Bus Pirate 电子 carry case
Screenshot_20240711_120513
A carry case for Bus Pirate and accessories is coming together amongst the other chaos. I’d like to do a two layer bag like this, but with more zipper compartments.
Design inspiration is the green canvas and yellow details from a traditional Chinese lineman’s electronics bag. This bag is great, and widely available for 11RMB (~$1.15). It was my daily carry ban in Shenzhen.
Manufacturers keep telling me that’s not waterproof, but it can definitely be treated with wax like an old tent, chore coat, or raw denim :wink:
Here is the first sample. We chose a canvas that’s the same color, but lighter in weight than the lineman’s bag.
  • The bias tape (wrapping around the edges) is the wrong color
  • I think they forgot to use the webbing material as a carry handle.
Two layers, both look like this inside. 3 small pockets and one big pocket.
  • Split the big pocket in two
  • Add additional half-height net pockets with elastic mouth (2 on one side, 3 on the other)
  • Add additional 2cm (?) elastic straps across the outside of everything for cables/etc
  • The interior was supposed to be high contrast, but they forgot.
media_20240905_145923_3542697340786110986
Net and inside fabric samples for rev 1.
I like the idea of an digital electronics field kit.
I have collected some tools for electronics field work. But this is currently focused more on the mechanical side, like pliers, soldering, shrink tubes, hotmelt glue and similar. Adding more digital-oriented tools would be welcome.
I have put my stuff into several of these military-style molle pouches, something like this: Molle Zakje Medische Emt Tactische Outdoor Noodpakket Camping Jacht Accessoires Utility Multi-Tool Kit Edc Tas - AliExpress 18
It works ok, but is missing smaller compartments that can be properly closed with zippers. It looks like your bag would solve this.
What I really like about the molle pouches is that you can easily fix several of them together with the molle and velcro straps. They then stay together quite well. This would be something I would suggest to add to your bag too. For example put several of these velcro straps on the outside of one side. This would allow to either to fix your bag to another one (or bigger backpack), or use the velcro straps to fix some bigger stuff to the outside, like a 100W USB-C power supply and it’s mains cable.
Great suggestions as always. A revision is in the works and I will try to work these in. The outside Velcro and straps is a great touch.
Hard to get a sense of scale without the BP in the photo. Would it fit in one of those top 3 pockets, or does it go down in the big one?
tool bag with stuff
Oh wow, that’s a lot bigger than I thought. But I can see the advantage once you’ve got a couple of planks, probes, etc.
I’ve been on the hunt for a case not larger than the BP5 itself. This is closest one I’ve found so far, was thinking I could laser-cut some foam for the bottom to hold the Pirate and quick connect adapter. That would still give me the top zippered compartment for USB cable and other assorted bits.
That being said, I’m certainly interested in adding the official case to the collection whenever it becomes available. :grinning:
First revision may start this week.
We’re pretty unhappy with the three zipper part. Instead, we’re going to move the zipper towards the edge and try a version with 3 pockets sealed by a single zipper. We came up with 4 layout styles, and one of each will go in the next prototype for dog-fooding.
Another thing is the net stuff. It’s nice to see through, but it catches on components and leads like crazy. The next one will use a solid material, just to test it out.
This came a while back but we haven’t had time to do much with it.
  • I like the inside color
  • Prefer solid to mesh, it doesn’t catch on pin legs
  • Not a fan of the divided-by-3 pockets, they feel cheap and breakable
This version is a bit thicker, and we wanted to try a meta zipper. The selection of 40mm metal zippers 0.5meters long is evidently not great, so our only option was black.
  • The plastic zipper actually feels/works a bit nicer than the metal
  • With the limited selection of colors, metal is probably also a bad idea
  • The increase in width is nice
  • The bias tape around the edges is the correct color, but I’m not sure I like it. It might look better with a properly colored plastic zipper
I’m going to load up all the Bus Pirate gear into it and dog food it for a few weeks.
I am curious what esd material and manufacturing would cost in the region to do something similiar to my pelican backpack.
The is a hard case fof the laptop with foam to customize the fit. But i was thinking hard shel, dividers, esd foam cutouts.
Then attach a bag made of other mater like the ones you are using, but for periferials, cords, chargers, etc.
I can imagine thos would not be cheap to have manufactured. Withouth the ivers we could divise a way to put grifinity into it and custome foam cutout or cut our own. I’m thinking dense foam many praducts use such as navigation imus and even the Pinecil soldering iron and tips.
Sorry, thinking while im typing makes fof lengthy messages. How do you colapse in the thread so i can tl;dr and expand to read the rest. I assume makeup.
This kind of hard sided case is super common. They usually come in orange and beige as well. All kinds of sizes, height, depths.
Then, you order a custom cut foam insert (ESD foam, I guess) to fit your stuff.
Some day I will use one to make a traveling Bus Pirate demo box, with devices under plexiglass on both sides, a big retro dial to select the active device, and a USB connector in the side.
[details="Summary"]
This text will be hidden
[/details]
This is how you fold text. There is also a option on the drop down menu from the gear icon.
Awesome thanks Ian. I hadnt gone looking yet. Should gave first. Much appreciated.
Heres my bag. They no longer sell this particular one.
17303067276598894974777373913153
Similiar to this scaled down and adjusted according to the orevious description.
And doesnt necessarily have to be custom. The precut pickout squares would work. But my mind was on something like this:
i bought some paragon gear when it was kickstarter, its now expensive and i dont see it anywhere. but it has molle straps and a folder with velcro.
