New Pull Request: DRAFT: Binmode dude readfix
mbrugman67/BusPirate5-firmware → DangerousPrototypes/BusPirate5-firmware
DO NOT MERGE UNTIL FURTHER TESTING
This PR fixes the issue with legacy binmode with AVRdude preventing reads on parts with flash > 64Kbytes.
The AVR command to read flash uses a 16-byte address pointer; for parts greater than 64K flash, there is a separate ISP command for AVR_LOAD_ADDRESS_EXTENDED_HIGH_BYTE_COMMAND. There could be issues on older AVR parts with <= 64Kbytes of flash generating errors if they receive this command.
To manage this, it’s necessary to know flash memory size before starting read flash memory operations. We’ll use the part’s signature to determine flash size. AVR parts have a 3-byte signature:
- byte 0 - always 0x1e
- byte 1 - flash size
- byte 2 - specific part within the flash size family
One of the first things that happens with AVRdude is that the part is commanded to go into ISP program mode, then the signature is read. This PR adds some hacky code to watch for that and set a flag if signature byte 1 indicates this part has > 64Kbytes.
Here is a table of signatures and parts supported by AVRdude:
| Signature | Flash size | Parts | Extended High Byte Required? |
| 0x1e 0x8f 0x– | 512 bytes | ATtiny4/5 | No |
| 0x1e 0x90 0x– | 1 Kbyte | ATtiny9/1*, AT90S1200 | No |
| 0x1e 0x91 0x– | 2 Kbyte | ATtiny2, AT90S23 | No |
| 0x1e 0x92 0x– | 4 Kbyte | ATtiny4, ATmega4, AT90S4* | No |
| 0x1e 0x93 0x– | 8 Kbyte | ATtiny8, ATmega8, ATxmega8, AT90S8 | No |
| 0x1e 0x94 0x– | 16 Kbyte | ATtiny16, ATmega16, ATxmega16* | No |
| 0x1e 0x95 0x– | 32 Kbyte | ATtiny32, ATmega32, ATxmega32, AVR32, AT90CAN32 | No |
| 0x1e 0x96 0x– | 48, 64 Kbyte | ATmega480, ATmega64, ATxmega64, AVR64, AT90CAN64, AT90USB64* | No |
| 0x1e 0x97 0x– | 128, 192 Kbyte | ATmega103, ATmega128, AVR128, ATxmega128, ATxmega192, AT90CAN128, AT90USB128 | Yes |
| 0x1e 0x98 0x– | 256, 384 Kbyte | ATmega256, ATxmega256, ATxmega384* | Yes |
| 0x1e 0xa6 0x– | 64 Kbyte | ATmega64RF* | No |
| 0x1e 0xa7 0x– | 128 Kbyte | ATmega128RF* | Yes |
| 0x1e 0xa8 0x– | 256 Kbyte | ATmega256RF* | Yes |
| 0x1e 0xc0 0x– | 512 Kbyte | AT32UC3A0512 | Yes |
Created by: mbrugman67
