Flashed newest build and was trying to tinker with an SGP30 VOC sensor, and choosing mode 5 (i2c) asks for freq, and then locks up no matter what you enter.
I tested previous build and it works fine. Since nothing was changed in the i2c code, maybe its the build server?
I am kind of a noob so cant speculate too much, but i did try a couple of the previous builds and i2c mode works as expected.
I have either the best or worst luck, depending how you look at it. this was literally the first thing i tried after getting my replacement from the mailbox a few minutes ago LOL
PS: when i reflashed the newest build to re-test, now it locks up before asking for freq. am i doing something dumb?
also to note. this happens before any wires are hooked to the BP. i did have wires hooked up the first time around, but realized i didnt know which IO BP would want for SCL/SDA so unhooked them completely and same thing happens
@ian
That’s because the stack guard has been turned on. I am not sure entirely what’s going on, but turning the stack guard on also requires specifying the value of PICO_STACK_SIZE. Like so in CMakeLists.txt:
target_compile_definitions(${revision} PUBLIC PICO_USE_STACK_GUARDS=1)
target_compile_definitions(${revision} PUBLIC PICO_STACK_SIZE=4096)
Sorry. The default stack size is 2KiB which is too small to accommodate for the FAT filesystem code which allocates more than this on the stack during the execution of f_open. Setting the stack size to 4Kib makes things better.
Confirmed this happens for everything related to writing to the fat system. Items such as UART config or general config (c) also cause the same defect to rise.
I think it was a great insight. I bet the core0 stack overflow is the cause of all of the unexplained crashes so far.
I think you should post a debug binary with stack guard and 4Kib of stack space for people to try and validate the new stack size. People who use a debugger will be able to send stack traces.
That would be excellent. I debugged the crashes I got with stack guard and any execution of f_open is guaranteed to trigger the stack guard exception. The code pushes on the stack a large structure that is larger than a sector size (2048). The problem is how to pick a value for the stack size. 4096 seems like a good value but likely to be conservatively large.
That’s a sector of the NAND flash, plus a 512 byte buffer I’d bet. I’ll look to see why that’s on the stack, it’s probably my fault - FatFS is really tuned to avoid that kind of thing.
I’m guessing I need a pool of already allocated file structures that can allow temporary ownership by various functions. I have not looked internally lately, but my recollection was FatFS has a dedicated sector buffer shared by all files. It sounds like that may not be the case, or maybe I don’t have that option enabled (minimal implementation is an option).
That’s a great idea, I would like to be one of the tester.
In addition, a long term solution could be adding some unit tests to certain modules, so some code quality could be guarantied automatically.
I have experience with Google’s gmock, we can easly integrate it with our existing Cmake build system.
File system and stack overflow updates are pushed to the test branch. It solved a bunch of issues for me.
The enabled the tiny FatFS implementation for now, and the speed doesn’t seem to be an issue.
Now that this seems to be a bit more under control, should I investigate enabling the STACK_GUARDS? It seems like the reason the hard fault happened on core 1, though it was caused by core 0, is the core0 stack overflowing up into core1 stack and causing the crash. Maybe this is a good thing to enable.
Someone linked a nice library to catch and display the stack trace on faults, but it’s not licensed in a way we can use it. I imagine I can catch the fault interrupt and do something, but I’m not sure what - maybe change LED color? The USB pipeline would be broken after the fault, I assume, so displaying anything in the terminal would be tricky.
I think stack guard should be enabled on test builds, and I suggest that test builds are configured as debug instead of release. This would enable people to include a stack trace using gdb.
Personally, I have made the following addition to CMakeList.txt
# useful for debug builds
target_compile_definitions(${revision} PUBLIC PICO_USE_STACK_GUARDS=$<CONFIG:DEBUG>)
In other words when I configure cmake for debug builds it automatically enable stack guard
@ian Awesome.
Another topic. If I understand correctly, people who want to submit a PR should do so on the test branch. I also understand that the contrib branch may not be necessary. If my understanding is correct, could you post somewhere an authoritative guidance about this? Thanks a lot!
The main goal is to avoid pull requests on main because when I accept it, we get an autobuild before testing. Some sort of staging area away from main seems like the answer.
Maybe there is a “github” way to accomplish that. Thus far I’ve been going to the source of the pull requests and grabbing a patch, or creating my own pull request onto a new branch. I don’t know if anyone really cares, but it feels a bit rude not accepting a pull request and making my own.
I saw you push to test, that is totally fine with me. I’ll merge all that to main today.
thats called the “git flow” and the branch that you call “test” right now is called “development” there and PRs end up there. merges to main are only from “development” when it is stable for a release. main branch is always a stable state that way.
