Can folks confirm this bug?
- Load up the most recent build on a BP6
- connect to the terminal
- run the help command
My devices are locking up when sending data to the queue. Worse, the state of the queue makes it seem like this should not be an infinite loop…
queue.c @ line 70: if (((q->wptr + 1) & (q->element_count - 1)) != q->rptr) { /* add data and exit function */ }
Dumping the queue data structure, wptr == rptr … so this should be entering the if block. However, it does not.
GDB dump...
(gdb) bt
#0 queue_add_internal (block=true, data=0x20081e27 "6\034\037\b \335#", q=0x2003d4b8 <tx_fifo>) at /src/bp5/src/queue.c:70
#1 queue2_add_blocking (q=0x2003d4b8 <tx_fifo>, data=0x20081e27 "6\034\037\b \335#") at /src/bp5/src/queue.c:162
#2 0x1000168e in _putchar (character=<optimized out>) at /src/bp5/src/printf-4.0.0/printf.c:126
#3 _out_char (buffer=<optimized out>, idx=<optimized out>, maxlen=<optimized out>, character=<optimized out>) at /src/bp5/src/printf-4.0.0/printf.c:162
#4 _out_char (character=<optimized out>, buffer=<optimized out>, idx=<optimized out>, maxlen=<optimized out>) at /src/bp5/src/printf-4.0.0/printf.c:158
#5 0x100023dc in _vsnprintf (out=<optimized out>, out@entry=0x10001679 <_out_char>, buffer=0x20081ec8 "", buffer@entry=0x20081ea8 "A", maxlen=maxlen@entry=4294967295,
format=0x1005f866 "s%s\r\n", format@entry=0x1005f9dc "\033[38;2;191;165;48m", va=..., va@entry=...) at /src/bp5/src/printf-4.0.0/printf.c:819
#6 0x1000285c in printf_ (format=0x1005f85c "%s%s%s\t%s%s%s\r\n") at /src/bp5/src/printf-4.0.0/printf.c:876
#7 0x10022fe8 in ui_help_options (help=help@entry=0x10093a94 <global_commands>, count=count@entry=65) at /src/bp5/src/ui/ui_help.c:35
#8 0x10007a18 in help_global () at /src/bp5/src/commands/global/h_help.c:175
#9 help_handler (res=<optimized out>) at /src/bp5/src/commands/global/h_help.c:204
#10 0x10021258 in ui_process_commands () at /src/bp5/src/ui/ui_process.c:146
#11 0x10000f52 in core0_infinite_loop () at /src/bp5/src/pirate.c:600
#12 main () at /src/bp5/src/pirate.c:676
(gdb) print -pretty on -- *q
$3 = {
core = {
spin_lock = 0x0
data = 0x20028800 <tx_buf> "89mo\033[0m\t\033[38;2;191;165;48mChoose how numbers are displayed\033[0m\r\n\033[38;2;150;203;89ml/L\033[0m\t\033[38;2;191;165;48mBitorder (msb/LSB)\033[0m\r\n\033[38;2;150;203;89mcls\033[0m\t\033[38;2;191;165;48mClear and reset the ter"...,
wptr = 915,
rptr = 915,
element_count = 1024
