I have a BP8 and BP10 (first release). I updated both to firmware to
Firmware main branch (2024-04-03T13:07:16Z)
My BP10 has a fix for the first bug but I never did the second hardware fix. I didn’t feel comfortable performing this fix.
I am testing a flash chip. To be precise, I copied the flash data from one chip to a second.
Here’s one odd thing.
I am able to read and verify the flash contents on my BP8.
But when I try to duplicate the same steps on my BP10, the “flash read” command aborts early in the cycle. The board disconnects from my computer, and when I look for the file system, none is mounted.
In addition, my syslog says:
Apr 3 13:00:04 mycpu kernel: [153678.739868] usb 1-2: reset full-speed USB device number 105 using xhci_hcd
Apr 3 13:00:04 mycpu kernel: [153678.867216] usb 1-2: device descriptor read/64, error -71
Apr 3 13:00:05 mycpu kernel: [153679.107411] usb 1-2: device descriptor read/64, error -71
Apr 3 13:00:05 mycpu kernel: [153679.347231] usb 1-2: reset full-speed USB device number 105 using xhci_hcd
Apr 3 13:00:05 mycpu kernel: [153679.475360] usb 1-2: device descriptor read/64, error -71
Apr 3 13:00:05 mycpu kernel: [153679.710858] usb 1-2: device descriptor read/64, error -71
Apr 3 13:00:06 mycpu kernel: [153679.950819] usb 1-2: reset full-speed USB device number 105 using xhci_hcd
Apr 3 13:00:06 mycpu kernel: [153679.950936] usb 1-2: Device not responding to setup address.
Apr 3 13:00:06 mycpu kernel: [153680.158929] usb 1-2: Device not responding to setup address.
Apr 3 13:00:06 mycpu kernel: [153680.366952] usb 1-2: device not accepting address 105, error -71
Apr 3 13:00:06 mycpu kernel: [153680.495138] usb 1-2: reset full-speed USB device number 105 using xhci_hcd
Apr 3 13:00:06 mycpu kernel: [153680.495410] usb 1-2: Device not responding to setup address.
Apr 3 13:00:06 mycpu kernel: [153680.703213] usb 1-2: Device not responding to setup address.
Apr 3 13:00:06 mycpu kernel: [153680.910911] usb 1-2: device not accepting address 105, error -71
Apr 3 13:00:06 mycpu kernel: [153680.911330] usb 1-2: USB disconnect, device number 105
It does it each time I try. This is the first time I’ve tried to use my BP10 w/SPI. One other this I noticed was this sequence:
SPI> W
Power supply
Volts (0.80V-5.00V)
x to exit (3.30) >
Maximum current (0mA-500mA), <enter> for none
x to exit (none) > P
0.0mA requested, closest value: 0.0mA
Power supply:Enabled
Error: Current over limit, power supply disabled
So I set it to 100ma. And when I continued, it crashed.
I’m not sure if my problem is caused by the hardware bug I didn’t fix, or it’s something different.
