Here’s a fresh compile from ‘main’: “build rp2350 boards”
ci-buspirate-main-8dc73f1.zip
Build time: 102.76 seconds
Git pull log @8dc73f1:
Updating ed89fc5…8dc73f1
.github/workflows/build.yaml | 7 +++±–
1 file changed, 4 insertions(+), 3 deletions(-)
Here’s a fresh compile from ‘main’: “.gitignore update”
ci-buspirate-main-736c509.zip
Build time: 104.15 seconds
Git pull log @736c509:
Updating 8dc73f1…736c509
.gitignore | 3 +±
hacks/build_server.md | 10 +++±—
hacks/build_server_condensed.md | 4 ±-
readme.md | 55 +++++++++++++++++++++++++++++±----------
4 files changed, 49 insertions(+), 23 deletions(-)
Here’s a fresh compile from ‘main’: “Update show_port_info.ps1”
ci-buspirate-main-3f6505f.zip
Build time: 107.78 seconds
Git pull log @3f6505f:
Updating 736c509…3f6505f
hacks/show_port_info.ps1 | 20 ++++++++++++±------
1 file changed, 13 insertions(+), 7 deletions(-)
Here’s a fresh compile from ‘main’: “fix image command help display”
ci-buspirate-main-089e906.zip
Build time: 110.15 seconds
Git pull log @089e906:
Updating 3f6505f…089e906
src/commands/global/image.c | 2 ±
Here’s a fresh compile from ‘main’: “Dump sle4442 to flash.”
ci-buspirate-main-8c3556d.zip
Build time: 108.7 seconds
Git pull log @8c3556d:
Updating 089e906…8c3556d
src/commands/2wire/sle4442.c | 50 ++++++++++++++++++++++++++++++++++++++++++++
src/translation/base.h | 1 +
src/translation/bs-ba.h | 1 +
src/translation/en-us.h | 1 +
src/translation/en-us.json | 1 +
src/translation/it-it.h | 1 +
src/translation/pl-pl.h | 1 +
src/translation/zh-cn.h | 1 +
8 files changed, 57 insertions(+)
Here’s a fresh compile from ‘main’: “SLE4442 dump format description.”
ci-buspirate-main-212ac74.zip
Build time: 105.81 seconds
Git pull log @212ac74:
Updating 8c3556d…212ac74
src/commands/2wire/sle4442.c | 6 +++±-
1 file changed, 4 insertions(+), 2 deletions(-)
Here’s a fresh compile from ‘main’: “Translation was set before the configuration file was loaded.”
ci-buspirate-main-c3d9cb7.zip
Build time: 108.93 seconds
Git pull log @c3d9cb7:
Updating 212ac74…c3d9cb7
src/pirate.c | 4 +±-
Here’s a fresh compile from ‘main’: “Button press on start-up to skip loading configuration file.”
ci-buspirate-main-b092018.zip
Build time: 106.98 seconds
Git pull log @b092018:
Updating c3d9cb7…b092018
Here’s a fresh compile from ‘main’: "Revert “Button press on start-up to skip loading configuration file.”
This reverts commit b09201890590b39ff96666ba5491af75ebce2ddd."
ci-buspirate-main-9410a69.zip
Build time: 107.01 seconds
Git pull log @9410a69:
Updating b092018…9410a69
Here’s a fresh compile from ‘main’: “new global and mode command structs, fill in missing command info”
ci-buspirate-main-71de3a9.zip
Build time: 106.59 seconds
Git pull log @71de3a9:
Updating 9410a69…71de3a9
.clang-format_files | 4 ±
src/CMakeLists.txt | 3 ±
src/binmode/binio.c | 2 ±
src/binmode/binio_helpers.c | 2 ±
src/binmode/dirtyproto.c | 2 ±
src/binmode/fala.c | 4 ±
src/binmode/falaio.c | 2 ±
src/binmode/legacy4third.c | 2 ±
src/binmode/logicanalyzer.c | 2 ±
src/binmode/sump.c | 2 ±
src/command_attributes.h | 16 ------
src/command_struct.h | 43 ++++++++++++++++
src/commands.c | 102 +++++++++++++++++±------------------
src/commands.h | 2 ±
src/commands/1wire/demos.c | 22 +++++±-
src/commands/1wire/scan.c | 12 +++±
src/commands/2wire/sle4442.c | 47 ++++++++±-------
src/commands/global/a_auxio.c | 2 ±
src/commands/global/bug.c | 2 ±
src/commands/global/button_scr.c | 2 ±
src/commands/global/cls.c | 2 ±
src/commands/global/cmd_binmode.c | 2 ±
src/commands/global/cmd_convert.c | 3 ±
src/commands/global/cmd_mcu.c | 2 ±
src/commands/global/cmd_selftest.c | 2 ±
src/commands/global/disk.c | 2 ±
src/commands/global/dummy.c | 2 ±
src/commands/global/freq.c | 2 ±
src/commands/global/h_help.c | 2 ±
src/commands/global/i_info.c | 2 ±
src/commands/global/l_bitorder.c | 2 ±
src/commands/global/logic.c | 2 ±
src/commands/global/macro.c | 2 ±
src/commands/global/p_pullups.c | 2 ±
src/commands/global/pause.c | 2 ±
src/commands/global/pwm.c | 2 ±
src/commands/global/script.c | 2 ±
src/commands/global/smps.c | 2 ±
src/commands/global/tutorial.c | 2 ±
src/commands/global/v_adc.c | 2 ±
src/commands/global/w_psu.c | 2 ±
src/commands/hdplxuart/bridge.c | 2 ±
src/commands/i2c/demos.c | 51 +++++++++++++±----
src/commands/i2c/scan.c | 11 ++±
src/commands/spi/flash.c | 36 +++++++±----
src/commands/spi/sniff.c | 2 ±
src/commands/spi/spiflash.c | 2 ±
src/commands/uart/bridge.c | 2 ±
src/commands/uart/monitor.c | 10 +±-
src/commands/uart/nmea.c | 2 ±
src/commands/uart/simcard.c | 2 ±
src/display/default.c | 2 ±
src/display/scope.c | 2 ±
src/displays.c | 2 ±
src/mode/binloopback.c | 11 +±-
src/mode/binloopback.h | 2 ±
src/mode/dio.c | 12 ++±-
src/mode/dio.h | 2 ±
src/mode/dummy1.c | 12 ++±-
src/mode/dummy1.h | 2 ±
src/mode/hiz.c | 23 +++±----
src/mode/hiz.h | 2 ±
src/mode/hw1wire.c | 23 ++++±—
src/mode/hw1wire.h | 2 ±
src/mode/hw2wire.c | 12 ++±-
src/mode/hw2wire.h | 2 ±
src/mode/hwhduart.c | 21 +++±—
src/mode/hwhduart.h | 2 ±
src/mode/hwi2c.c | 30 +++++++±–
src/mode/hwi2c.h | 2 ±
src/mode/hwled.c | 12 ++±-
src/mode/hwled.h | 2 ±
src/mode/hwspi.c | 18 +++±–
src/mode/hwspi.h | 2 ±
src/mode/hwuart.c | 29 +++++±----
src/mode/hwuart.h | 2 ±
src/mode/infrared.c | 12 ++±-
src/mode/infrared.h | 2 ±
src/modes.c | 2 ±
src/modes.h | 2 ±
src/opt_args.h | 18 -------
src/pirate.c | 2 ±
src/pirate/amux.c | 2 ±
src/pirate/hwi2c_pio.c | 2 ±
src/pirate/hwuart_pio.c | 2 ±
src/pirate/shift.c | 2 ±
src/pirate/storage.c | 2 ±
src/syntax.c | 3 ±
src/system_config.c | 2 ±
src/system_monitor.c | 2 ±
src/toolbars/logic_bar.c | 2 ±
src/translation/base.h | 3 ++
src/translation/bs-ba.h | 3 ++
src/translation/en-us.h | 3 ++
src/translation/en-us.json | 5 ±
src/translation/it-it.h | 3 ++
src/translation/pl-pl.h | 3 ++
src/translation/zh-cn.h | 3 ++
src/ui/ui_button.c | 2 ±
src/ui/ui_command.h | 20 --------
src/ui/ui_config.c | 2 ±
src/ui/ui_display.c | 3 ±
src/ui/ui_format.c | 3 ±
src/ui/ui_help.c | 8 ±-
src/ui/ui_help.h | 4 ±
src/ui/ui_info.c | 2 ±
src/ui/ui_init.c | 2 ±
src/ui/ui_lcd.c | 2 ±
src/ui/ui_mode.c | 2 ±
src/ui/ui_parse.c | 2 ±
src/ui/ui_process.c | 25 ++++++±-
src/ui/ui_prompt.c | 2 ±
src/ui/ui_statusbar.c | 2 ±
src/wavegen.c | 2 ±
115 files changed, 483 insertions(+), 351 deletions(-)
delete mode 100644 src/command_attributes.h
create mode 100644 src/command_struct.h
delete mode 100644 src/opt_args.h
delete mode 100644 src/ui/ui_command.h
Here’s a fresh compile from ‘main’: “Add comments to command structs”
ci-buspirate-main-62ce168.zip
Build time: 104.56 seconds
Git pull log @62ce168:
Updating 71de3a9…62ce168
src/binmode/fala.c | 12 ++++++++±–
src/binmode/falaio.c | 3 +++
src/command_struct.h | 17 +++++++±--------
src/mode/dio.c | 30 +++++++++++++++±-------------
src/mode/hwled.c | 36 +++++++++++++++++++++++++±---------
src/mode/hwled.h | 1 +
src/modes.c | 1 +
7 files changed, 64 insertions(+), 36 deletions(-)
Here’s a fresh compile from ‘main’: “Binmode save settings, show active binmode in i menu and binmode -h display”
ci-buspirate-main-b08ba61.zip
Build time: 111.34 seconds
Git pull log @b08ba61:
Updating 62ce168…b08ba61
src/binmode/binmodes.c | 23 +++++++++++++++++++++++
src/binmode/binmodes.h | 3 +++
src/binmode/fala.c | 22 ±--------------------
src/binmode/falaio.c | 28 ++++++++++++++++++++++++++++
src/binmode/falaio.h | 1 +
src/commands/global/cmd_binmode.c | 27 ++++++++++++++++++++++++±-
src/commands/global/cmd_binmode.h | 2 ±
src/commands/global/i_info.c | 5 +++++
src/pirate.c | 2 ±
9 files changed, 88 insertions(+), 25 deletions(-)
Here’s a fresh compile from ‘main’: “force complete LCD redraw after screensaver”
ci-buspirate-main-d031108.zip
Build time: 109.22 seconds
Git pull log @d031108:
Updating b08ba61…d031108
src/ui/ui_lcd.c | 2 ++
Here’s a fresh compile from ‘main’: “Review of code prior to its removal”
ci-buspirate-main-664f569.zip
Build time: 106.57 seconds
Git pull log @664f569:
Updating d031108…664f569
src/usb_descriptors.c | 21 ++++++++++++±-------
1 file changed, 13 insertions(+), 8 deletions(-)
This firmware works, but I need to select the second com port opened on Win11.
As in, the higher port is the terminal? I also note port swapping.
Or do you mean the second port doesn’t work on win11?
Yes. The high port is the terminal. If you connect to the lower port, it seems you disable the terminal power until the unit is power cycled.
Ah thank you so much, have you upgraded to the latest firmware?
The default mode is SUMP logic analyzer. It should not block the terminal. Some binary modes do lock the terminal though, but that cannot be saved as default.
Yes. That is with the latest firmware. It worked normally with the as-shipped firmware (quite old). I had not used it yet and decided to try it today. The first step was firmware upgrade. Tried a couple other versions as well before I found an old post and decided to try the second port. When I found that worked, I went back to the newest release.
@pmhupman Try this script next time:
