Build server setup documentation
The auto build server is the cheapest available Ubuntu 22.04 instance at Vultr.com. I followed these instructions, but substitute arm-gcc 10.3, which is what is included with the PICO SDK installer. These notes are so I can do it a bit faster next time…
Install git
sudo add-apt-repository -y ppa:git-core/ppa
sudo apt install -y git
git --version
Install CMake
sudo wget -qO /etc/apt/trusted.gpg.d/kitware-key.asc https://apt.kitware.com/keys/kitware-archive-latest.asc
echo "deb https://apt.kitware.com/ubuntu/ $(lsb_release -sc) main" | sudo tee /etc/apt/sources.list.d/kitware.list
sudo apt update
sudo apt install -y cmake
cmake --version
Install gcc-arm
curl -Lo gcc-arm-none-eabi.tar.bz2 "https://developer.arm.com/-/media/Files/downloads/gnu-rm/10.3-2021.10/gcc-arm-none-eabi-10.3-2021.10-x86_64-linux.tar.bz2"
sudo mkdir /opt/gcc-arm-none-eabi
sudo tar xf gcc-arm-none-eabi.tar.bz2 --strip-components=1 -C /opt/gcc-arm-none-eabi
echo 'export PATH=$PATH:/opt/gcc-arm-none-eabi/bin' | sudo tee -a /etc/profile.d/gcc-arm-none-eabi.sh
source /etc/profile
arm-none-eabi-gcc --version
arm-none-eabi-g++ --version
rm -rf gcc-arm-none-eabi.tar.bz2
Install pico sdk
sudo git clone https://github.com/raspberrypi/pico-sdk.git /opt/pico-sdk
sudo git -C /opt/pico-sdk submodule update --init
echo 'export PICO_SDK_PATH=/opt/pico-sdk' | sudo tee -a /etc/profile.d/pico-sdk.sh
source /etc/profile.d/pico-sdk.sh
Install BP5
sudo git clone https://github.com/DangerousPrototypes/BusPirate5-firmware.git bp5-main
cd bp5-main
mkdir build
cd build
cmake ..
make
Install build script and webhook
cd ~
md webhook
pip install virtualenv
apt install python3.10-venv
python3.10 -m venv env
sudo apt install build-essential libssl-dev libffi-dev python3-dev
source env/bin/activate
pip3 install flask
pip3 install github_webhook
pip3 install requests
sudo iptables -A INPUT -p tcp --dport 80 -j ACCEPT
sudo apt-get install iptables-persistent
screen
python3 webhook.py
Latest build server setup, condensed for less copy and paste. Maybe it should be a shell script…
Install git
sudo add-apt-repository -y ppa:git-core/ppa && sudo apt install -y git && git --version
Install CMake
sudo wget -qO /etc/apt/trusted.gpg.d/kitware-key.asc https://apt.kitware.com/keys/kitware-archive-latest.asc && echo "deb https://apt.kitware.com/ubuntu/ $(lsb_release -sc) main" | sudo tee /etc/apt/sources.list.d/kitware.list && sudo apt update && sudo apt install -y cmake && cmake --version
Install gcc-arm
Note: C23 is required for the most recent codebase. Use gcc-arm-none-eabi 13+. This one should work for Linux
curl -Lo gcc-arm-none-eabi.tar.bz2 "https://developer.arm.com/-/media/Files/downloads/gnu-rm/10.3-2021.10/gcc-arm-none-eabi-10.3-2021.10-x86_64-linux.tar.bz2" && sudo mkdir /opt/gcc-arm-none-eabi && sudo tar xf gcc-arm-none-eabi.tar.bz2 --strip-components=1 -C /opt/gcc-arm-none-eabi
echo 'export PATH=$PATH:/opt/gcc-arm-none-eabi/bin' | sudo tee -a /etc/profile.d/gcc-arm-none-eabi.sh && source /etc/profile && arm-none-eabi-gcc --version && arm-none-eabi-g++ --version && rm -rf gcc-arm-none-eabi.tar.bz2
Install pico sdk
sudo git clone https://github.com/raspberrypi/pico-sdk.git /opt/pico-sdk && sudo git -C /opt/pico-sdk submodule update --init
Install BP5
sudo git clone https://github.com/DangerousPrototypes/BusPirate5-firmware.git bp5-main && cd bp5-main &&mkdir build && cd build && cmake .. && make
cd ~ && mkdir webhook && pip install virtualenv && pip install argparse && pip install python-dotenv && apt install python3.10-venv && python3.10 -m venv env && sudo apt install build-essential libssl-dev libffi-dev python3-dev && source env/bin/activate && pip3 install flask && pip3 install github_webhook && pip3 install requests && sudo iptables -A INPUT -p tcp --dport 80 -j ACCEPT && sudo apt-get install iptables-persistent
screen
python3 webhook.py
Exit screen:  Ctrl+A and then D
Here is the webhook we’re using to build all four Bus Pirate firmwares, package them and post them to this Discourse forum.
webhook.zip (3.8 KB)
python webhook --test
Optional test argument forces it to run a task instead of starting the webhook listener
  • A task is one repo branch
  • Tasks have 1 or more builds that compile firmware and produce one or more outputs
  • Builds have one or more make commands, and support %%GIT_COMMIT_HASH%% as a tag that is replaced by the current git short hash
  • Outputs have an optional zip_file_location property that shoves the _rev8 firmware into a folder called attic
  • Outputs are packaged with log files, and then posted to a discourse thread
  • API username, key and URL should be stored in a .env file (see sample.env)
  • If the git_pull_dir directory doesn’t exist, the script will attempt to clone and switch to the git_branch specified. This is so adding new branches is faster/automated.
It also has the dead simple class that posts new pull requests in the forum.
Latest PirateBot:
  • Create new topics for each pull request open and issue open action
  • Post replies to the correct topics (tracking github)
  • Send notice to the live chat box
  • Generally cleaner
Orphaned pull requests comments (without an existing topic) will be rejected, but issue comments will create a topic using the available issue data send by github.
The forum category for pull requests and issues is currently private while I do some testing.
webhook.zip (4.7 KB)
I just saw this topic and saw in the first post that you were using Vultr.
Does this work well for you?
I found them to be quite expensive in comparison. Yes, they offer their smallest instance for US$ 2.50, but it has so few ram that it is almost unusable in my experience. So I consider this more like a bait offer or loss leader thing.
Have a look here instead:
This is where I now host my VMs.
It’s just what I’ve been using. Super convenient, but really pricey for what you get. We have two monster AMD Ryzan servers with SSD drives in Germany that cost about EUR30/month, while the droplet running this forum is more than half that for single core/limited ram.
I will check this out the next time I spool up a server, thank you.
You probably should a) not include that sudo for that git clone, and b) install the clone in a specific user directory (it’s just “wherever I currently am”).
