Flashrom & AVRDude support (only legacy mode)
Help us test and improve support for AVRDude and Flashrom (legacy mode)
Firmware files & more info:
Give us feedback!
This is amazing! I hope to be done with the rp2350 debug today and will address this next.
Flashed the firmware. ~@Dreg please take a look at the chat Need some assistance here.~
EDIT: Nevermind I figured it out.
areyouloco@studio:~$ sudo flashrom -p buspirate_spi:dev=/dev/serial/by-id/usb-Bus_Pirate_Bus_Pirate_5_32420B0B33CC62E4-if02,spispeed=8M -r a
flashrom 1.4.0 on Linux 6.10.3-amd64 (x86_64)
flashrom is free software, get the source code at https://flashrom.org
Found Macronix flash chip "MX25L6405" (8192 kB, SPI) on buspirate_spi.
Found Macronix flash chip "MX25L6405D" (8192 kB, SPI) on buspirate_spi.
Found Macronix flash chip "MX25L6406E/MX25L6408E" (8192 kB, SPI) on buspirate_spi.
Found Macronix flash chip "MX25L6436E/MX25L6445E/MX25L6465E" (8192 kB, SPI) on buspirate_spi.
Found Macronix flash chip "MX25L6473E" (8192 kB, SPI) on buspirate_spi.
Found Macronix flash chip "MX25L6473F" (8192 kB, SPI) on buspirate_spi.
Multiple flash chip definitions match the detected chip(s): "MX25L6405", "MX25L6405D", "MX25L6406E/MX25L6408E", "MX25L6436E/MX25L6445E/MX25L6465E", "MX25L6473E", "MX25L6473F"
Please specify which chip definition to use with the -c <chipname> option.
areyouloco@studio:~$ sudo flashrom -p buspirate_spi:dev=/dev/serial/by-id/usb-Bus_Pirate_Bus_Pirate_5_32420B0B33CC62E4-if02,spispeed=8M -c "MX25L6436E/MX25L6445E/MX25L6465E" -r a
Reading flash... done.
areyouloco@studio:~$ sudo flashrom -p buspirate_spi:dev=/dev/serial/by-id/usb-Bus_Pirate_Bus_Pirate_5_32420B0B33CC62E4-if02,spispeed=8M -c "MX25L6436E/MX25L6445E/MX25L6465E" -r a2
areyouloco@studio:~$ diff a a2
areyouloco@studio:~$ echo $?
0
So seems like it worked i used hexedit to see whats inside and looks like some binary data. It’s from some 1000 year old router.
But I had to go to SPI mode first to check the pinout on the LCD and then back to legacy binmode and then flashrom. Confirmed working.
thx for your feedback @AreYouLoco
the LCD minor issue will be fixed in a future PR
@Dreg wrote a tutorial showing how to use AVRDUDE, the Bus Pirate and the legacy binmode to dump an Arduino Leonardo.
This is in a new “software” section of the firmware documentation.
I pushed a new docs section for the new binary modes. It currently covers SUMP and FALA.
@Dreg - I pulled all the old SPI binmode docs from Bus Pirate v3.x and put them in a draft page here. When you have a chance, could you please see what needs to be updated to match the Legacy binmode you made? I can do all the final formatting, but I don’t know the technical details of your update.
Sorry for replying so late, I’ve been busy with personal matters.
I’ll take care of everything this week, don’t worry! I’ll do the best I can.
I will also add a flashrom demo in the new section you’ve created.
Hello
I’ve attempted to use fresh flashrom with both the most recent build of BP as well as two builds from the thread, with no sucesss. It stucks at:
flashrom -V -c XM25QH256B -p buspirate_spi:dev=/dev/ttyACM1,spispeed=1M -r a
Initializing buspirate_spi programme
In the recent build I’m getting:
Scripting mode enabled. Terminal locked.
then goes back so at least the communication is initialized properly. Despite -V flag in flashrom I’m getting no further info. Also not sure about the speed - with standalone SPI I was able to read at maximum with 10000kHz, should the flashrom spispeed param corespond to that ?
You have to select legacy binmode before running flashrom and the max speed that buspirate can handle now is 8M
See here:
Tutorial:
Btw, @AreYouLoco the LCD thing is merged :wink:
