Major internal updates: command line, args parsing, number parsing, syntax compiler, number display
A few weeks ago I burned excess LLM credits making some deep experimental changes to the firmware. A lot of the changes are really nice and I think we should integrate them. While the LLM was super useful for testing big updates rapidly, the actual code and implementation is mostly a mess and unusable.
The experimental builds are available here.
linenoise command line
Linenoise is the command line used in redis, among others. It supports hinting and autocomplete (if we can wrangle our stuff into a workable structure). It works from a linear buffer, and then stores history in a weird list structure that requires shuffling everything around.
  • Remove dynamic memory allocations
  • Replace weird history buffer with circular buffer
  • Add simple mode so prompts can be parsed separately from command line
  • Integrate hinting with command structure (see below)
Updated argument parser
The LLM did an okay job reworking the argument parsing. I think it’s more a template for updates I need to do, than actual usable code.
  • Support positional arguments
  • Support short - and long – flags
  • Supports combined short flags -lfc
Command struct rework
This is going to need some thought because it impacts the rest of the changes. I’m not happy with the LLM prototype as the core of these updates.
General thoughts:
  • Global and mode commands share the same struct definition.
  • Global commands are self documenting, so help is built dynamically rather than manually avoiding “orphaned” commands.
  • In concert with the new args parser, global and local command arguments should be accessible to linenoise for hinting.
Break up syntax compiler
The compile/execute/report functions are in one huge file. LLM did a passable job, I think this code is usable, but needs manual implementation.
Unified number parsing library
There are currently 2, perhaps 3 very similar functions for parsing int/float/string. With some manual tweaks, the LLM reworked library should be usable.
Number printing functions
Similarly there are three number printing functions. One is dead code, the other two differ by only the slightest amount. LLM code is usable (only a few lines changed), but needs manual implementation.
Safe injection point for scripts
This has been an issue - the interaction of the command line, history, and scripts is dodgy at best. Linenoise fixes this issue.
Done but needs more testing.
= command with full math and logic calculator
This is probably the most impressive thing to come out of the LLM experiment. The code is pretty good, and the test fixture covers lots of cases. I think it’s worth including.
Latest experimental build
Linenoise is now integrated and seems solid.
  • Implemented in command line and prompts
  • History bugs with old command line are gone
  • Can detect ^C but I don’t know what to do with that yet :slight_smile:
  • Safe injection point for scripts and macros, seems OK but I’d could use some help testing.
  • Removed all old circular buffer stuff
  • completion and hinting are NOT enabled yet, they’ll depend on the new implementation of the args parser.
Next I’ll go for the lowest hanging fruit:
  • Unified number parsing library
  • Number printing functions
  • Break up syntax compiler
Command struct rework and arguments parser update will be a big project and go hand in hand.
Latest experimental build has:
  • = command with full math and logic calculator
  • ETA: Number printing functions
Integrated the refactored syntax compiler. Autocompile should arrive in the experimental thread shortly.
This leaves the biggest, interlocked updates:
  • Linked to the command documentation struct, unified with linenoise hinting and help text
  • Reuse number parsing library if at all possible.
General thoughts:
A new structure holds the action, argument flags, and help for commands.
static const bp_command_opt_t flash_opts[] = {
    { "file",     'f', BP_ARG_REQUIRED, "<file>",    T_HELP_FLASH_FILE_FLAG },
    { "erase",    'e', BP_ARG_NONE,     NULL,        T_HELP_FLASH_ERASE_FLAG },
    { "verify",   'v', BP_ARG_NONE,     NULL,        T_HELP_FLASH_VERIFY_FLAG },
    { "start",    's', BP_ARG_REQUIRED, "<addr>",    UI_HEX_HELP_START },
    { "bytes",    'b', BP_ARG_REQUIRED, "<count>",   UI_HEX_HELP_BYTES },
    { "quiet",    'q', BP_ARG_NONE,     NULL,        UI_HEX_HELP_QUIET },
    { "nopager",  'c', BP_ARG_NONE,     NULL,        T_HELP_DISK_HEX_PAGER_OFF },
    { "override", 'o', BP_ARG_NONE,     NULL,        T_HELP_FLASH_OVERRIDE },
    { "yes",      'y', BP_ARG_NONE,     NULL,        T_HELP_FLASH_YES_OVERRIDE },
    { 0 }
We tell the args parser which flags require parameters, so it can throw errors from a central location instead of writing that code in each command.
Next we need to:
  • Get the new command structure registers in the mode/global command list.
  • Try autocomplete and hinting with linenoise
  • Unify mode/global command structures
  • Make global commands self documenting in help.
Not a huge surface change, but massive update to system core. Help and command lists should be a lot more polished. When the commands are all ported to the new system I’ll look at autocomplete and hinting.
There may be a autobuild, let’s see if this compiles :slight_smile:
  • Implemented new mode and global command struct
  • The command registration is radically changed
  • help is now self documented and no more orphaned commands
  • Short/long flags added to ALL mode commands
  • Short/long flags added to most global commands
  • Lots more internal chaos
//TO DO:
  • DDR4/DDR5/dummy.c check the impact of not having the no_args flag on -b and other flags
  • Restore as non-priority, the command name to the master global command struct (for easier dev)
  • Not getting args parse errors when required values are missing
  • Help pager is messed up (remove?)
  • Python script to scan for dead translation entries
  • Python script to extract all the help menus and put in markdown for easier one stop testing
  • Check dead code in ui_cmdln
  • Positional arguments are not well explained in the help
  • PWM and Pullups need attention
  • Predictive text seems to blow out cursors in simple mode
As a UNIX guy, Control-C is an immediate stop.abort
There are times where I have done an “oops’“ and want to abort the process; Am I sure I wired the pins right? The Glasgow has a physical abort/disconnect button.
I like the idea of a disconnect/reconnect feature. I was testing different component and would go to Hi-Z modem, unplug the component. Plug in another jig/component, and re-type the commands to get back into the same mode, answering all of the questions, etc.
It would be handy to have a simple workflow
  1. Disconnect electronically and save config
  2. Unplug and switch new component
  3. Reconnect and restore config
  4. repeat the last command
Maybe I’m just paranoid. I don’t switch parts with power on, and always connect ground first.
I wrote a script to extract all the help from every command so I can review it in one place easily.
Help extraction
Bus Pirate Command Help Reference
Auto-generated by helpcollect.py. Do not edit manually.
W
W -h
usage:
w|W	<v> <i> [-u <%>]
Disable: w
Enable, with menu: W
Enable 5v, 50mA fuse, 10% default undervoltage limit: W 5 50
Enable 3.3v, 300mA default fuse, 10% default undervoltage limit: W 3.3
Enable 3.3v, 100mA fuse, 20% undervoltage limit: W 3.3 100 -u 20
Enable 3.3v, no fuse, no undervoltage limit: W 3.3 0 -u 100
W - enable onboard power supply, show configuration menu.
-u, --undervoltage <%> Undervoltage limit <percent>
HiZ>
w
w -h
usage:
Disable: w
w - disable onboard power supply.
HiZ>
P
P -h
P - enable onboard pull-up resistors.
HiZ>
p
p -h
p - disable onboard pull-up resistors.
HiZ>
a
a -h
usage:
a/A/@ <io> [-h(elp)]
Pin 0 ouput, low: a 0
Pin 2 output, high: A 2
Pin 5 input, read value: @ 5
a <IOx> - make pin <IOx> output and low.
HiZ>
A
A -h
usage:
A <IOx> - make pin <IOx> output and high.
HiZ>
@ -h
usage:
@ <IOx> - make pin <IOx> input, read the pin state.
HiZ>
f
f -h
usage:
f [pin]
Measure frequency once: f
Measure frequency on pin 2: f 2
f <IOx> - measure frequency on <IOx> once.
HiZ>
F
F -h
usage:
F [pin]
Continuous frequency measurement: F
Continuous frequency on pin 2: F 2
F <IOx> - measure frequency on <IOx> continuously.
HiZ>
G
G -h
G - configure frequency generator (PWM) on an available IOx pin.
HiZ>
g
g -h
g <IOx> - disable frequency generator (PWM) on pin <IOx>.
HiZ>
v
v -h
usage:
v/V [io]
Measure pin 0 voltage: v 0
Continuous measurement pin 0: V 0
Measure voltage on all pins: v
Continuous measurement on all pins: V
v <IOx> - single voltage measurement on pin <IOx>. Omit the pin number to measure voltage on all pins once.
HiZ>
V
V -h
usage:
v/V [io]
V <IOx> - continuous voltage measurement on pin <IOx>. Omit the pin number to measure voltage on all pins.
HiZ>
c
c -h
c - open Bus Pirate configuration menu.
HiZ>
d
d -h
d - change display mode, show selection menu.
HiZ>
o
o -h
o - configure number output display format.
HiZ>
l
l -h
usage:
L
Set bit order to MSB-first: L
l - set Most Significant Bit output order.
HiZ>
L
L -h
usage:
l
Set bit order to LSB-first: l
L - set Least Significant Bit ouput order.
HiZ>
cls
cls -h
usage:
cls
Clear and refresh the terminal screen: cls
Note: will attempt to detect and initialize VT100 ANSI terminal
Clear and reset the terminal
HiZ>
i
i -h
usage:
i
Display system information: i
i - show Bus Pirate info and status screen.
HiZ>
reboot
reboot -h
usage:
reboot
Reboot the Bus Pirate: reboot
reboot - reboot and restart the Bus Pirate.
HiZ>
$ -h
usage:
Jump to bootloader for firmware updates: $
$ - reset and enter bootloader mode for updates.
HiZ>
~ -h
usage:
~	[-h(elp)]
Run self-test: ~
Warning: Disconnect any devices before running self-test
Warning: Self-test is only available in HiZ mode
run a complete system self-test
HiZ>
bug
bug -h
usage:
replicate hardware bugs
Test errata E9: bug e9
HiZ>
ovrclk
ovrclk -h
!!ovrclk is in demonstration mode!!
To enable overclocking, recompile with BP_OVERCLOCK_ENABLED defined
usage:
ovrclk 	[-m <MHz> | -k <kHz>] [-v <core mV>]
Overclock: ovrclk -m 135
Change core voltage: ovrclk -v 1150 (850-1300mV valid)
-m, --mhz <MHz>
-k, --khz <kHz>
-v, --volt <mV>
HiZ>
smps
smps -h
usage:
smps	<v> [-s]
Set SMPS to <v> volts:  smps 12.3
Show SMPS ADC setpoints (diagnostic): smps -s
Switch mode power supply (plank required)
-s, --setpoints Show calculated ADC setpoints
HiZ>
jep106
jep106 -h
usage:
jep106 <bank number> <vendor id>
Lookup JEP106 ID (Micron): jep106 0x00 0x2c
Lookup JEP106 ID (Sinker): jep106 0x0a 0xab
lookup vendor name from 2 byte JEDEC JEP106 ID code
HiZ>
ls
ls -h
usage:
ls <dir>
Show current directory contents: ls
Show directory contents: ls /dir
list files and directories on local storage
HiZ>
cd
cd -h
usage:
cd <dir>
Change directory: cd dir
change to a directory on local storage
HiZ>
mkdir
mkdir -h
usage:
mkdir <dir>
Create directory: mkdir dir
create directory on internal storage
HiZ>
rm
rm -h
usage:
rm [<file>|<dir>]
Delete file: rm example.txt
Delete directory: rm dir
delete file or directory on local storage
HiZ>
cat
cat -h
usage:
cat <file>
Print file contents: cat example.txt
print file contents as text
HiZ>
hex
hex -h
usage:
hex <file> [-s <start address>] [-b <bytes>] [-p (disable pager)] [-a (disable address column)]
Print file contents in HEX: hex example.bin
Print 32 bytes starting at address 0x50: hex example.bin -s 0x50 -b 32
Disable address and ASCII columns: hex example.bin -q
press 'x' to quit pager
Print file contents in HEX format
-s, --start <addr> Dump: start address
-b, --bytes <count> Dump: number of bytes
-q, --quiet     Dump: quiet mode, disable address and ASCII columns
-c, --nopager   Dump: disable pager
HiZ>
format
format -h
usage:
format
Format storage: format
erase and format internal storage in FAT16 format
HiZ>
label
label -h
usage:
label [get|set] <name>
Get flash storage label name: label get
Set flash storage label name: label set <name>
get or set the disk label
get             returns the current label of the disk
set             sets the current label of the disk
HiZ>
image -h
usage:
Read BMP info and display image file on LCD
Usage: image <file> [-d] [-h]
Read info: image example.bmp
Draw on display: image example.bmp -d
Read formats: BITMAPINFOHEADER V1 (40Bytes), V2 (52B), V3 (54B)
Draw formats: 16-bit (565) and 24-bit bitmaps, 240x320 pixels
Write a bitmap image on the LCD
-d, --draw      Draw the image on the LCD
HiZ>
dump
dump -h
usage:
dump <bytes> <file>
First, manually setup a read from the device
Then, run this command to read X bytes to a file
Read X bytes to a file: dump 256 example.bin
dump <file> <device> - dump contents of flash <device> to <file>. Warning: currently a prototype that only works with 25LC020 in SPI mode.
HiZ>
otpdump
otpdump -h
Invalid command: otpdump. Type ? for help.
HiZ>
script
script -h
usage:
script <file> [-p(ause for <enter>)] [-d (hiDe comments)] [-a(bort on error)] [-h(elp)]
Run script: script example.scr
Script files:
Script files are stored in text files with the .scr extension
Lines starting with '#' are comments
Other lines are inserted into the command prompt
Exit with 'x' during execution
Example:
# This is my example script file
# The 'pause' command waits for any key press
pause
# Did it pause?
Run script files, automation
-p, --pause     Pause after each line for manual <enter> key
-d, --hide      Hide comment lines starting with #
-a, --abort     Exit script on error
HiZ>
button
button -h
usage:
button [short|long] [-f <file>] [-d (hiDe comments)] [-e(xit on error)] [-h(elp)]
Assign script file to short button press: button short -f example.scr
Assign script file to long button press: button long -f example.scr
Exit script on error option: button short example.scr -e
Default script files are 'button.scr' and 'buttlong.scr' in the root directory
Assign script file to button press
short           Assign script file to short button press
long            Assign script file to long button press
-f, --file <file> Script file to assign to button press
-d, --hide      Hide comments
-e, --exit      Exit script on error
HiZ>
macro
macro -h
usage:
macro <#>
	[-f <file>] [-a] [-l] [-h(elp)]
Load macros: macro -f <file>
List macros: macro -l
Run macro 1: macro 1
Macro system help: macro -h
Macro files:
 Macros are stored in text files
 Lines starting with '#!' are macro usage instructions
 Every macro line includes an id (>0), a separator ':', and commands
Example:
 # This is my example macro file
 #! Read 5 bytes from an I2C EEPROM
 1:[0xa0 0][0xa1 r:5]
Run macros, load a macro file
-a, --all       List all macro files on storage
-f, --file <file> Macro file to load
-l, --list      List all macros in active macro file
HiZ>
pause
pause -h
usage:
pause and wait for any key: pause
pause and wait for button press: pause -b
pause and wait for button or any key: pause -b -k
'x' key to exit (e.g. script mode): pause -x
Pause for user input, optional exit
-k, --key       Press any key to continue (default)
-b, --button    Press the Bus Pirate button to continue
-x, --exit      'x' key to exit (e.g. script mode)
HiZ>
logic
logic -h
usage:
logic analyzer usage
logic	[start|stop|hide|show|nav]
	[-i] [-g] [-o oversample] [-f frequency] [-d debug]
start logic analyzer: logic start
stop logic analyzer: logic stop
hide logic analyzer: logic hide
show logic analyzer: logic show
navigate logic analyzer: logic nav
configure logic analyzer: logic -i -o 8 -f 1000000 -d 0
set base pin (0=bufdir, 8=bufio): -b: logic -b 8
logic analyzer control
start           start logic analyzer
stop            stop logic analyzer
hide            hide logic graph
show            show logic graph
nav             navigate logic graph with arrow keys, x to exit
-i, --info      show configuration info
-o, --oversample <rate> set oversample rate, multiplies the sample frequency
-f, --frequency <freq> set sample frequency in Hz
-0, --lowchar <char> set character used for low in graph (ex:_)
-1, --highchar <char> set character used for high in graph (ex:*)
-d, --debug <level> set debug level: 0-2
-b, --base <pin> show configuration info
HiZ>
= -h
usage:
= <expression>
Convert: = 0x12
Math: = 0xFF & (1<<4)
Ops: + - * / & | ^ ~ << >>
= <value> - convert <value> to BIN/DEC/HEX/ASCII.
HiZ>
| -h
usage:
| <value>
Inverse bits: | 0x12345678
| <value> - inverse the bits in <value>.
HiZ>
m
m -h
m - change protocol mode. m <mode number> to skip the menu.
HiZ>
binmode
binmode -h
usage:
binmode
Configure the active binary mode: binmode
Select binary mode
Active binmode: BPIO2 flatbuffer interface
HiZ>
scan
scan -h
usage:
scan	[-h(elp)]
Scan 1-Wire address space: scan
scan for 1-Wire devices
1WIRE>
eeprom
eeprom -h
usage:
eeprom [dump|erase|write|read|verify|test|list|protect]
	[-d <device>] [-f <file>] [-v(verify)] [-s <start address>] [-b <bytes>] [-h(elp)]
List available EEPROM devices: eeprom list
Display contents (x to exit): eeprom dump -d ds2431
Display 16 bytes starting at address 0x10: eeprom dump -d ds2431 -s 0x10 -b 16
Erase, verify: eeprom erase -d ds2431 -v
Write from file, verify: eeprom write -d ds2431 -f example.bin -v
Read to file, verify: eeprom read -d ds2431 -f example.bin -v
Verify against file: eeprom verify -d ds2431 -f example.bin
Test chip (full erase/write/verify): eeprom test -d ds2431
Show write protect control block: eeprom protect -d ds2431
read, write and erase 243X series 1-Wire EEPROM chips
dump            Show contents. Space to continue, x to exit
erase           Erase chip
write           Write file to chip
read            Read chip to file
verify          Verify chip against file
test            Erase and write chip with dummy data, verify
list            List supported EEPROM devices
protect         Show chip write protect status
-d, --device <device> Specify the EEPROM device
-f, --file <file> File to write, read or verify
-v, --verify    Verify after write, read or erase
-y, --yes       Override yes/no prompt for destructive actions (erase, write, test)
1WIRE>
ds18b20
ds18b20 -h
usage:
ds18b20	[-h(elp)]
measure temperature (single sensor bus only): ds18b20
Query DS18B20 temperature sensor
1WIRE>
gps
gps -h
usage:
gps	[-h(elp)]
Decode GPS NMEA packets: gps
Exit: press any key
parse NMEA GPS data
UART>
bridge
bridge -h
usage:
bridge	[-h(elp)] [-t(oolbar)]
Transparent UART bridge: bridge
Exit: press Bus Pirate button
open UART with raw data IO, usb to serial bridge mode
-t, --toolbar   ENABLE toolbar while bridge is active (default: disabled)
UART>
glitch
glitch -h
usage:
glitch	[-h(elp)] [-c(onfig)]
UART glitch generator.  Note that times are in terms of nanoseconds * 10; therefore, a setting of 3 = 30ns
UART glitcher
-c, --config    show configuration info
UART>
bridge
bridge -h
usage:
bridge	[-h(elp)]
-s, --suppress  Suppress local echo, don't echo back sent data
HDUART>
scan
scan -h
usage:
scan	[-v(erbose)] [-h(elp)]
Scan I2C address space: scan
Scan, list possible part numbers: scan -v
scan I2C addresses, with optional part number
-v, --verbose   Verbose mode, print potential part numbers
I2C>
sniff
sniff -h
usage:
sniff [-q] [-7] [-r]
Start the I2C sniffer: sniff
Supress (quiet) ACK in output: sniff -q
Print (raw) data, no '[',']','R''W': sniff -r
Show 7-bit address: sniff -7
pico-i2c-sniff by @jjsch-dev https://github.com/jjsch-dev/pico_i2c_sniffer
Max speed: 500kHz
I2C sniffer
-q, --quiet     Quiet mode, don't show ACKs
-r, --raw       Raw, only show data
-7, --addr7     Use 7bit i2c addresses
I2C>
eeprom
eeprom -h
read, write and erase 24XX series I2C EEPROM chips
erase           Erase chip
-a, --address <i2caddr> I2C address (0x50 default)
I2C>
ddr5
ddr5 -h
usage:
ddr5 [probe|dump|write|read|verify|lock|unlock|crc]
	[-f <file>] [-b <block number>|<bytes>] [-s <start address>] [-h(elp)]
Probe DDR5 SPD: ddr5 probe
Show DDR5 SPD NVM contents: ddr5 dump
Show 32 bytes starting at address 0x50: ddr5 dump -s 0x50 -b 32
Write SPD NVM from file, verify: ddr5 write -f example.bin
Read SPD NVM to file, verify: ddr5 read -f example.bin
Verify against file: ddr5 verify -f example.bin
Show NVM block lock status: ddr5 lock -or- ddr5 unlock
Lock a NVM block 0-15: ddr5 lock -b 0
Unlock a NVM block 0-15: ddr5 unlock -b 0
Check/generate CRC for JEDEC blocks 0-7: ddr5 crc -f example.bin
Patch/update CRC in file: ddr5 patch -f example.bin
DDR5 write file **MUST** be exactly 1024 bytes long
read, write and probe DDR5 SPD chips
probe           Show DDR5 SPD chip and NVM/EEPROM status
dump            Display DDR5 SPD NVM contents
read            Read DDR5 SPD NVM to a file
write           Write file to DDR5 SPD NVM
verify          Verify DDR5 SPD NVM against file
lock            Lock DDR5 SPD NVM block (64 bytes per block)
unlock          Unlock DDR5 SPD NVM block
crc             Calculate/verify CRC of JEDEC blocks 0-7 in a file
patch           Update correct CRC values for blocks 0-7 in a file
-f, --file <file> File flag. Specify a file to write, read, verify or check CRC
-b, --block <block> Block flag. Specify a DDR5 SPD NVM block to lock or unlock (0 - 15)
I2C>
ddr4
ddr4 -h
usage:
ddr4 [probe|dump|write|read|verify|lock|unlock|crc]
Probe DDR4 SPD: ddr4 probe
Show DDR4 SPD contents: ddr4 dump
Show 32 bytes starting at address 0x50: ddr4 dump -s 0x50 -b 32
Write SPD from file, verify: ddr4 write -f example.bin
Read SPD to file, verify: ddr4 read -f example.bin
Verify against file: ddr4 verify -f example.bin
Show block lock status: ddr4 lock -or- ddr4 unlock
Lock a block 0-3: ddr4 lock -b 0
Unlock all blocks 0-3: ddr4 unlock
Check/generate CRC for JEDEC bytes 0-125: ddr4 crc -f example.bin
Patch/update CRC in file: ddr4 patch -f example.bin
DDR4 write file **MUST** be exactly 512 bytes long
read, write and probe DDR4 SPD chips
probe           Show DDR4 SPD info
dump            Display DDR4 SPD contents
read            Read DDR4 SPD to a file
write           Write file to DDR4 SPD
verify          Verify DDR4 SPD against file
lock            Lock DDR4 SPD block (128 bytes per block)
unlock          Unlock all DDR4 SPD blocks
crc             Calculate/verify CRC of JEDEC bytes 0-125 in a file
patch           Update correct CRC values for bytes 0-125 in a file
-b, --block <block> Block flag. Specify a DDR4 SPD NVM block to lock (0 - 3)
I2C>
sht3x
sht3x -h
SHT30/31/35 Temperature and Humidity Sensor Demo
usage:
sht3x [-h(elp)]
- read SHT3x series temperature and humidity sensors
- 2.15-5 volt device, pull-up resistors required
Read SHT3x: sht3x
Read temperature and humidity from SHT3x sensors
I2C>
sht4x
sht4x -h
SHT40/41/43/45 Temperature and Humidity Sensor Demo
usage:
sht4x [-h(elp)]
- read SHT4x series temperature and humidity sensors
- 1.08-3.3 volt device, pull-up resistors required
Read SHT4x: sht4x
Read temperature and humidity from SHT4x sensors
I2C>
si7021
OFF	SDA	SCL	-	-	-	-	-	-	GND	si7021 -h
usage:
si7021 [-h(elp)]
- 3.3volt device, pull-up resistors required
Show temperature and humidity: si7021
Read temperature and humidity from SI7021/HTU21/SHT21 sensor
I2C>
ms5611
ms5611 -h
usage:
ms5611 [-h(elp)]
Show temperature and pressure: ms5611
Read temperature and pressure from MS5611 sensor
I2C>
tsl2561
tsl2561 -h
usage:
tsl2561 [-h(elp)]
Show LUX: tsl2561
Read light intensity (LUX) from TSL2561 sensor
I2C>
tcs3472
tcs3472 -h
usage:
tcs3472 [-g <gain:1,4,16*,60x>] [-i <integration cycles:1-256*>] [-h(elp)]
- read tcs3472x color sensor, show colors in terminal and on Bus Pirate LEDs
Read with default* 16x gain, 256 integration cycles: tcs3472
Read with 60x gain, 10 integration cycles: tcs3472 -g 60 -i 10
read color sensor data from TCS3472x sensor
-g, --gain <1,4,16*,60> Set TCS34725 gain (1x, 4x, 16x, 60x)
-i, --integration <1-256*> Set TCS34725 integration time (2.4ms to 700ms)
I2C>
fusb302
fusb302 -h
usage:
show chip ID and status info: fusb302 status
scan and select PDO profiles: fusb302 scan
interface with FUSB302 USB-C Power Delivery controller
status          read ID and status registers
scan            scan and select PDO profiles
I2C>
i2c
i2c -h
usage:
i2c [dump|read]
	[-a <7 bit i2c address>] [-w <register width>] [-r <register address>] [-b <bytes>] [-f <file>] [-h(elp)]
Dump 16 bytes from device: i2c dump -a 0x50 -w 1 -r 0x00 -b 16
Read 256 bytes to file: i2c read -a 0x50 -w 1 -r 0x00 -b 256 -f example.bin
Dump device with 2 byte wide register: i2c dump -a 0x50 -w 2 -r 0x0000 -b 64
Dump device with 3 bytes wide register: i2c dump -a 0x50 -w 3 -r 0x000000 -b 64
Dump common I2C device registers
-a, --address <7-bit> 7-bit I2C device address (default 0x50)
-w, --regwidth <bytes> Address register width in bytes (1 - 4, default 1)
-r, --regaddr <addr> Starting register address (default 0x00)
-f, --file <file> Save dump to <file name>
I2C>
usbpd
usbpd -h
usage:
usbpd [status|request|reset]
	[-p <PDO index>] [-v <mV>] [-i <mA>] [-h(elp)]
show USB PD status: usbpd status
request a fixed voltage PDO profile: usbpd request -p 1
request a PPS/AVS voltage profile: usbpd request -p 2 -v 9000 -i 1500
send USB PD hard reset: usbpd reset
interface with USB-C Power Delivery controller AP33772S
status          Show USB PD profiles and status
request         Request a Power Delivery profile (PDO)
reset           Request a USB PD hard reset
-p, --pdo <index> Power Delivery profile index (1 - n)
-v, --voltage <mV> Voltage in mV for adjustable (PPS) PDO request
-i, --current <mA> Current in mA for PDO request (optional, default max)
I2C>
mpu6050
mpu6050 -h
usage:
mpu6050 read: mpu6050
interface with MPU-6050 6-axis IMU sensor
I2C>
eeprom
eeprom -h
Invalid command: eeprom. Type ? for help.
SPI>
sle4442
sle4442 -h
usage:
sle4442 [init|dump|unlock|write|erase|psc]
	[-a <address>] [-v <value>] [-p <current psc>] [-n <new psc>] [-f <dump file>] [-s <start address>] [-b <bytes>] [-h(elp)]
Initialize and probe: sle4442 init
Dump contents: sle4442 dump
Dump 32 bytes starting at address 0x50: sle4442 dump -s 0x50 -b 32
Dump contents to file: sle4442 dump -f dump.bin
Dump format: DATA[0:255],SECMEM[256:259],PRTMEM[260:263]Unlock card:z sle4442 unlock -p 0xffffff
Write a value: sle4442 write -a 0xff -v 0x55
Erase memory: sle4442 erase
Update PSC: sle4442 psc -p 0xffffff -n 0x000000
Write protection mem: sle4442 protect -v 0x000000
SLE4442 smart card interface
init            Initialize card with ISO7816-3 ATR. Default action
dump            Display main, security and protect memory
unlock          Unlock card with Programmable Security Code (PSC)
write           Write data to card (requires unlock)
erase           Erase data from range 0x32-0x255 (requires unlock)
psc             Change Programmable Security Code (PSC)
protect         Write 32 bit protection memory (requires unlock)
-a, --address <address> Write address flag
-v, --value <value> Write value flag
-p, --current <psc> Current Programmable Security Code (PSC) flag
-n, --new <psc> New Programmable Security Code (PSC) flag
2WIRE>
sniff
sniff -h
usage:
sniff [-q]
Start the 2WIRE sniffer: sniff
Sniffs SLE4442 style 8bit I2C-like protocols (no NAK/ACK)
Based on pico-i2c-sniff by @jjsch-dev https://github.com/jjsch-dev/pico_i2c_sniffer
Max speed: 500kHz
I2C sniffer
2WIRE>
tvbgone
tvbgone -h
usage:
tvbgone
Turn off TVs: tvbgone
Based on TV B Gone by Mitch Altman and a 2009 kit version by Limor Fried
TV-B-Gone, turn off many brands of TV
INFRARED-(RAW)>
irtx
irtx -h
usage:
irtx [aIR packet] [-f <file>]
aIR format: $<modulation freq (kHz)>:<MARK1>,<SPACE1>,...<MARKn>,<SPACEn>,;
Transmit: irtx $38:900,1800,900,65535,;
Transmit from file: irtx -f example.air
Transmit IR signals (aIR format)
-f, --file <file> Transmit one or more aIR packets from a file
INFRARED-(RAW)>
irrx
irrx -h
usage:
irrx [-f <file>] [-s <sensor>]
Receive (interactive): irrx
Receive, save to file (interactive): irrx -f example.air
Receive, specify sensor (interactive): irrx -s 56D
Sensors: 38kHz barrier (38B), 36-40kHz/56kHz demodulator (38D*/56D)
*default
Receive, record, retransmit IR signals (aIR format)
-f, --file <file> Specify filename for saved signals
-s, --sensor <sensor> Specify sensor for received signals (38B/38D/56D)irtx -h
INFRARED-(RAW)>
bluetag
bluetag -h
usage:
bluetag [jtag|swd] [-c <channels>] [-v(ersion)] [-d(isable pulsing)]
blueTag interactive interface: bluetag
JTAG scan, 6 channels: bluetag jtag -c 6
SWD scan, 4 channels: bluetag swd -c 4
Show version: bluetag -v
Disable JTAG pin pulsing: bluetag jtag -c 6 -d
blueTag by @Aodrulez https://github.com/Aodrulez/blueTag
blueTAG options
jtag            Scan for JTAG pins
swd             Scan for SWD pins
-c, --channels <count> Number of channels to scan (starting from IO0)
-v, --version   Show version
-d, --disable   Disable pin pulsing (JTAG mode)
JTAG>
Today I worked on cleaning up the help and investigating some of the issue we found.
Completion and hinting (with tab to cycle/complete) is partly working. It should be good to go tomorrow.
//TO DO:
  • DDR4/DDR5/dummy.c/spi_eeprom/otpdump all impacted by a change in the parser. Need to rework the return value or args struct.
  • Not getting args parse errors when required values are missing Related to #1, not bailing on parser error detection
  • Python script to scan for dead translation entries - Done, but need to commit to breaking changes with the translation history.
  • Positional arguments are not well explained in the help - maybe they get their own parsing struct too?
    -~~ Predictive text seems to blow out cursors in simple mode - fixed somewhat, but still buggy~~
  • Predictive text needs some polish. Color, feel. Can it be tab to complete?
  • Look into the unified file parser - how used, where, change underlying parser used?
  • Look into HEX viewer core arguments parsers
  • Positional arguments get parsing own struct and help?
  • Mode command per-mode flags and parsing, using the exiting prompt definition structs in each mode.
  • Look into how the args parser is handing errors (shows message but lets underlying code continue without notice)
Big big big day today. It might actually be worth giving the experimental build a spin
  • Add positional arguments to structs for all commands
  • Reformat help
  • Check all help to standardize use of [optional] and <required>
  • [] and <\> for positional and flag options are now generated automatically in the help, as well as in the command line hinting. This will now be consistent system wide
  • linenoise simple mode for prompts seems definitively fixed
  • Linenoise hinting bug on <\>[\ ] fixed
Tomorrow I’m taking a side quest:
  • Add an optional struct to enable input validation via the args parser directly
  • Unify command line argument and prompt validation structures, perhaps parsing
This will give us instant, standardized input validation and error messages system wide.
I’m thrilled the command parsing is getting attention … it’s critical to getting stable scripting. Without AI doing a lot of the drudge work, I wonder when/if it would have happened, so I guess some good may come of AI after all. :wink:
I’m still sidelined by time (and energy) constraints, but … bravo!
Woah, that was some side quest!
  • Completely new prompt pipeline reuses the arguments parsing stuff
  • Unified error checking/bound checked and reporting in prompt and command line argument parsing
  • W command updated to new prompts as prototype
  • UART mode updated to new system, now can be configured directly from the command line.
  • Fixed the arg missing return type bug impacting ddr5/ddr4/otpdump/dummy. ddr4/5 & dummy updated and tested. optdump to be done later.
  • So much more, it is a LOT
There is a experimental compile of my work from today. BEWARE: lots of little formatting bugs in prompts and error messages (too many new lines, not enough new lines) will get ironed out when the dust settles.
I’m going to continue refractoring the m command because it is a weird corner case for hinting and also needs all of these (and we need a way to do m uart -h to get individual mode help).
Now would be a great time to take the experimental firmware for a test drive. The past two days have focused on refactoring everything to the new args/prompt/help/validation API, as well as documenting the new API.
Almost everything “menu prompt, command line, help” has been refactored, but there’s very little real world testing of the complete migration. The only thing still relying on the old system is the c config menu because it’s a bit funky.
//TODO:
  • Document entire bp_cmd with usage examples
//Completed:
  • c configuration command not really ported, but enough to integrate the new help system
  • Regex remove dead help strings from commands.c struct.
  • PWM and Pullups need attention: done but check
  • DDR4/DDR5/dummy.c/spi_eeprom/otpdump all impacted by a change in the parser: fixed, but verify each implementation
  • Check dead code in ui_cmdln, ui_prompt.
  • Check remaining ui_prompt_float
  • Unify Y/N/exit in bp_cmd
