That looks like a hard one. The data sheets I find say it’s a proprietary 16bit microcontroller so there’d be no way to know what it does without ripping the code and knowing how to disassemble it for that chip.
The JVC DTV series of CRT broadcast monitors is highly sought after by us in the retro gaming community as they output a very high quality and accurate analog display signal.
This IC is the cause of a lot of issues in this monitor as outlined in the service manual. I have one dead monitor that requires a replacement, and know several people in the community with the same issue.
The purpose of doing this is to provide the community with either a replacement part for their broken monitors, or write a guide on how to flash a replacement chip.
I’m reading more on the subject and just learned this chip uses the I2C protocol for communication. Since it’s proprietary, does this mean the data would be protected and cannot be dumped?
Thanks again
Edit: Please excuse my noob questions. Does the process require more than dumping and flashing to a new chip?
The key is to find some documentation on how to read and write the chip, then if nothing is protected it is a simple matter to copy to a new chip. But that is only once you know how to actually read it.
Do you know if the chip is using I2C components, or is itself programmed with I2C?
if it is simply setting some I2C devices to eg tune channels, then you may be able to use a different chip for that. The key would be using a logic analyzer to capture the I2C bus during power up and tuning/volume actions, then send the same commands and see if it works without the chip.
This is entirely conjecture though. Finding datasheets for antique components can be challenging.
Some user on reddit was kind enough to look into it and they suggested a DIY parallel programmer can be used to read/write to it.
Or they suggested the below programmer which was originally used to program these chips in circuit.
I’m still reading more on the topic and trying to figure out if this is something within my capabilities. Otherwise I’ll have to find someone experienced who I can send the board to. Good thing about the monitor is the board where the chip sits in is nice and tiny.
Tbh… As the majority of things are analogue, you might find that it’s only job is to run the i2c bus to control other chips.
The bus Pirate could look at the i2c bus to see what’s being sent.
Try reading the signals a few times to see what changes… Does it have digital controls? That might be it’s function…
If it is, then it should be a simple task to replicate those functions.
If it uses the adc then it might be a bit harder, but I’d guess it just adjusts a few i2c pots… It would be the simplest solution which most manufacturers take
