@mbrugman Reading an Arduino Mega works and then right after an Arduino Leonardo (ATmega32U4) doesn’t work.
dude.zip (11.2 KB)
dude.zip (11.2 KB)
Hmmm, I was able to go back and forth between 328p and 2560 with no problem.
I have some 32u4 parts around somewhere; I’ll try it tomorrow.
@mbrugman Alright, I figured it out! We need to clearly state in the documentation that the Arduino must absolutely be connected via USB and powered — I ran some tests and the errors I was getting were because of that.
32uworkingdude.zip (41.6 KB)
retesting (arduino powered by USB)
arduino mega → works fine
arduino leonardo → works fine
arduino uno → works fine
I tried running them in sequence, changing the order, etc… and it all seems to work as expected. Great job @mbrugman ! You can go ahead and merge it as far as I’m concerned.
Interesting!
EDIT: I’m overthinking everything below, just ignore me, haha.
I was starting to remember something special about the u4 parts: the 32u4 part actually has more than 32k of flash!
There’s additional flash above 0x7fff set aside for a usb/dfu bootloader. I thought avrdude might be trying to read that, which would generate an error similar to what we were seeing with larger flash.
@mbrugman It’s curious, isn’t it? In the logs, you can see that the MCU type does get detected over SPI, but then the SPI read page fails — and as soon as you power it via USB, voilà! It works!
With your PR The ATmega32U4 dump works fine — check out this photo:
avrdude.exe -c buspirate -p m32u4 -P COM12 -b 115200 -U flash:r:"C:\Users\regue\Desktop\dump.bin":r
attempting to initiate BusPirate binary mode ...
Paged flash write enabled
Reading flash memory ...
Reading | ################################################## | 100% 39.76 s
Writing 32730 bytes to output file dump.bin
Avrdude done. Thank you.
Thanks again for testing and for the sanity checks ![]()
@mbrugman Can you do me a favor? Could you power your boards only using the Bus Pirate’s VOUT at 5 volts, and try switching boards around to see if you get the same issue as I did? Maybe try plugging in a USB hub (not self powered) or something in between that slightly drops the Bus Pirate’s voltage?
I did all my testing with only BP power - no USB, but I didn’t try a 32u4. I do use a powered hub, I can tra a different one
@chickendipper - the fix for this is merged into the main branch now ![]()
@dreg - I did some experimenting with 32u4 boards today; I had a few in my bin. To be fair, I tried them using AVRDude with both the Bus Pirate and the AVRDragon.
cmdline for the BP was:
avrdude -c buspirate -P /dev/ttyACM1 -p m32u4 -U flash:r:full32u4.BP1.bin
and for the Dragon:
avrdude -c dragon_isp -p m32u4 -U flash:r:full32u4Dragon1.bin
Here’s where it got a little funny… Of the 3 boards (all identical), one had to have the Leonardo’s USB connected - without it, the BP couldn’t read the Flash. The other two I could read the flash with the BP with the Leonardo’s USB connected or disconnected.
(For reference, the part has to be powered for the AVRDragon to work, so I had to have the Leonardo’s USB plugged in for all 3 to make the dragon work).
So, inconsistent, which is odd; but I did recreate your experience where you had to power the Leonardo board. ![]()
Weird. 3 identical boards exactly the same, or with the same chip but different design?
The updates to legacy 4 third around the PSU seems to have been effective. I’m in a refactoring mood and think turning the pirate lib into a struct of functions might might be on the horizon. A kind of rework to a C++ like object framework.
Same model board, different firmware on each (which shouldn’t matter). Really odd, but who knows?
@mbrugman Can you confirm that as soon as you connect the AVR board via USB, it always works?
Yes, that was the behavior I saw. Even disconnecting and reconnecting everything it worked for the “bad” board, as long as the USB was connected.
Alright… thank you so much for this, I was going a bit crazy haha. While we figure out what the actual issue is, I’m going to update the documentation.
The 32u4 (and 16u4) are pretty unique parts. Maybe the power requirements with the USB make it a bit flaky that way.
The dragon has no problems; but the dragon requires the target be powered before it’ll do anything.
By the way, it’s funny how we’ve turned @chickendipper ’s thread into a full-on Bus Pirate development thread — the poor user must be freaking out with all this stuff that doesn’t even interest them
we’re unbelievable.
Thread derailment service at work again ![]()
Hey, let’s be “modern” firmware engineers: Thread Takeover as a Service (TTaaS)! ![]()
