Issue #265: i2c scan & pull-ups
i2c scan & pull-ups:
I updated the firmware and now i2c scan no longer works. I have a device attached to my BP and set it in 12c mode. I set the woltage and pullups. Then
I2C> P
Pull-up resistors: Enabled (10K ohms @ 3.3V)
I2C> scan
Error: Pull-up not detected on IO pin
Hint: Use P to enable pull-up resistors, or use external pull-up
Aborting I2C scan
I had enabled pullups. The configuration is
I2C> i
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions:
(1) this device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
Bus Pirate 6
https://BusPirate.com/
Firmware main branch @ a3b3977 (Nov 10 2025 13:16:25)
RP2350B with 512KB RAM, 128Mbit FLASH
S/N: 442CD5B5206B7C03
Storage:   0.10GB (FAT16 File System)
Configuration file: Loaded
Active binmode: Follow along logic analyzer
Active mode: I2C
 I2C speed: 100 kHz
 Clock stretching: OFF
Display format: Auto
Pull-up resistors: ON
Power supply: ON (3.3V/3.29V)
Current limit: OK (4.8mA/300.0mA)
Frequency generators: OFF
Since this was related to a firmware change, I did some investigation,
Version
Firmware main branch @ 7c08a5d (Feb 6 2025 14:48:19)
works. Version
Firmware main branch @ f0b199b (Mar 8 2025 11:44:56)
does not work.
Issue opened by: grymoire
I’m not having this issue, but I am having another issue with scan limited to BP6. I’m debugging this issue now.
On my hardware, I’m not getting any I2C output on 6, from latest firmware back to the March 8 version you post. None of them work at all.
The hardware otherwise seems fine.
I2C> P
I2C> scan
I2C address search:
0x2D (0x5A W) (0x5B R)
0x36 (0x6C W) (0x6D R)
0x53 (0xA6 W) (0xA7 R)
0x57 (0xAE W) (0xAF R)
Found 8 addresses, 4 W/R pairs.
I2C>
Update: ok, this is weird. It seems to be an issue with one particular 6, even though it passes self test. The other does I2C fine. I will need to dig deeper.
However I do not have the same issue with scan that you observed using the latest firmware.
Do all the voltages look right? IO0 and IO1 actually at 3.3volts?
So… E9 strikes again :wink: The Bus Pirate 6 I was testing with did not have the E9 bug fix. In fact, I only have half-fixed hand reworked boards for testing the initial fix.
