Just got my BP5, pulled the repo, built, and programmed it with the latest FW. My question regards the status bar at the bottom of the screen. When it pops up, it has the appearance of two (or three?) rows at the bottom of the screen that are intended to remain in place, while the rest of the screen rows scroll up as normal. In fact, I’m pretty sure I remember this kind of pane separation being defined in the VT100 codes, if not the ANSI escape codes as well (yeah, I’m that old).
But, in the few cases I’ve tried, using screen or with a separate serial terminal emulator program, the status bars do not stay put. They roll up the screen with other subsequent commands. This could easily by a terminal setup problem on my end, but before I dive off the deep end testing that, I wanted to make sure I understood HOW the status bars are supposed to behave.
