Doc update: using serial terminal on Linux
My favorite is GNU screen, but there are others.
It’s as easy as
$ screen /dev/ttyACM0 115200,8n1
where ACM0 is the name of your serial device (if unsure, check dmesg output) ; you can now enter your commands.
To exit, type (with default screen config) ctrl+a, shift+k then y.
Thank you! I’m in the process of updating all the docs and I’ll include this.
To add to the above I found this post particularly useful for the BP under Linux (paricularly the config file settings):
My BusPirateSetup.sh script in the repo (in the hacks folder) asks the user which terminal emulator they want to use, and sets up a config file that BusPirate.sh will then use.
It asks the user which one to use and gives a choice of:
  • minicom
  • screen
  • tio
It correctly sets up the arguments to call the terminal emulator. It also includes the tio options to make backspace work properly.
Added this to the updated docs, thank you.
