hey i’m getting this error when trying to flash in binmode using flashrom. this is my first time using the device, i’m an intermediate novice and could use some direction if you have a moment please. thank you! here are my commands:
SPI> i
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device m
ay not cause harmful interference, and (2) this device must accept any interference received, including interference that m
ay cause undesired operation.
Bus Pirate 5 REV10
https://BusPirate.com/
Firmware main branch @ 7c08a5d (Feb 6 2025 14:47:19)
S/N: 2C19535F68A863E4
Configuration file: Loaded
Active binmode: SUMP logic analyzer
Available modes: HiZ 1-WIRE UART HDUART I2C SPI 2WIRE 3WIRE DIO LED INFRARED JTAG
Active mode: SPI
SPI speed: 1000 kHz
Data bits: 8
Clock polarity: Idle LOW
Clock phase: LEADING edge
Chip select: Active LOW (/CS)
Display format: Auto
Pull-up resistors: ON
Power supply: ON (1.7V/1.79V)
Current limit: OK (7.4mA/50.0mA)
Frequency generators: OFF
SPI> binmode
Select binary mode
- SUMP logic analyzer
- Binmode test framework
- Arduino CH32V003 SWIO
- Follow along logic analyzer
- Legacy Binary Mode for Flashrom and AVRdude (EXPERIMENTAL)
- IRMAN IR decoder (LIRC, etc)
- AIR capture (AnalysIR, etc)
x. Exit
5
Binmode selected: Legacy Binary Mode for Flashrom and AVRdude (EXPERIMENTAL)
Binmode active. Terminal locked
SPI>
Set OUTPUT HOLD(IO2) & WP(IO3) pins? (no=INPUT)
y/n (Y) > Y
Set HOLD HIGH? (no=LOW)
y/n (Y) > Y
Set WP HIGH? (no=LOW)
y/n (Y) > Y
Power supply
Volts (0.80V-5.00V)
x to exit (3.30) > 1.8
Maximum current (0mA-500mA), for none
x to exit (none) > 50
Done! Just execute flashrom or avrdude using the binary com port
assertion “false” failed: file “/root/bp5-main/src/usb_rx.c”, line 101, function: tud_cdc_rx_cb
flashrom --programmer buspirate_spi:dev=/dev/ttyACM1 --chip MX25U12835F --write Image_UEFI_UEFI_image.rom --verbose
flashrom v1.2 on Linux 6.8.0-52-generic (x86_64)
flashrom is free software, get the source code at https://flashrom.org
flashrom was built with libpci 3.7.0, GCC 11.2.0, little endian
Command line (7 args): flashrom --programmer buspirate_spi:dev=/dev/ttyACM1 --chip MX25U12835F --write Image_UEFI_UEFI_image.rom --verbose
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Initializing buspirate_spi programmer
Detected Bus Pirate hardware 2.5
Detected Bus Pirate firmware 7.1
Using SPI command set v2.
SPI speed is 8MHz
Raw bitbang mode version 1
Raw SPI mode version 1
The following protocols are supported: SPI.
Probing for Macronix MX25U12835F, 16384 kB: probe_spi_rdid_generic: id1 0xc2, id2 0x2538
Found Macronix flash chip “MX25U12835F” (16384 kB, SPI) on buspirate_spi.
Chip status register is 0x00.
Chip status register: Status Register Write Disable (SRWD, SRP, …) is not set
Chip status register: Bit 6 is not set
Chip status register: Block Protect 3 (BP3) is not set
Chip status register: Block Protect 2 (BP2) is not set
Chip status register: Block Protect 1 (BP1) is not set
Chip status register: Block Protect 0 (BP0) is not set
Chip status register: Write Enable Latch (WEL) is not set
Chip status register: Write In Progress (WIP/BUSY) is not set
This chip may contain one-time programmable memory. flashrom cannot read
and may never be able to write it, hence it may not be able to completely
clone the contents of this chip (see man page for details).
Reading old flash chip contents… done.
Erasing and writing flash chip… Trying erase function 0… 0x000000-0x000fff:S, 0x001000-0x001fff:S, 0x002000-0x002fff:S, 0x003000-0x003fff:S, 0x004000-0x004fff:S, 0x005000-0x005fff:S, 0x006000-0x006fff:S, 0x007000-0x007fff:S, 0x008000-0x008fff:S, 0x009000-0x009fff:S, 0x00a000-0x00afff:S, 0x00b000-0x00bfff:S, 0x00c000-0x00cfff:S, 0x00d000-0x00dfff:S, 0x00e000-0x00efff:S, 0x00f000-0x00ffff:S, 0x010000-0x010fff:S, 0x011000-0x011fff:S, 0x012000-0x012fff:S, 0x013000-0x013fff:S, 0x014000-0x014fff:S, 0x015000-0x015fff:S, 0x016000-0x016fff:S, 0x017000-0x017fff:S, 0x018000-0x018fff:S, 0x019000-0x019fff:S, 0x01a000-0x01afff:S, 0x01b000-0x01bfff:S, 0x01c000-0x01cfff:S, 0x01d000-0x01dfff:S, 0x01e000-0x01efff:S, 0x01f000-0x01ffff:S, 0x020000-0x020fff:S, 0x021000-0x021fff:S, 0x022000-0x022fff:S, 0x023000-0x023fff:S, 0x024000-0x024fff:S, 0x025000-0x025fff:S, 0x026000-0x026fff:S, 0x027000-0x027fff:S, 0x028000-0x028fff:S, 0x029000-0x029fff:S, 0x02a000-0x02afff:S, 0x02b000-0x02bfff:S, 0x02c000-0x02cfff:S, 0x02d000-0x02dfff:S, 0x02e000-0x02efff:S, 0x02f000-0x02ffff:S, 0x030000-0x030fff:S, 0x031000-0x031fff:S, 0x032000-0x032fff:S, 0x033000-0x033fff:S, 0x034000-0x034fff:S, 0x035000-0x035fff:S, 0x036000-0x036fff:S, 0x037000-0x037fff:S, 0x038000-0x038fff:S, 0x039000-0x039fff:S, 0x03a000-0x03afff:S, 0x03b000-0x03bfff:S, 0x03c000-0x03cfff:S, 0x03d000-0x03dfff:S, 0x03e000-0x03efff:S, 0x03f000-0x03ffff:S, 0x040000-0x040fff:S, 0x041000-0x041fff:S, 0x042000-0x042fff:S, 0x043000-0x043fff:S, 0x044000-0x044fff:S, 0x045000-0x045fff:S, 0x046000-0x046fff:S, 0x047000-0x047fff:S, 0x048000-0x048fff:S, 0x049000-0x049fff:S, 0x04a000-0x04afff:S, 0x04b000-0x04bfff:S, 0x04c000-0x04cfff:S, 0x04d000-0x04dfff:S, 0x04e000-0x04efff:S, 0x04f000-0x04ffff:S, 0x050000-0x050fff:S, 0x051000-0x051fff:S, 0x052000-0x052fff:S, 0x053000-0x053fff:S, 0x054000-0x054fff:S, 0x055000-0x055fff:S, 0x056000-0x056fff:S, 0x057000-0x057fff:S, 0x058000-0x058fff:S, 0x059000-0x059fff:S, 0x05a000-0x05afff:S, 0x05b000-0x05bfff:S, 0x05c000-0x05cfff:S, 0x05d000-0x05dfff:S, 0x05e000-0x05efff:S, 0x05f000-0x05ffff:S, 0x060000-0x060fff:S, 0x061000-0x061fff:S, 0x062000-0x062fff:S, 0x063000-0x063fff:S, 0x064000-0x064fff:S, 0x065000-0x065fff:S, 0x066000-0x066fff:S, 0x067000-0x067fff:S, 0x068000-0x068fff:S, 0x069000-0x069fff:S, 0x06a000-0x06afff:S, 0x06b000-0x06bfff:S, 0x06c000-0x06cfff:S, 0x06d000-0x06dfff:S, 0x06e000-0x06efff:S, 0x06f000-0x06ffff:S, 0x070000-0x070fff:S, 0x071000-0x071fff:S, 0x072000-0x072fff:S, 0x073000-0x073fff:S, 0x074000-0x074fff:S, 0x075000-0x075fff:S, 0x076000-0x076fff:S, 0x077000-0x077fff:S, 0x078000-0x078fff:S, 0x079000-0x079fff:S, 0x07a000-0x07afff:S, 0x07b000-0x07bfff:S, 0x07c000-0x07cfff:S, 0x07d000-0x07dfff:S, 0x07e000-0x07efff:S, 0x07f000-0x07ffff:S, 0x080000-0x080fff:S, 0x081000-0x081fff:S, 0x082000-0x082fff:S, 0x083000-0x083fff:S, 0x084000-0x084fff:S, 0x085000-0x085fff:S, 0x086000-0x086fff:S, 0x087000-0x087fff:S, 0x088000-0x088fff:S, 0x089000-0x089fff:S, 0x08a000-0x08afff:S, 0x08b000-0x08bfff:S, 0x08c000-0x08cfff:S, 0x08d000-0x08dfff:S, 0x08e000-0x08efff:S, 0x08f000-0x08ffff:S, 0x090000-0x090fff:S, 0x091000-0x091fff:S, 0x092000-0x092fff:S, 0x093000-0x093fff:S, 0x094000-0x094fff:S, 0x095000-0x095fff:S, 0x096000-0x096fff:S, 0x097000-0x097fff:S, 0x098000-0x098fff:S, 0x099000-0x099fff:S, 0x09a000-0x09afff:S, 0x09b000-0x09bfff:S, 0x09c000-0x09cfff:S, 0x09d000-0x09dfff:S, 0x09e000-0x09efff:S, 0x09f000-0x09ffff:S, 0x0a0000-0x0a0fff:S, 0x0a1000-0x0a1fff:S, 0x0a2000-0x0a2fff:S, 0x0a3000-0x0a3fff:S, 0x0a4000-0x0a4fff:S, 0x0a5000-0x0a5fff:S, 0x0a6000-0x0a6fff:S, 0x0a7000-0x0a7fff:S, 0x0a8000-0x0a8fff:S, 0x0a9000-0x0a9fff:S, 0x0aa000-0x0aafff:S, 0x0ab000-0x0abfff:S, 0x0ac000-0x0acfff:S, 0x0ad000-0x0adfff:S, 0x0ae000-0x0aefff:S, 0x0af000-0x0affff:S, 0x0b0000-0x0b0fff:S, 0x0b1000-0x0b1fff:S, 0x0b2000-0x0b2fff:S, 0x0b3000-0x0b3fff:S, 0x0b4000-0x0b4fff:S, 0x0b5000-0x0b5fff:S, 0x0b6000-0x0b6fff:S, 0x0b7000-0x0b7fff:S, 0x0b8000-0x0b8fff:S, 0x0b9000-0x0b9fff:S, 0x0ba000-0x0bafff:S, 0x0bb000-0x0bbfff:S, 0x0bc000-0x0bcfff:S, 0x0bd000-0x0bdfff:S, 0x0be000-0x0befff:S, 0x0bf000-0x0bffff:S, 0x0c0000-0x0c0fff:S, 0x0c1000-0x0c1fff:S, 0x0c2000-0x0c2fff:S, 0x0c3000-0x0c3fff:S, 0x0c4000-0x0c4fff:S, 0x0c5000-0x0c5fff:S, 0x0c6000-0x0c6fff:S, 0x0c7000-0x0c7fff:S, 0x0c8000-0x0c8fff:S, 0x0c9000-0x0c9fff:S, 0x0ca000-0x0cafff:S, 0x0cb000-0x0cbfff:S, 0x0cc000-0x0ccfff:S, 0x0cd000-0x0cdfff:S, 0x0ce000-0x0cefff:S, 0x0cf000-0x0cffff:S, 0x0d0000-0x0d0fff:S, 0x0d1000-0x0d1fff:S, 0x0d2000-0x0d2fff:S, 0x0d3000-0x0d3fff:S, 0x0d4000-0x0d4fff:S, 0x0d5000-0x0d5fff:S, 0x0d6000-0x0d6fff:S, 0x0d7000-0x0d7fff:S, 0x0d8000-0x0d8fff:S, 0x0d9000-0x0d9fff:S, 0x0da000-0x0dafff:S, 0x0db000-0x0dbfff:S, 0x0dc000-0x0dcfff:S, 0x0dd000-0x0ddfff:S, 0x0de000-0x0defff:S, 0x0df000-0x0dffff:S, 0x0e0000-0x0e0fff:S, 0x0e1000-0x0e1fff:S, 0x0e2000-0x0e2fff:S, 0x0e3000-0x0e3fff:S, 0x0e4000-0x0e4fff:S, 0x0e5000-0x0e5fff:S, 0x0e6000-0x0e6fff:S, 0x0e7000-0x0e7fff:S, 0x0e8000-0x0e8fff:S, 0x0e9000-0x0e9fff:S, 0x0ea000-0x0eafff:S, 0x0eb000-0x0ebfff:S, 0x0ec000-0x0ecfff:S, 0x0ed000-0x0edfff:S, 0x0ee000-0x0eefff:S, 0x0ef000-0x0effff:S, 0x0f0000-0x0f0fff:S, 0x0f1000-0x0f1fff:S, 0x0f2000-0x0f2fff:S, 0x0f3000-0x0f3fff:S, 0x0f4000-0x0f4fff:S, 0x0f5000-0x0f5fff:S, 0x0f6000-0x0f6fff:S, 0x0f7000-0x0f7fff:S, 0x0f8000-0x0f8fff:S, 0x0f9000-0x0f9fff:S, 0x0fa000-0x0fafff:S, 0x0fb000-0x0fbfff:S, 0x0fc000-0x0fcfff:S, 0x0fd000-0x0fdfff:S, 0x0fe000-0x0fefff:S, 0x0ff000-0x0fffff:S, 0x100000-0x100fff:S, 0x101000-0x101fff:S, 0x102000-0x102fff:S, 0x103000-0x103fff:S, 0x104000-0x104fff:S, 0x105000-0x105fff:S, 0x106000-0x106fff:S, 0x107000-0x107fff:S, 0x108000-0x108fff:S, 0x109000-0x109fff:S, 0x10a000-0x10afff:S, 0x10b000-0x10bfff:S, 0x10c000-0x10cfff:S, 0x10d000-0x10dfff:S, 0x10e000-0x10efff:S, 0x10f000-0x10ffff:S, 0x110000-0x110fff:S, 0x111000-0x111fff:S, 0x112000-0x112fff:S, 0x113000-0x113fff:S, 0x114000-0x114fff:S, 0x115000-0x115fff:S, 0x116000-0x116fff:S, 0x117000-0x117fff:S, 0x118000-0x118fff:S, 0x119000-0x119fff:S, 0x11a000-0x11afff:S, 0x11b000-0x11bfff:S, 0x11c000-0x11cfff:S, 0x11d000-0x11dfff:S, 0x11e000-0x11efff:S, 0x11f000-0x11ffff:S, 0x120000-0x120fff:S, 0x121000-0x121fff:S, 0x122000-0x122fff:S, 0x123000-0x123fff:S, 0x124000-0x124fff:S, 0x125000-0x125fff:S, 0x126000-0x126fff:S, 0x127000-0x127fff:S, 0x128000-0x128fff:S, 0x129000-0x129fff:S, 0x12a000-0x12afff:S, 0x12b000-0x12bfff:S, 0x12c000-0x12cfff:S, 0x12d000-0x12dfff:S, 0x12e000-0x12efff:S, 0x12f000-0x12ffff:S, 0x130000-0x130fff:S, 0x131000-0x131fff:S, 0x132000-0x132fff:S, 0x133000-0x133fff:S, 0x134000-0x134fff:S, 0x135000-0x135fff:S, 0x136000-0x136fff:S, 0x137000-0x137fff:S, 0x138000-0x138fff:S, 0x139000-0x139fff:S, 0x13a000-0x13afff:S, 0x13b000-0x13bfff:S, 0x13c000-0x13cfff:S, 0x13d000-0x13dfff:S, 0x13e000-0x13efff:S, 0x13f000-0x13ffff:S, 0x140000-0x140fff:S, 0x141000-0x141fff:S, 0x142000-0x142fff:S, 0x143000-0x143fff:S, 0x144000-0x144fff:S, 0x145000-0x145fff:S, 0x146000-0x146fff:S, 0x147000-0x147fff:S, 0x148000-0x148fff:S, 0x149000-0x149fff:S, 0x14a000-0x14afff:S, 0x14b000-0x14bfff:S, 0x14c000-0x14cfff:S, 0x14d000-0x14dfff:S, 0x14e000-0x14efff:S, 0x14f000-0x14ffff:S, 0x150000-0x150fff:S, 0x151000-0x151fff:S, 0x152000-0x152fff:S, 0x153000-0x153fff:S, 0x154000-0x154fff:S, 0x155000-0x155fff:S, 0x156000-0x156fff:S, 0x157000-0x157fff:S, 0x158000-0x158fff:S, 0x159000-0x159fff:S, 0x15a000-0x15afff:S, 0x15b000-0x15bfff:S, 0x15c000-0x15cfff:S, 0x15d000-0x15dfff:S, 0x15e000-0x15efff:S, 0x15f000-0x15ffff:S, 0x160000-0x160fff:S, 0x161000-0x161fff:S, 0x162000-0x162fff:S, 0x163000-0x163fff:S, 0x164000-0x164fff:S, 0x165000-0x165fff:S, 0x166000-0x166fff:S, 0x167000-0x167fff:S, 0x168000-0x168fff:S, 0x169000-0x169fff:S, 0x16a000-0x16afff:S, 0x16b000-0x16bfff:S, 0x16c000-0x16cfff:S, 0x16d000-0x16dfff:S, 0x16e000-0x16efff:S, 0x16f000-0x16ffff:S, 0x170000-0x170fff:S, 0x171000-0x171fff:S, 0x172000-0x172fff:S, 0x173000-0x173fff:S, 0x174000-0x174fff:S, 0x175000-0x175fff:S, 0x176000-0x176fff:S, 0x177000-0x177fff:S, 0x178000-0x178fff:S, 0x179000-0x179fff:S, 0x17a000-0x17afff:S, 0x17b000-0x17bfff:S, 0x17c000-0x17cfff:S, 0x17d000-0x17dfff:S, 0x17e000-0x17efff:S, 0x17f000-0x17ffff:S, 0x180000-0x180fff:S, 0x181000-0x181fff:S, 0x182000-0x182fff:S, 0x183000-0x183fff:S, 0x184000-0x184fff:S, 0x185000-0x185fff:S, 0x186000-0x186fff:S, 0x187000-0x187fff:S, 0x188000-0x188fff:S, 0x189000-0x189fff:S, 0x18a000-0x18afff:S, 0x18b000-0x18bfff:S, 0x18c000-0x18cfff:S, 0x18d000-0x18dfff:S, 0x18e000-0x18efff:S, 0x18f000-0x18ffff:S, 0x190000-0x190fff:S, 0x191000-0x191fff:S, 0x192000-0x192fff:S, 0x193000-0x193fff:S, 0x194000-0x194fff:S, 0x195000-0x195fff:S, 0x196000-0x196fff:S, 0x197000-0x197fff:S, 0x198000-0x198fff:S, 0x199000-0x199fff:S, 0x19a000-0x19afff:S, 0x19b000-0x19bfff:S, 0x19c000-0x19cfff:S, 0x19d000-0x19dfff:S, 0x19e000-0x19efff:S, 0x19f000-0x19ffff:S, 0x1a0000-0x1a0fff:S, 0x1a1000-0x1a1fff:S, 0x1a2000-0x1a2fff:S, 0x1a3000-0x1a3fff:S, 0x1a4000-0x1a4fff:S, 0x1a5000-0x1a5fff:S, 0x1a6000-0x1a6fff:S, 0x1a7000-0x1a7fff:S, 0x1a8000-0x1a8fff:S, 0x1a9000-0x1a9fff:S, 0x1aa000-0x1aafff:S, 0x1ab000-0x1abfff:S, 0x1ac000-0x1acfff:S, 0x1ad000-0x1adfff:S, 0x1ae000-0x1aefff:S, 0x1af000-0x1affff:S, 0x1b0000-0x1b0fff:S, 0x1b1000-0x1b1fff:W, 0x1b2000-0x1b2fff:W, 0x1b3000-0x1b3fff:W, 0x1b4000-0x1b4fff:W, 0x1b5000-0x1b5fff:W, 0x1b6000-0x1b6fff:W, 0x1b7000-0x1b7fff:W, 0x1b8000-0x1b8fff:W, 0x1b9000-0x1b9fff:W, 0x1ba000-0x1bafff:W, 0x1bb000-0x1bbfff:W, 0x1bc000-0x1bcfff:W, 0x1bd000-0x1bdfff:W, 0x1be000-0x1befff:W, 0x1bf000-0x1bffff:W, 0x1c0000-0x1c0fff:W, 0x1c1000-0x1c1fff:W, 0x1c2000-0x1c2fff:W, 0x1c3000-0x1c3fff:W, 0x1c4000-0x1c4fff:W, 0x1c5000-0x1c5fff:W, 0x1c6000-0x1c6fff:W, 0x1c7000-0x1c7fff:W, 0x1c8000-0x1c8fff:W, 0x1c9000-0x1c9fff:W, 0x1ca000-0x1cafff:W, 0x1cb000-0x1cbfff:W, 0x1cc000-0x1ccfff:W, 0x1cd000-0x1cdfff:W, 0x1ce000-0x1cefff:W, 0x1cf000-0x1cffff:W, 0x1d0000-0x1d0fff:W, 0x1d1000-0x1d1fff:W, 0x1d2000-0x1d2fff:W, 0x1d3000-0x1d3fff:W, 0x1d4000-0x1d4fff:W, 0x1d5000-0x1d5fff:W, 0x1d6000-0x1d6fff:W, 0x1d7000-0x1d7fff:W, 0x1d8000-0x1d8fff:W, 0x1d9000-0x1d9fff:W, 0x1da000-0x1dafff:S, 0x1db000-0x1dbfff:W, 0x1dc000-0x1dcfff:W, 0x1dd000-0x1ddfff:W, 0x1de000-0x1defff:W, 0x1df000-0x1dffff:W, 0x1e0000-0x1e0fff:W, 0x1e1000-0x1e1fff:W, 0x1e2000-0x1e2fff:W, 0x1e3000-0x1e3fff:W, 0x1e4000-0x1e4fff:W, 0x1e5000-0x1e5fff:W, 0x1e6000-0x1e6fff:W, 0x1e7000-0x1e7fff:W, 0x1e8000-0x1e8fff:W, 0x1e9000-0x1e9fff:W, 0x1ea000-0x1eafff:W, 0x1eb000-0x1ebfff:W, 0x1ec000-0x1ecfff:W, 0x1ed000-0x1edfff:W, 0x1ee000-0x1eefff:W, 0x1ef000-0x1effff:W, 0x1f0000-0x1f0fff:W, 0x1f1000-0x1f1fff:W, 0x1f2000-0x1f2fff:W, 0x1f3000-0x1f3fff:W, 0x1f4000-0x1f4fff:W, 0x1f5000-0x1f5fff:W, 0x1f6000-0x1f6fff:W, 0x1f7000-0x1f7fff:W, 0x1f8000-0x1f8fff:W, 0x1f9000-0x1f9fff:W, 0x1fa000-0x1fafff:W, 0x1fb000-0x1fbfff:W, 0x1fc000-0x1fcfff:W, 0x1fd000-0x1fdfff:W, 0x1fe000-0x1fefff:W, 0x1ff000-0x1fffff:W, 0x200000-0x200fff:W, 0x201000-0x201fff:W, 0x202000-0x202fff:W, 0x203000-0x203fff:W, 0x204000-0x204fff:W, 0x205000-0x205fff:W, 0x206000-0x206fff:W, 0x207000-0x207fff:W, 0x208000-0x208fff:W, 0x209000-0x209fff:W, 0x20a000-0x20afff:W, 0x20b000-0x20bfff:W, 0x20c000-0x20cfff:W, 0x20d000-0x20dfff:W, 0x20e000-0x20efff:W, 0x20f000-0x20ffff:W, 0x210000-0x210fff:W, 0x211000-0x211fff:W, 0x212000-0x212fff:W, 0x213000-0x213fff:W, 0x214000-0x214fff:W, 0x215000-0x215fff:W, 0x216000-0x216fff:W, 0x217000-0x217fff:W, 0x218000-0x218fff:W, 0x219000-0x219fff:W, 0x21a000-0x21afff:W, 0x21b000-0x21bfff:W, 0x21c000-0x21cfff:W, 0x21d000-0x21dfff:W, 0x21e000-0x21efff:W, 0x21f000-0x21ffff:W, 0x220000-0x220fff:W, 0x221000-0x221fff:S, 0x222000-0x222fff:S, 0x223000-0x223fff:S, 0x224000-0x224fff:S, 0x225000-0x225fff:S, 0x226000-0x226fff:S, 0x227000-0x227fff:S, 0x228000-0x228fff:S, 0x229000-0x229fff:S, 0x22a000-0x22afff:S, 0x22b000-0x22bfff:S, 0x22c000-0x22cfff:S, 0x22d000-0x22dfff:S, 0x22e000-0x22efff:S, 0x22f000-0x22ffff:S, 0x230000-0x230fff:S, 0x231000-0x231fff:S, 0x232000-0x232fff:S, 0x233000-0x233fff:S, 0x234000-0x234fff:S, 0x235000-0x235fff:S, 0x236000-0x236fff:S, 0x237000-0x237fff:S, 0x238000-0x238fff:S, 0x239000-0x239fff:S, 0x23a000-0x23afff:S, 0x23b000-0x23bfff:S, 0x23c000-0x23cfff:S, 0x23d000-0x23dfff:S, 0x23e000-0x23efff:S, 0x23f000-0x23ffff:S, 0x240000-0x240fff:S, 0x241000-0x241fff:S, 0x242000-0x242fff:S, 0x243000-0x243fff:S, 0x244000-0x244fff:S, 0x245000-0x245fff:S, 0x246000-0x246fff:S, 0x247000-0x247fff:S, 0x248000-0x248fff:S, 0x249000-0x249fff:S, 0x24a000-0x24afff:S, 0x24b000-0x24bfff:S, 0x24c000-0x24cfff:S, 0x24d000-0x24dfff:S, 0x24e000-0x24efff:S, 0x24f000-0x24ffff:S, 0x250000-0x250fff:S, 0x251000-0x251fff:S, 0x252000-0x252fff:S, 0x253000-0x253fff:S, 0x254000-0x254fff:S, 0x255000-0x255fff:S, 0x256000-0x256fff:S, 0x257000-0x257fff:S, 0x258000-0x258fff:S, 0x259000-0x259fff:W, 0x25a000-0x25afff:W, 0x25b000-0x25bfff:S, 0x25c000-0x25cfff:W, 0x25d000-0x25dfff:S, 0x25e000-0x25efff:W, 0x25f000-0x25ffff:W, 0x260000-0x260fff:W
