Hi,
I just got my BusPirate 6 Rev2 and ran the self test and getting errors for BIO5, is this something that will cause issues for me using this device or is there something I can do to fix it?
No cables were attached during the self test, and BP was unplugged/plugged fresh before running test, I also ran twice and got same errors
HiZ> ~
SELF TEST STARTING
DISABLE IRQ: OK
ADC SUBSYSTEM: VUSB 5.21V OK
FLASH STORAGE: OK
PSU ENABLE: OK
VREG==VOUT: 3358 = 3338 OK
BIO FLOAT TEST (SHOULD BE 0/<0.30V)
BIO0 FLOAT: 0/0.04V OK
BIO1 FLOAT: 0/0.04V OK
BIO2 FLOAT: 0/0.05V OK
BIO3 FLOAT: 0/0.05V OK
BIO4 FLOAT: 0/0.06V OK
BIO5 FLOAT: 1/2.92V ERROR!
BIO6 FLOAT: 0/0.05V OK
BIO7 FLOAT: 0/0.05V OK
BIO HIGH TEST (SHOULD BE >3.00V)
BIO0 HIGH: 3.35V OK
BIO0 SHORT->BIO5 (1/2.92V): ERROR!
BIO1 HIGH: 3.34V OK
BIO1 SHORT->BIO5 (1/2.92V): ERROR!
BIO2 HIGH: 3.34V OK
BIO2 SHORT->BIO5 (1/2.93V): ERROR!
BIO3 HIGH: 3.34V OK
BIO3 SHORT->BIO5 (1/2.93V): ERROR!
BIO4 HIGH: 3.34V OK
BIO4 SHORT->BIO5 (1/2.93V): ERROR!
BIO5 HIGH: 3.34V OK
BIO6 HIGH: 3.34V OK
BIO6 SHORT->BIO5 (1/2.92V): ERROR!
BIO7 HIGH: 3.34V OK
BIO7 SHORT->BIO5 (1/2.93V): ERROR!
BIO LOW TEST (SHOULD BE <0.30V)
BIO0 LOW: 0.02V OK
BIO1 LOW: 0.02V OK
BIO2 LOW: 0.03V OK
BIO3 LOW: 0.02V OK
BIO4 LOW: 0.03V OK
BIO5 LOW: 0.03V OK
BIO6 LOW: 0.03V OK
BIO7 LOW: 0.02V OK
LA_BPIO TEST (SHOULD BE 1)
LA_BPIO0 HIGH: 1 OK
LA_BPIO: 0:1 1:0 2:0 3:0 4:0 5:1 6:0 7:0
LA_BBIO20 SHORT->BIO5 (1): ERROR!
LA_BPIO1 HIGH: 1 OK
LA_BPIO: 0:0 1:1 2:0 3:0 4:0 5:1 6:0 7:0
LA_BBIO21 SHORT->BIO5 (1): ERROR!
LA_BPIO2 HIGH: 1 OK
LA_BPIO: 0:0 1:0 2:1 3:0 4:0 5:1 6:0 7:0
LA_BBIO22 SHORT->BIO5 (1): ERROR!
LA_BPIO3 HIGH: 1 OK
LA_BPIO: 0:0 1:0 2:0 3:1 4:0 5:1 6:0 7:0
LA_BBIO23 SHORT->BIO5 (1): ERROR!
LA_BPIO4 HIGH: 1 OK
LA_BPIO: 0:0 1:0 2:0 3:0 4:1 5:1 6:0 7:0
LA_BBIO24 SHORT->BIO5 (1): ERROR!
LA_BPIO5 HIGH: 1 OK
LA_BPIO: 0:0 1:0 2:0 3:0 4:0 5:1 6:0 7:0
LA_BPIO6 HIGH: 1 OK
LA_BPIO: 0:0 1:0 2:0 3:0 4:0 5:1 6:1 7:0
LA_BBIO26 SHORT->BIO5 (1): ERROR!
LA_BPIO7 HIGH: 1 OK
LA_BPIO: 0:0 1:0 2:0 3:0 4:0 5:1 6:0 7:1
LA_BBIO27 SHORT->BIO5 (1): ERROR!
TEST RP2350 E9 BUG FIX
BIO PULL-UP HIGH TEST (SHOULD BE 1/>3.00V)
BIO0 PU-HIGH: 1/3.31V OK
BIO1 PU-HIGH: 1/3.33V OK
BIO2 PU-HIGH: 1/3.32V OK
BIO3 PU-HIGH: 1/3.29V OK
BIO4 PU-HIGH: 1/3.28V OK
BIO5 PU-HIGH: 1/3.33V OK
BIO6 PU-HIGH: 1/3.31V OK
BIO7 PU-HIGH: 1/3.29V OK
BIO PULL-UP LOW TEST (SHOULD BE <0.30V)
BIO0 PU-LOW: 0.06V OK
BIO1 PU-LOW: 0.07V OK
BIO2 PU-LOW: 0.07V OK
BIO3 PU-LOW: 0.07V OK
BIO4 PU-LOW: 0.07V OK
BIO5 PU-LOW: 0.07V OK
BIO6 PU-LOW: 0.07V OK
BIO7 PU-LOW: 0.07V OK
CURRENT OVERRIDE: OK
CURRENT LIMIT TEST: OK
PUSH BUTTON (SPACE TO SKIP): PUSH BUTTON (SPACE TO SKIP): OK
ERRORS: 3
FAIL! :(
