Bus pirate Hduart newbie
Hi guys new to the bus pirate so apologies. I have been using an arduino to sniff data of a refrigeration controller which is using 1 wire for tx/rx and ground, I have collected a lot of data but I can’t send any commands. So I have just bought a bp 5v10 put it into hduart but every time I try to send any hex it says invalid command I’ve tried the following
HDUART>>0x64 0x6E 0x00 0x67 0x00 0x64 0x51 0xC2
HDUART>[0x64 0x6E 0x00 0x67 0x00 0x64 0x51 0xC2]
Still invalid command any ideas please
Hey @Seadanzig,
Thank so much for the bug report!
HDUART> >0x64 0x6E 0x00 0x67 0x00 0x64 0x51 0xC2
TX: 0x64 0x6E 0x00 0x67 0x00 0x64 0x51 0xC2
HDUART>
I tried that sequence with the latest firmware and get this output.
Can you post the mode setup and the invalid command output in full? I’ll have a look and try to replicate the issue.
Hi Ian thanks for this I did it in your format and have no issues. As I said I’m new to the business pirate looking forward to getting to grips with it
That’s odd … maybe I’m just not seeing it … where is the difference between what Ian said to try, and what you said you’d already tried? The characters look the same to me…
I didn’t have a space between > and > it worked for for strange
