:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-4e4d3a3.zip :arrow_down: :arrow_down: :arrow_down:
WARNING: New flash driver in use. It should be backwards compatible, but BACKUP THE INTERNAL STORAGE prior to upgrade if you value the contents.
Here’s a fresh compile from ‘main’:
  • fafc89b: webhook fixed files
  • 4e4d3a3: for for 1wire and spi eeprom related to GUI implementation:
Build time: 163.16 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-073ac1e.zip :arrow_down: :arrow_down: :arrow_down:
  • 040ebff: Fix GPIO override arguments in bio_init
  • 073ac1e: Merge pull request #330 from MarioGt-02/codex/fix-bio-gpio-overrides
Build time: 161.77 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-4d2b206.zip :arrow_down: :arrow_down: :arrow_down:
  • 94a7eda: hwi2c: end mode setup with a STOP so the first transaction is ACKed
  • 4d2b206: Merge pull request #331 from FerriteGiant/hwi2c-stop-after-setup
Build time: 162.67 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-2f0b0e2.zip :arrow_down: :arrow_down: :arrow_down:
  • 6c4ef83: bpio: return an error for oversized reads instead of crashing
  • 2f0b0e2: Merge pull request #332 from FerriteGiant/bpio-read-size-error
Build time: 161.59 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-5fc331e.zip :arrow_down: :arrow_down: :arrow_down:
  • a3c9128: hwspi: drive CS to its idle level before SCK at mode setup
  • ae6769a: Merge pull request #333 from FerriteGiant/hwspi-drive-cs-before-sclk
Build time: 164.7 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-86ee9e7.zip :arrow_down: :arrow_down: :arrow_down:
  • 86ee9e7: USB/PS2 Keyboard sniffing modes. Changed USB->USBKB to be consistent with upcoming USBPD mode.
Build time: 173.91 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-694b4de.zip :arrow_down: :arrow_down: :arrow_down:
  • 694b4de: psu: poll the fuse during enable and report success after 50 ms
Build time: 164.08 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-679dfa2.zip :arrow_down: :arrow_down: :arrow_down:
  • 679dfa2: shift: reuse SPI clock dividers instead of recomputing them per write
Build time: 164.9 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-dc62c73.zip :arrow_down: :arrow_down: :arrow_down:
  • b9b5afd: core1: keep servicing USB during the voltage sweep and LCD redraws
  • d468cd6: psu: redraw only the VOUT label when the supply starts
  • dc62c73: lcd: send glyph pixels in batches instead of one SPI call per pixel
Build time: 163.03 seconds | compare
:arrow_down: :arrow_down: :arrow_down: ci-buspirate-main-e9cb31e.zip :arrow_down: :arrow_down: :arrow_down:
  • e9cb31e: bpio: sweep the analog mux once per status request
Build time: 163.55 seconds | compare
