In earlier code on BP5, I could call up a repeated start as follows:
[ 0xc0 0x02 0x53 0x00 0x20
[ 0xc0 0x07 0x00 ]
Note no STOP on the first line.
This does not work on the subject configuration:
I2C> [ 0xc0 0x02 0x53 0x00 0x20
I2C START
TX: 0xC0 ACK 0x02 ACK 0x53 ACK 0x00 ACK 0x20 ACK
I2C> [ 0xc0 0x07 0x00 ]
I2C START
TX: 0xC0 NACK (I2C bus error)
I2C>
It works if I put a stop on the first line, but I should be able to use the repeated START so the bus is not released.
Owen
Here is a log of this working on BP5 with earlier firmware (see log).
HiZ> m
Mode selection
1. HiZ
2. 1-WIRE
3. UART
4. HDPLXUART
5. I2C
6. SPI
7. 2WIRE
8. LED
x. Exit
Mode > 5
Use previous settings?
I2C speed: 100kHz
y/n, x to exit (Y) > n
I2C speed
1kHz to 1000kHz
x. Exit
kHz (400kHz*) > 100k
Mode: I2C
I2C> W
Power supply
Volts (0.80V-5.00V)
Maximum current (0mA-500mA), <enter> for none
- SDA SCL - - - - - - GND
3.30V requested, closest value: 3.30V 0.0V 0.0V 0.0V 0.0V GND
100.0mA requested, closest value: 100.0mA
Power supply:Enabled
Vreg output: 3.3V, Vref/Vout pin: 3.3V, Current: 41.7mA
I2C> P
Pull-up resistors: Enabled (10K ohms @ 3.3V)
I2C> i
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
Bus Pirate 5 REV10
Firmware main branch (2024-04-10T12:30:36Z)
S/N: 2145260B134063E4
https://BusPirate.com/
Configuration file: Loaded
Available modes: HiZ 1-WIRE UART HDPLXUART I2C SPI 2WIRE LED
Active mode: HWI2C (speed)=(0)
Display format: Auto
Pull-up resistors: ON
Power supply: ON (3.3V/3.29V)
Current limit: OK (33.6mA/100.0mA)
Frequency generators: OFF
Vout: 3.29V/100.0mA max | Pull-ups: ON |
I2C START
038.3mA SDA SCL - - - - - - GND
3.3V [ 0xc0 0x07 0x00 3.2V 3.3V 3.2V 3.3V 3.3V 3.2V GND
I2C START
031.9mA0 ACK 0x07 ACK 0x00 ACK
3.3V [ 0xc0 0x0f 0x00 0x0c 0x8c 0x8c 0x8c 0x8c 0x8c 0x8c 0x8c 3.2V
I2C START
TX: 0xC0 ACK 0x0F ACK 0x00 ACK 0x0C ACK 0x8C ACK 0x8C ACK 0x8C ACK 0x8C ACK
007.0mAC ACK 0x8C ACK 0x8C ACK
3.3V [ 0xc0 0x1a 0xa4 0x3c 0x00 0x0f 0xff 0xb9 0x55 0xbc3.3V 3.3V
I2C START
TX: 0xC0 ACK 0x1A ACK 0xA4 ACK 0x3C ACK 0x00 ACK 0x0F ACK 0xFF ACK 0xB9 ACK
038.3mA5 ACK 0xBC ACK
3.3V [ 0xc0 0x2a 0x00 0x02 0x01 0x0f 0x40 0x00 0x00 0x003.3V 3.3V
I2C START
TX: 0xC0 ACK 0x2A ACK 0x00 ACK 0x02 ACK 0x01 ACK 0x0F ACK 0x40 ACK 0x00 ACK
035.6mA0 ACK 0x00 ACK
3.3V [ 0xc0 0x5a 0x00 0x003V 3.3V 3.3V 3.3V 3.3V 3.2V
I2C START
030.5mA0 ACK 0x5A ACK 0x00 ACK 0x00 ACK
3.3V [ 0xc0 0x95 0x00 0x00 0x00 0x00 0x00 0x00 0x00V 3.3V 3.3V
I2C START
TX: 0xC0 ACK 0x95 ACK 0x00 ACK 0x00 ACK 0x00 ACK 0x00 ACK 0x00 ACK 0x00 ACK
006.5mA0 ACK
3.3V [ 0xc0 0xa2 0x00 0x00 0x00 0x00 3.3V 3.3V 3.2V 3.3V
I2C START
024.4mA0 ACK 0xA2 ACK 0x00 ACK 0x00 ACK 0x00 ACK 0x00 ACK
3.3V [ 0xc0 0xb7 0x92 ] 3.3V 3.3V 3.3V 3.2V 3.3V 3.3V
I2C START
TX: 0xC0 ACK 0xB7 ACK 0x92 ACK
010.4mAP
3.3V p 3.3V 3.3V 3.3V 3.2V 3.3V 3.2V 3.3V 3.3V
Pull-up resistors: Disabled
I2C> w
Power supply: Disabled
I2C> i
Bus Pirate 5 REV10
Pull-up resistors: OFF
ian
October 28, 2024, 9:30am
3
Thank you so much for providing the i output. I can browse the history to see where this might have started.
However, I have a mostly finished rewrite of the I2C PIO program that should be a lot more flexible. I’ll try to get that pushed today, but more realistically tomorrow. I will check the repeated starts as well.
ian
October 30, 2024, 10:37am
4
Hello,
There should be an auto build momentarily with a completely reworked I2C mode.
Using SI7021 and reading serial number, repeated start seems to work ok. That doesn’t mean it’s fixed for all cases, but I’m hopeful
This sequence worked earlier on BP5 as noted, but it does not work on 305f709.
I2C> i
Bus Pirate 6
Firmware main branch @ 305f709 (2024-10-30T10:54:09Z)
RP2350B with 512KB RAM, 128Mbit FLASH
S/N: 2EAE869F8943242C
Available modes: HiZ 1-WIRE UART HDUART I2C SPI 2WIRE DIO LED INFRARED
Active mode: I2C
I2C speed: 100kHz
Clock stretching: OFF
Current limit: OK (25.8mA/100.0mA)
I2C START
I2C START
TX: 0xC0 NACK 0x07 NACK 0x00 NACK
I2C> [ 0xc0 0x0f 0x00 0x0c 0x8c 0x8c 0x8c 0x8c 0x8c 0x8c 0x8c
I2C START
TX: 0xC0 NACK 0x0F NACK 0x00 NACK 0x0C NACK 0x8C NACK 0x8C NACK 0x8C NACK 0x8C NACK
I2C> [ 0xc0 0x1a 0xb5 0xa7 0x00 0x0f 0xf3 0x00 0x24 0xfb
I2C START
TX: 0xC0 NACK 0x1A NACK 0xB5 NACK 0xA7 NACK 0x00 NACK 0x0F NACK 0xF3 NACK 0x00 NACK
0x24 NACK 0xFB NACK
I2C> [ 0xc0 0x2a 0x00 0x04 0x00 0x2a 0xe0 0x00 0x00 0x00
I2C START
TX: 0xC0 NACK 0x2A NACK 0x00 NACK 0x04 NACK 0x00 NACK 0x2A NACK 0xE0 NACK 0x00 NACK
0x00 NACK 0x00 NACK
I2C> [ 0xc0 0x5a 0x00 0x00
I2C START
TX: 0xC0 NACK 0x5A NACK 0x00 NACK 0x00 NACK
I2C> [ 0xc0 0x95 0x00 0x00 0x00 0x00 0x00 0x00 0x00
I2C START
TX: 0xC0 NACK 0x95 NACK 0x00 NACK 0x00 NACK 0x00 NACK 0x00 NACK 0x00 NACK 0x00 NACK
0x00 NACK
I2C> [ 0xc0 0xa2 0x00 0x00 0x00 0x00
I2C START
TX: 0xC0 NACK 0xA2 NACK 0x00 NACK 0x00 NACK 0x00 NACK 0x00 NACK
I2C> [ 0xc0 0xb7 0x92 ]
I2C START
TX: 0xC0 NACK 0xB7 NACK 0x92 NACK
I2C STOP
I2C>
It does work if I do not use repeated START:
I2C> i
Bus Pirate 6
Active mode: I2C
I2C speed: 100kHz
Current limit: OK (30.6mA/100.0mA)
I2C> [ 0xc0 0x02 0x53 0x00 0x20 ]
I2C START
I2C STOP
I2C START
TX: 0xC0 ACK 0x07 ACK 0x00 ACK
I2C STOP
I2C> [ 0xc0 0x0f 0x00 0x0c 0x8c 0x8c 0x8c 0x8c 0x8c 0x8c 0x8c ]
I2C START
I2C STOP
I2C> [ 0xc0 0x1a 0xb5 0xa7 0x00 0x0f 0xf3 0x00 0x24 0xfb ]
I2C START
TX: 0xC0 ACK 0x1A ACK 0xB5 ACK 0xA7 ACK 0x00 ACK 0x0F ACK 0xF3 ACK 0x00 ACK
0x24 ACK 0xFB ACK
I2C STOP
I2C> [ 0xc0 0x2a 0x00 0x04 0x00 0x2a 0xe0 0x00 0x00 0x00 ]
I2C START
TX: 0xC0 ACK 0x2A ACK 0x00 ACK 0x04 ACK 0x00 ACK 0x2A ACK 0xE0 ACK 0x00 ACK
0x00 ACK 0x00 ACK
I2C STOP
I2C> [ 0xc0 0x5a 0x00 0x00 ]
I2C START
TX: 0xC0 ACK 0x5A ACK 0x00 ACK 0x00 ACK
I2C STOP
I2C> [ 0xc0 0x95 0x00 0x00 0x00 0x00 0x00 0x00 0x00 ]
I2C START
0x00 ACK
I2C STOP
I2C> [ 0xc0 0xa2 0x00 0x00 0x00 0x00 ]
I2C START
TX: 0xC0 ACK 0xA2 ACK 0x00 ACK 0x00 ACK 0x00 ACK 0x00 ACK
I2C STOP
I2C START
I2C STOP
I2C>
Owen
ian
October 30, 2024, 12:16pm
7
Thank you so much for testing.
In a moment there should be a new firmware with explicit start/repeated start tracking. A repeat start sequence is sent instead of relying on the PIO program to sort it out.
Repeat starts will be sent until a stop is sent.
Hi Ian,
That worked, thanks:
I2C> i
Bus Pirate 6
Firmware main branch @ fdd4e34 (2024-10-30T16:25:38Z)
Active mode: I2C
I2C speed: 100 kHz
Current limit: OK (27.8mA/100.0mA)
I2C START
I2C REPEATED START
I2C REPEATED START
I2C REPEATED START
0x24 ACK 0xFB ACK
I2C REPEATED START
0x00 ACK 0x00 ACK
I2C REPEATED START
I2C REPEATED START
0x00 ACK
I2C REPEATED START
I2C REPEATED START
I2C STOP
I2C>
Owen
ian
October 30, 2024, 6:43pm
9
Yeah! Thank you so much for the bug report and test result follow ups. I’m.glad it’s working.
Just let me know of there’s anything else.
Cheers,
Ian
Small issue, see the corrupted prompt for clock stretching:
I2C> m 5
I2C speed: 100 kHz
I2C speed
1kHz to 1000kHz
x. Exit
kHz (400kHz*) > 100
Clock stretching
1. OFF
2. ON
x. Exit
ð©?ð© (0) > 1
Mode: I2C
I2C>
ian
October 30, 2024, 6:50pm
11
Thank you I will push a fix.
ian
October 31, 2024, 11:09am
12
Thanks again for the bug reports!
I pushed a fix. This was a little bug that crept in during the recent rework of the I2C PIO program. I think it’s good to go now. Happy Bus Pirate-ing!
Thanks.
Bus Pirate 6
Firmware main branch @ 8e51eb6 (2024-10-31T11:09:12Z)
Works fine now.
Owen
