BP5 fails self-test
My BP5 terminal locked up as I was preparing to flash an SPI chip, and also seemed flaky shortly before that. After plugging it back in I tried a self test - these are the last few lines:
BIO4 SHORT->BIO3 (1/1.80V): ERROR!
BIO4 SHORT->BIO5 (1/1.77V): ERROR!
BIO4 SHORT->BIO6 (1/1.76V): ERROR!
BIO4 SHORT->BIO7 (1/1.77V): ERROR!
BIO5 PU-LOW: 0.09V OK
BIO5 SHORT->BIO0 (1/1.77V): ERROR!
BIO5 SHORT->BIO1 (1/1.75V): ERROR!
BIO5 SHORT->BIO2 (1/1.75V): ERROR!
BIO5 SHORT->BIO3 (1/1.75V): ERROR!
BIO5 SHORT->BIO4 (1/1.75V): ERROR!
BIO5 SHORT->BIO6 (1/1.75V): ERROR!
BIO5 SHORT->BIO7 (1/1.74V): ERROR!
BIO6 PU-LOW: 0.09V OK
BIO6 SHORT->BIO0 (1/1.77V): ERROR!
BIO6 SHORT->BIO1 (1/1.75V): ERROR!
BIO6 SHORT->BIO2 (1/1.77V): ERROR!
BIO6 SHORT->BIO3 (1/1.72V): ERROR!
BIO6 SHORT->BIO4 (1/1.72V): ERROR!
BIO6 SHORT->BIO5 (1/1.80V): ERROR!
BIO6 SHORT->BIO7 (1/1.77V): ERROR!
BIO7 PU-LOW: 0.10V OK
BIO7 SHORT->BIO0 (1/1.77V): ERROR!
BIO7 SHORT->BIO1 (1/1.77V): ERROR!
BIO7 SHORT->BIO2 (1/1.75V): ERROR!
BIO7 SHORT->BIO3 (1/1.75V): ERROR!
BIO7 SHORT->BIO4 (1/1.75V): ERROR!
BIO7 SHORT->BIO5 (1/1.75V): ERROR!
BIO7 SHORT->BIO6 (1/1.75V): ERROR!
CURRENT OVERRIDE: OK
CURRENT LIMIT TEST: OK
PUSH BUTTON (SPACE TO SKIP):
Tried updating the firmware, different cables, rebooting the PC - no dice. Any ideas?
FYI - It only reports 1.7V when I enabled Vout in SPI mode w/ the default 3.3v setting and nothing else connected. My multi-meter reads 2.5v between Vout and ground. I noticed a similar though less severe voltage sag earlier today using ‘flash write’, but now it seems to occur whenever I turn the power supply on.
Hi Byron,
Thanks for the bug report, I’m sorry this happened. I’ll message you and make sure we get a replacement sent out right away.
It looks like there may be a few failures. 1.7 is about half of 3.3volts, in which case I’d assume an op-amp failed in the adjustable power supply. But if the actual voltage measured doesn’t match what the Bus Pirate shows, then a second system (voltage monitoring) must also have an issue.
I’ll write now for details on how to get you a replacement.
