A minor bug but it’s worth documenting. When the toolbar is enabled, and you disconnect from the BP - either with the “$” or “#” command, the bottom 4 lines of the toolbar stays. So if your output scrolls past the bottom (on my Linux system), the toolbar stays there.
A Unix “clear” command fixes it, as it resets the VT100 code to not “reserve” the bottom 4 lines.
Interestingly, when I use “screen” - the toolbar is present when I exit, but eventually scrolls up. The display is garbled a bit for a while.
When I use “tio” - the toolbar stays even if the screen scrolls past it.
p.s. If you use putty - there is a security update - some private keys are guessable (weren’t random enough).
