nRF52 ... PPIO, GPIOTE, and WS2812
I thought I’d just post a short series on a design created (but not selected) for controlling WS2812 style pixels, circa 2019, using the nRF52 series microcontroller. This post will be the TOC, linking to later posts.
Quick nRF52840 Highlights
nRF52840 TRM / datasheet
Full datasheet / TRM v.1.8 is latest from archive.org, or get latest directly from NordicSemi.
nRF52840 ... The Good
The chip had solid support, both in Arduino
and VSCode + PlatformIO,
as well as a solid set of features:
  • 64 MHz Cortex-M4 with FPU
  • 1 MB Flash, 256 KB RAM
  • 2.4 GHz Transceiver
  • 2 Mbps, 1 Mbps, Long Range
  • Bluetooth 5, Bluetooth mesh
  • ANT, 802.15.4, Thread, Zigbee
  • +8 dBm TX Power
  • 128-bit AES CCM, ARM CryptoCell
  • UART, SPI, TWI, PDM, I2S, QSPI
  • PWM
  • 12-bit ADC
  • NFC-A
  • USB 2.0
nRF52 ... The Ugly
Bluetooth support linked an opaque, closed-source blob called
SoftDevice into the firmware. This also changed various NVIC
parameters, such that the Bluetooth-related interrupts had higher
priority than anything in your own firmware, and so that supported
APIs for disabling interrupts would never disable the SoftDevice
interrupts.
As you may have noticed, the nRF52 is a single-core chip.
As a result, when the SoftDevice was enabled, and a BT packet
arrived, the SoftDevice interrupt handler would fire and
consume the processor for ~225μs (up to ~406μs).
Sending data to clockless protocol pixels (such as the WS2812)
can fail with deviations as small as 50ns. Even a 1μs interruption
is 20x that limit, so a SoftDevice interrupt that typically
took 225μs required a CPU-free method to support clockless protocols.
Example BLE Interrupt Timing and Overhead
This was pulled from the SoftDevice v1.40 specifications.
Usage / Pattern Max Typ Freq
BLE Advertising 348,000ns 229,000ns 40,000ns
BLE Connection 406,000ns 219,000ns 183,000ns
BLE Scanner / Initiator 273,000ns 175,000ns ???,000ns
Note: Freq is the minimum time between such interrupts occurring.
These timings only cover softdevice processing that occurs at
interrupt priority levels 0 and 1 … the CPU overhead at interrupt priority
level 4 (deferred BLE processing) can substantially increase
these values further.
Interesting nRF52 Peripherals
PPI
The nRF52 (and likely other Nordic chips) have a flexible, programmable
interconnect (PPI), which allows creating a channel from a
chosen peripheral’s EVENT. Each channel can trigger up to two
TASKs on other peripheral … and the peripherals may be distinct from each other.
The PPI runs on a 16MHz (62.5ns) clock, allowing predictable,
consistent, real-time setting of TASKs in response to any
given EVENT, from nearly any peripheral.
The configured channels can also be part of one or more
channel groups. This simplifies the simultaneous enabling
or disabling of multiple channels.
GPIOTE
There is a peripheral whose sole purpose seems to be to translate
GPIO edges into EVENTs, and support TASKs for setting, clearing,
and toggling the GPIO state.
There are of course some limitations:
  • GPIOTE could not be configured on a pin used by another peripheral,
    even in a read-only / snooping mode. Thus, for example, a pin
    configured as part of the SPI peripheral could not also directly
    generate GPIOTE events.
  • Each GPIOTE could be configured for at most one of the following
    events: RISE, FALL, or CHG (rising edge, falling edge, or
    either edge).
WS2818 uses NRZ protocol
As you likely know, clockless pixels such as the WS2812
use a Non-Return-to-Zero (NRZ) transmission protocol,
sometimes referred to a pulse-width encoding.
In essence, the time from the rising edge to the falling
edge defines if the bit is a one or a zero. A minimum
time with no edges defines the end of data transmission,
typically orders of magnitude larger than the time to
transfer a single bit.
For WS2812:
  • the GPIO idles low
  • a shorter pulse is a 0 bit
  • a longer pulse is a 1 bit
  • total time per bit can be the same (longer low period for 0, shorter low period for 1).
  • reset time is orders of magnitude longer (e.g., 50us (50k ns))
This is sometimes referred to in shorthand as:
  • T1 == time from starting edge to when 0 bit drops low
  • T2 == time from T1 to when 1 bit drops low
  • T3 == min time from T2 to when next bit starts
For example, with T1/T2/T3 of 320/320/640 nanoseconds,
transmission of a 0 bit would be a pulse that is high
for 320ns, and then low for at least 960ns, while a
transmission of a 1 bit would be a pulse that is high
for 640ns, and then low for at least 640ns.
An over-engineered solution. This solution was not selected, but is interesting in its combination of PPI, GPIOTE, and SPIS peripherals.
Conceptually, the solution is only somewhat complex
Everything is synchronized to the 16MHz clock from GPIOTE.
  • PPI channels cause TASKs to occur in response to EVENTs.
  • GPIOTE peripherals configured for an input pin generate
    events on changes in the value.
  • GPIOTE peripherals configured for an output pin allow
    events to change the output pin state.
  • SPIS peripheral is used to serialize the data stream to a GPIO, in order to enable/disable groups of PPI channels.
A COUNTER peripheral is for two things:
  1. detect when the last data bit has been transmitted (LAST_BIT)
  2. detect when the required post-data delay has finished (END_OF_DELAY)
An interrupt on LAST_BIT can be used to reclaim the data buffer, allowing preparation of the next transfer at the earliest possible time.
Slightly more detail
The SPIS peripheral reacts to the /CS line falling by loading
the first bit of output to the configured MISO GPIO. It reacts to the CLK line falling by loading the next bit of the data to transmit.
A TIMER peripheral is used to generate events:
  • T1 → (only when current data bit is 0): sets output low
  • T1+T2 → ensures output low, and increments counter
  • T1+T2+T3 → , SCLK rise, and SCLK fall.
  • SCLK1 → sets GPIOs for SPIS clock and for data output high
  • SCLK0 → sets GPIO for SPIS clock low
The interesting chain is the response to the SCLK0 event:
  • PPI links SCLK0 to GPIOTE(SPIS CLK).SetLow
  • SPIS peripheral sets MISO to next data bit
  • PPI links GPIOTE(MISO).Rising to Disable of PPI channel group ‘x’
  • PPI links GPIOTE(MISO).Falling to Enable of PPI channel group x
Channel group x is a single PPI, which responds to the T1 timer event, and sets the output bit low for the shorter pulse output. Since T1+T2 event always ensures the bit is low, ensuring this one event corresponds to the next data bit pushed from SPIS ensures the pulse length on the data output also corresponds to that SPIS-pushed next data bit.
Externally bridged connections
Of course, the above hand-waves a necessary evil: To control peripheral’s input GPIO (e.g., SPIS’s SCLK), a second GPIO is externally bridged. A GPIOTE task can then set / clear / toggle that second GPIO.
Similarly, to respond to changes peripheral’s output GPIO(e.g., SPIS’s MISO), a second GPIO is externally bridged. The GPIOTE peripheral can then cause events based on the peripheral’s changes to its output pin.
Full details are in later post(s).
Continuing the over-engineered solution…
General configuration notes
In essence, everything is gated to 16MHz / 62.5ns clock.
  • The PPI system is gated to 16MHz aka 62.5ns (nRF52840 specific)
  • The TIMER max clock rate is 16MHz (nRF52840 specific)
  • Must use either TIMER3 or TIMER4, due to # of CMP registers (nRF52840 specific)
  • To ensure synchronization, the SPIS peripheral is used,
    with the clock externally bridged from a TIMER peripheral.
  • At the start of a transfer, two steps are manually taken:
    • SPIS /CS is manually held low for at least 1000ns (1us),
      ensuring the first bit is loaded and ready on SPIS MISO.
    • Based on whether the first bit to transfer is a zero or one,
      either PPI Channel Group X will initially be configured
      as enabled or disabled, prior to starting the data transfer.
Peripherals Used
  • SPIS is used to transmit, one bit at a time, an array of bytes of data.
  • GPIOTE are used to:
    • generate SPIS clock
    • detect SPIS output changes, and enable/disable a channel group CHGx
    • control final output timing
  • TIMER, with period set to match the total transmission time for a single bit
    • CMP0 D0 === T1; when the output pin should fall, to output a zero bit (e.g., 250ns for WS2812); also increments counter
    • CMP1 D1 === T1+T2, when output pin should fall, to output a one bit (e.g., 1000ns for WS2812)
    • CMP2 SCLK=0 == when SCLK should go low
    • CMP3 SCLK=1 == when SCLK should go high
  • A COUNTER is used with two comparators:
    • CNT1 last bit to indicate the last bit has been transmitted, which also
      disables CHGy, to prevent the output from being set high again.
    • CNT0 delay to indicate the post-data delay has finished, and disables
      CHGz to disable ALL the PPI channels used in this process.
    • Interrupt for CNT1 event indicates that the data buffer can be reclaimed.
    • Interrupt for CNT0 event indicates transmission is fully completed.
GPIO Configuration
Pin Name I or O Comment
SPIS_CLK input As configured in SPIS peripheral registers
SPIS_MISO output As configured in SPIS peripheral registers
SPIS_CSN input IFalling edge causes SPIS to prepares the first output bit
GPIOTE_CLK output Externally bridged to SPIS_CLK, controlled via GPIOTE TASK
GPIOTE_MISO_RISE input Externally bridged to SPIS_MISO, GPIOTE event on rising signal
GPIOTE_MISO_FALL input Externally bridged to SPIS_MISO, GPIOTE event on rising signal
GPIOTE_OUTPUT output Final output of WS2812 data signal
PPI Channel and Group configuration
Channel group X CHGx is defined to allow a PPI task to enable/disable
the single channel that causes a shorter pulse; changes based on rising
and falling edge of SPIS MISO.
Channel group Y CHGy is used disable the only event that sets output
high, easily enabling the mandatory idle time at the end of the data.
Channel group Z CHGz is defined to simplify enabling all the events
at the start, and disabling all the events after the final bit is transferred.
CHG PPI EVENT TASK Comment
.yz 1 CMP3(SCLK=1) GPIOTE_OUTPUT.TASKS_SET Sets output pin high, when CHGy enabled
^^^^^^^^^^^^ GPIOTE_CLK.TASKS_SET Sets the SPI clock high
..z 2 CMP2(SCLK=0) GPIOTE_CLK.TASKS_CLEAR Set the SPI clock low (loads next data bit)
..z 3 CMP1(D1) COUNTERx.TASKS_COUNT Increments count of total bits transmitted
..z ^^^^^^^^^^^^ GPIOTE_OUTPUT.TASKS_CLEAR Ensures output pin set low at longer of two bit lengths
x.z 4 CMP0(D0) GPIOTE_OUTPUT.TASKS_CLEAR Timer sets output pin low, but only when CHGx enabled (data bit was zero)
..z 5 GPIOTE_MISO_RISE PPI.TASKS_CHG.DIS Disables CHGx when data bit is one
..z 6 GPIOTE_MISO_FALL PPI.TASKS_CHG.EN Enables CHGx when data bit is zero
..z 7 CNT1(last bit) PPI.TASKS_CHG[y].DIS Disables event that sets output high
..z 8 CNT0(delay) PPI.TASKS_CHG[z].DIS ENDS TRANSMISSION
WaveDROM timing diagram
I even generated a timing diagram, to ensure there were no
edge cases / race conditions. Load the following into the
WaveDrom editor at WaveDrom Editor.
    "Comments" : "Load into WaveDrom editor at https://wavedrom.com/editor.html",
    "signal" : [
        { "name":"", "node":"abc" },
        ["Clocks",
            { "name": "Clk_16MHz",        "wave": "p......................................|..........................|...." },
            { "name": "single bit",       "wave": "xx8...................8................|..8.....................xx|xxxx", "data": "OutputBit OutputBit OutputBit" },
            { "name": "250ns",            "wave": "1.1...1...1...1...1...1...1...1...1...1|..1...1...1...1...1...1...|...1" },
        ["SPIS Mode 1",
            { "name": "SPI_MISO (out)",   "wave": "3...........x4..................x9.|x5.|............x1............|....", "node": ".............I..........................................................", "data": " InputBit7  InputBit6  ... InputBitN" },
            { "name": "SPI_MOSI  (in)",   "wave": "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx|xxxxxxxxxxxxxxxxxxxxxxxxxx|xxxx", },
            { "name": "SPI_CSN   (in)",   "wave": "0......................................|..........................|....", },
            { "name": "SPI_CLK   (in)",   "wave": "0.1.........0.........1.........0......|..1.........0.........1...|....", "node": "..B.........H.............................P.........g..................."   },
        ["Timers",
            { "name": "PERIOD",           "wave": "1...................1..................|1...................1.....|...."},
            { "name": "CMPx (SCLK=0)",    "wave": "0..........0...................0.......|...........0..............|....", "node": "...........G............................................................"   },
            { "name": "CMPx (SCLK=1)",    "wave": "00...................0.................|.0.......................0|....", "node": ".A.......................................N.............................."   },
            { "name": "CMPx (D0)",        "wave": "0....0...................0.............|.....0....................|....", "node": ".....E.......................................R.........................."   },
            { "name": "CMPx (D1)",        "wave": "0................0...................0.|...................0......|0...", "node": ".................K.........................................T.......a...."   },
        { "name": "OUTPUT",            "wave": "0.1...3...........0...1...4...........0|..1...5.............0...0.|....", "node": "..C...F...........L.......................Q...S.............U...........", "data": " InputBit7  InputBit6  InputBitN" },
        ["Counter",
            { "name": "COUNT EVENT",      "wave": "0.................0...................0|....................0.....|.0..", "node": "..................M.........................................V.......b..."   },
            { "name": "CNTx (delay)",     "wave": "0......................................|..........................|..0.", "node": ".....................................................................Y.."   },
            { "name": "CNTx (last bit)",  "wave": "0......................................|.....................0....|....", "node": ".............................................................W.........."   },
        ["PPI CHG EN/DIS",
            { "name": "PPI_CHG1_Enabled", "wave": "3...........xx4.................xx9|xx5|............xx1...........|....", "node": "..............J........................................................", "data": " InputBit7  InputBit6  ... InputBitN" },
            { "name": "PPI_CHG2_Enabled", "wave": "1..................................|...|.....................x0...|....", "node": ".............................................................X........."  },
            { "name": "PPI_CHG3_Enabled", "wave": "1..................................|...|..........................|...0", "node": "......................................................................Z"  },
    "edge": [
        "A-|>B  GPIOTE - set SCLK high",
        "A-|>C  GPIOTE - set output high",
        "E-|>F  GPIOTE - only when data bit is zero",
        "G-|>H  GPIOTE - set SCLK low",
        "H-|>I  SCLK triggers next bit of data",
        "I-|>J  GPIOTE - data triggers PPI CHG enable/disable",
        "K-|>L  GPIOTE - ensures output low",
        "K-|>M  PPI - TASK increments counter",
        "N-|>P  GPIOTE - set SCLK high",
        "N-|>Q  GPIOTE - set output high",
        "R-|>S  GPIOTE - only when data bit is zero",
        "T-|>U  GPIOTE - ensures output low",
        "T-|>V  TASK increments counter",
        "V-|>W  LAST BIT",
        "W-|>X  PPI - disables the CHG that sets output high",
        "a-|>b  GPIOTE - ensures output low",
        "b-|>Y  END OF DELAY",
        "Y-|>Z  PPI - disable all CHG",
WaveDROM timing diagram (PNG)
For those curious, the final solution used DMA, with a RAM-inefficient encoding of the data to be transferred (48 bytes per pixel instead of 3 bytes per pixel!!!)
Sine the nRF52840 has 256k of RAM, this was a “good enough” solution, and much, much simpler … only used a single PWM peripheral to DMA the data.
FIN
What a journey!
WS2812s are such a pain. I would absolutely have added a $1 RP2040 and used PIO :wink:
I agree whole-heartedly. This work was done circa 2019, or about two years before the RP2040 shipped, so … :person_shrugging: I’ll note that in the first post…
