BP5 or BP6 LCD part different from given supplier
Hello,
I was thinking of making my own bus pirate because where i am, it’s not possible to order it.
the image in the given link for LCD is :
https://item.taobao.com/item.htm?id=581793017604
has a different pin size from the one used in the PCB or the one specified in the hardware components.
has the supplier changed the pin format ? where can i get the LCD that is compatible with the PCB files?
Furthermore more the LCD driver on the supplier website says ST7789T3 while the BP5 spec says ST7789V
Bus pirate specified LCD
Supplier LCD Pinout
Excited to see your build!
The part change on the same Taobao page is something I’ve seen with several display sellers. It’s weird.
I searched their store and it doesn’t seem to be on Taobao anymore. We definitely use the same display we always have, and we bought some recently so they definitely still have/make them.
You could try contacting the manufacturer via the Taobao chat box.
Thank you for your recommendation. I finally managed to find it.
The same supplier had it; they just changed the product link.
I’m still trying to find the rest of the parts. It would have been awesome if you could link each schematic part to its equivalent LCSC part number.
Glad you managed to find it!
If you get most of your parts at LCSC and have a link list I’ll add it to the docs.
