objective Answer as many correctly as possible before time runs out
Crypto Crack — crack
Intercepted cipher text cascades across your terminal — Caesar wheels, XOR masks, hex streams, binary waterfalls — all screaming to be decoded before the timer hits zero. Your fingers are already moving. Difficulty and cipher variety ramp with each level.
Run crack
Controls Type answer + enter to submit, q quit
Objective Decode as many ciphers as possible
Simulation
Game of Life — life
Hover above an infinite grid as patterns of glowing life bloom and die beneath your hands — gliders, oscillators, and still lifes emerging from pure mathematics. The universe is alive. It doesn’t need your guidance. It only needs to be observed.
Run life
Controls Space pause/resume, r randomize, c clear, +/− speed, q quit
Objective Observe and experiment with emergent cellular patterns
Word Game
Hangman — hangman
The gallows are made of soldering iron and copper wire. Incomplete words glow in oscilloscope traces — MOSFET, BUSPIRATE, CHIPSELECT — with blank spaces waiting to be filled. Every wrong letter adds another component to the scaffold. Choose wisely.
Run hangman
Controls a–z to guess letters, q quit
Objective Guess the word before the drawing is complete
Quick Reference
Game Command Genre Controls
Snake snake Arcade WASD / arrows
Bricks bricks Arcade A/D / arrows
Worm worm Arcade WASD / arrows
Wire Trace trace Arcade WASD / arrows
Protocol Invaders invaders Arcade arrows + space
PCB Run pcbrun Runner space / up
Signal Rider sigride Runner arrows
Crossflash xflash Runner arrows
Stack Overflow stkover Platformer arrows
Rogue Probe rogue Roguelike WASD / arrows + space
2048 2048 Puzzle WASD / arrows
Mine Sweep mines Puzzle WASD / arrows + space + f
Tic-Tac-Toe ttt Board 1–9
Drop Four drop4 Board 1–7 / arrows
Fleet fleet Board arrows + space
Logic Gates gates Educational 1–4
Crypto Crack crack Educational type + enter
Game of Life life Simulation space, r, c, +/−
Hangman hangman Word a–z
Bus Pirate arcade now available in the experimental build.
The AI did an amazing job bringing to mind the crazy early-eighties artwork for early computer games. Colors, over-hype, and all! Well done … adds a fanciful flare and really … just fun art!
I’m really impressed, it was a lol afternoon project. LLM came up with a list of games, wrote them with minimal supervision. Then it made the above docs page and a prompting document to put in a image model to get the retro art.
I did poke a few of the images a bit (you can tell by the image name) and I had to test the gameplay. Other than that it was mostly unsupervised models building the whole thing.
Now, would I do that with actual workhorse code in the bus pirate? At this point absolutely not.
We should make a game thats like Pokemon go, but you discover new beasts by discovering different NEC codes with the IR plank toy. maybe expand it to other protocols and planks.
We could have it make generative “creatures” based on the data you discover in real-world devices.
EDIT: ill start working on it although dont think i have IR plank yet hehe. will order one soon
That sounds super cool!
We can just send you an irtoy plank, they’re being made but will be ready shortly.
no no no dont worry ian. you have already done too much, i want to show my support. im going to be making an order next week from dirtyPCBs with some of the other new stuff like the RS232 survival kit. i did become curious about the USB and PS/2 sniffing module that is on buspirate shop tho (in dev and didnt see on dirtypcbs)
i went down a rabbit hole the other day looking into PD and what it would take to emulate it. For instance if i wanted to dump power from my lab supply to a macbook and emulate the PD negotiation. I think id just need to advertise the correct PDOs
things like Twonkie can sniff PD
and in the past ive wanted to build something like the USBValve that sniffs the data lines to detect BADUSB etc
Completely derailed the convo, but dont worry. I will order the IR toy soon. But i definitely am curious about a USB sniffing plank if you have a dev version you can throw in
PS: should i be ordering from bus pirate shop or dirty pcbs these days?
In general the shop. is not working, but you can try! Dirty PCBs is the way to go. If you want a USB PD with the simple.chip (no sniffing, just query and trigger basically) I have two of the current prototype and I can send you one from here. There’s none in China though.
nah dont worry for now. i can learn/figure stuff out with what i have. i do think its a cool idea for a plank though. we could write modes and commands to sniff PD , detect badusb, passthru (maybe?)
