Issue #270: Feature: Add BPIO2 support for UART Glitch mode
Feature: Add BPIO2 support for UART Glitch mode:
What I’m trying to do
Being able to control UART glitching through BPIO2 would let me:
  • Run automated parameter sweeps from Python
  • Log results programmatically
  • Integrate with other tools in my workflow
Current glitch parameters
From looking at src/commands/uart/glitch.c, these are the settings:
Parameter What it does
glitch_trg Character that triggers the glitch (default: 13 = Enter)
glitch_delay How long after the stop bit to fire (in 10ns units)
glitch_wander How much to vary the timing for sweeping
glitch_time How long the glitch pulse lasts
glitch_recycle Minimum wait between attempts (ms)
fail_resp Character that means “bad password” (to detect success)
retry_count How many times to try before giving up
disable_ready Skip checking the ready input
Pins used:
  • IO0 - Trigger output (goes to your glitcher)
  • IO1 - Ready input (optional - glitcher signals when it’s recharged)
What I’d like to see
Something like this in Python:
client = BPIOClient('/dev/cu.usbmodem6buspirate3')
# Set up UART first (needs issue #1)
client.configuration_request(mode='UART', mode_configuration={'speed': 115200})
# Start the glitch attack
client.uart_glitch_request(
    trigger_char=13,        # Enter key
    delay_ns10=100,         # Start at 1000ns delay
    wander_ns10=50,         # Sweep ±500ns
    pulse_ns10=10,          # 100ns pulse
    fail_char=ord('#'),     # '#' means bad password
    max_retries=1000,
    start=True
# Check progress
while True:
    status = client.uart_glitch_status()
    if status['success']:
        print(f"Got it! Response: {status['response']}")
        break
    if not status['running']:
        print("No luck this time")
        break
Notes
  • This depends on basic UART BPIO2 support being added first (issue #1)
  • The existing PIO code in glitch.pio should work as-is
  • Would be nice if it auto-stops when you disconnect or change modes
Happy to help test if you want to point me at a branch!
Issue opened by: tc-mgriff
main my dude, let’s see it
Bot-copy from GitHub comment by: DangerousPrototypes
I’m love this idea. As the contributor for the UART glitch command, I have a could of thoughts right off the cuff:
  • biggest issue is the unpredictability of glitching - sometimes the target will lock up or behave in very unexpected ways which may make scripting a bit tricky
  • I really like the “sweep” idea; kind of like working with a Chip Whisperer
I can’t look at it for the next couple of weeks, I’m away from home, but would gladly be a part of this.
Bot-copy from GitHub comment by: mbrugman67
