Pull Request #279: [WIP] Generate remaining developer documentation for Bus Pirate firmware
New Pull Request: [WIP] Generate remaining developer documentation for Bus Pirate firmware
DangerousPrototypes/BusPirate5-firmware → DangerousPrototypes/BusPirate5-firmware
Thanks for asking me to work on this. I will get started on it and keep this PR’s description up to date as I form a plan and make progress.
Prompt: Generate Bus Pirate Developer Documentation
For Claude Opus 4.6 in VS Code with full workspace access.
Your Task
Generate the remaining markdown documentation pages described in docs/developer_docs_outline.md for the Bus Pirate 5/6/7 firmware. Two pages already exist and are approved — do NOT recreate them. Use them as your style template. Read source code from the workspace to extract real struct definitions, function signatures, code excerpts, and examples.
Already Complete — DO NOT Recreate
These two guides are finished, approved, and checked in. Do not modify or regenerate them. Use them only as style references:
  1. docs/new_command_guide.md — Step-by-step guide to implementing a new global or mode command. Uses code excerpts from src/commands/global/dummy.c. 10 numbered steps, tables for every struct/enum, checklist at the end, API quick reference section.
  2. docs/new_mode_guide.md — Step-by-step guide to implementing a new protocol mode. Uses code excerpts from src/mode/dummy1.c. 13 numbered steps, covers setup (dual-path interactive + CLI), syntax handlers, macros, periodic service, registration in modes.c, checklist at the end.
Style Rules (Match the Existing Guides)
Read both docs/new_command_guide.md and docs/new_mode_guide.md in full before writing anything. Then follow these conventions exactly:
  • Title: # Topic Name with a > One-line description blockquote beneath
  • Separator: --- between the overview and the first section
  • Section headers: ## Step N: Name for how-to guides, ## Section Name for reference pages
  • Code excerpts: Real code from the codebase in fenced ```c blocks, with contextual comments. Never invent fake code — read the actual source files.
  • Tables: Use tables for struct fields, enum values, function signatures, and comparisons. Every struct/type gets a field table.
  • Key points: Bold for emphasis, code backticks for identifiers, italics sparingly
  • Cross-references: Relative markdown links: [other_doc.md](other_doc.md), source file references as inline code
  • Checklist: End how-to guides with a ## Checklist section using - [ ] items
  • Related Documentation: End every page with a ## Related Documentation section linking to relevant sibling docs and source files
  • No migration content: The outline includes migration material from bp_cmd_developer_docs_outline.md. Skip all of §10 (Migration Guide) and §11 (What’s NOT Replaced). These are internal working documents, not developer docs.
  • Concise: These are reference docs for working developers, not tutorials. Be direct. Every sentence should teach something.
Source Material
You have three source documents to work from. Read them all before starting:
  1. docs/developer_docs_outline.md — The master outline defining all pages, their sections, and bullet points. This is your table of contents. Follow the section structure.
  2. docs/bp_cmd_developer_docs_outline.md — Detailed outline for the bp_cmd framework (§3 in the master outline). Contains type descriptions, API signatures, pattern descriptions, and architectural notes. Use the non-migration sections (§1–9, §12) as source material for the bp_cmd reference pages.
  3. The codebase itself — Read the actual source files to extract real struct definitions, function signatures, code excerpts, and usage examples. Key files:
    • src/lib/bp_args/bp_cmd.h — All bp_cmd types and function declarations
    • src/lib/bp_args/bp_cmd.c — Implementation (parsing, validation, prompting, help)
    • src/lib/bp_args/bp_cmd_linenoise.c — Hint/completion callbacks
    • src/commands.c — Global command registration (commands[] array, _global_command_struct)
    • src/command_struct.h — _global_command_struct, _mode_command_struct, command_result, cmd_category
    • src/modes.c — Mode registration (modes[] array)
    • src/pirate.h — Master config, platform selection, BP_HW_* flags, mode enable defines
    • src/system_config.h — system_config struct
    • src/syntax.h, src/syntax_struct.h, src/syntax_internal.h — Syntax pipeline
    • src/bytecode.h — struct _bytecode, opcodes, error codes
    • src/pirate/bio.h — BIO pin functions
    • src/pirate/storage.h — Storage API, mode_config_t
    • src/usb_rx.h, src/usb_tx.h — USB communication
    • src/spsc_queue.h — Lock-free inter-core queue
    • src/binmode/binmode.h — Binary mode struct and dispatch
    • src/displays.h — Display mode struct
    • src/translation/base.h — T_ enum
    • src/translation/en-us.c — English string table + language-adding guide
    • src/system_monitor.h — System monitor
    • src/pirate/amux.h — Analog multiplexer
    • src/boards/ — Board and platform headers
    • CMakeLists.txt, src/CMakeLists.txt — Build system
    • docker/ — Docker build environment
    • tests/ — Test infrastructure
    • Reference implementations: src/commands/global/dummy.c, src/mode/dummy1.c, src/mode/hwuart.c, src/commands/global/w_psu.c, src/commands/spi/flash.c, src/binmode/binsump.c, src/binmode/binio.c
Pages to Generate
Generate each page as a separate markdown file in docs/. Follow the priority order below. For each page, read the relevant source files first, then write the doc with real code excerpts.
Tier 1 — Generate These First
File: docs/bp_cmd_data_types.md
  • Source: bp_cmd_developer_docs_outline.md §3, plus src/lib/bp_args/bp_cmd.h
  • Read bp_cmd.h and extract the actual struct definitions for: bp_command_def_t, bp_command_opt_t, bp_command_positional_t, bp_val_constraint_t, bp_val_choice_t, bp_command_action_t, bp_action_delegate_t, bp_cmd_status_t, bp_arg_type_t
  • For each type: show the real struct definition in a code block, then a field table explaining each field
  • Include the sentinel convention ({ 0 } termination for opts and positionals arrays)
  • Include lifetime rules (always static const or file-scope const if extern)
  • Show real usage examples from dummy.c, dummy1.c, hwuart.c, flash.c, ui_mode.c
File: docs/bp_cmd_parsing_api.md
  • Source: bp_cmd_developer_docs_outline.md §4 + §6, plus src/lib/bp_args/bp_cmd.h
  • Read bp_cmd.h for the actual function declarations
  • Cover: action resolution, simple flag queries, simple positional queries, remainder access, constraint-aware resolution
  • Include the help system here (§6): bp_cmd_help_check(), bp_cmd_help_show()
  • Show real examples from dummy.c, w_psu.c, flash.c
  • End with a complete function signature table (like the one in new_command_guide.md “Parsing API Quick Reference”)
File: docs/translation_guide.md
  • Source: outline §4.4, plus src/translation/base.h, src/translation/en-us.c, check_translations.py
  • Read en-us.c header comments for the 7-step language-adding guide
  • Read base.h for the T_ enum structure
  • Read check_translations.py for the toolchain
  • Cover: how T_ constants work, GET_T(), adding a new string, adding a new language, the 0 placeholder convention for development, the json2h.py pipeline
File: docs/syntax_bytecode_guide.md
  • Source: outline §4.1, plus src/syntax.h, src/syntax_struct.h, src/syntax_internal.h, src/bytecode.h, src/syntax_compile.c, src/syntax_run.c, src/syntax_post.c
  • Read bytecode.h for the actual struct _bytecode definition and opcodes
  • Read syntax_struct.h for struct _syntax_io
  • Emphasize the critical rule: no printf() during execute phase
  • Show how modes plug in via function pointers (cross-ref new_mode_guide.md Step 7)
  • Include opcode table, error code table, result struct field table
Tier 2 — Generate These Next
File: docs/build_system_guide.md
  • Source: outline §1.1, plus CMakeLists.txt, src/CMakeLists.txt, docker/Dockerfile, docker-compose.yml
  • Read both CMakeLists.txt files for actual target definitions, PIO compilation commands, platform selection logic
  • Cover: how to build, platform selection, adding a new target, PIO pipeline, Docker environment
File: docs/bio_pin_guide.md
  • Source: outline §4.2, plus src/pirate/bio.h, src/pirate/bio.c, src/system_config.h
  • Read bio.h for actual function declarations and the bp_bio_pins enum
  • Read a platform header (e.g. src/boards/bp5_rev10.h) for bio2bufiopin[] mappings
  • Show the pin claiming pattern from dummy1.c setup_exc/cleanup
  • Cross-ref new_mode_guide.md Step 5
File: docs/storage_guide.md
  • Source: outline §4.3, plus src/pirate/storage.h
  • Read storage.h for actual API: storage_save_mode(), storage_load_mode(), mode_config_t
  • Show the complete storage descriptor pattern from dummy1.c Step 4a
  • Cover: config file naming, FatFS operations, global system config
  • Cross-ref new_mode_guide.md Step 4
File: docs/binary_mode_guide.md
  • Source: outline §2.3, plus src/binmode/binmode.h, src/binmode/binmode.c, src/binmode/binsump.c, src/binmode/binio.c
  • Read binmode.h for the binmode_t struct definition
  • Read binsump.c as a clean example implementation
  • Style: step-by-step like new_command_guide.md and new_mode_guide.md
  • Include checklist at the end
Tier 3 — Generate These Last
File: docs/board_abstraction_guide.md
  • Source: outline §1.2, plus src/pirate.h, board/platform headers in src/boards/
  • Read pirate.h for the BP_VER/BP_REV cascade and BP_HW_* flags
  • Read one platform header (e.g. bp5_rev10.h) and its matching board header as examples
  • Cover: what to create when adding a new hardware revision
File: docs/dual_core_guide.md
  • Source: outline §1.3, plus src/spsc_queue.h, src/usb_rx.h, src/usb_tx.h
  • Read spsc_queue.h — it’s well-commented, extract the API and design rationale
  • Cover: Core 0 vs Core 1 responsibilities, SPSC queue API, memory barrier usage
  • Describe the data flow: USB ↔ Core 1 ↔ SPSC queues ↔ Core 0 ↔ protocol engine
File: docs/bp_cmd_prompting.md
  • Source: bp_cmd_developer_docs_outline.md §5, plus src/lib/bp_args/bp_cmd.c (the bp_cmd_prompt function)
  • Show the dual-path pattern with real examples from hwuart.c and w_psu.c
  • Cover: BP_VAL_UINT32 prompts, BP_VAL_CHOICE prompts, saved config integration
File: docs/bp_cmd_linenoise.md
  • Source: bp_cmd_developer_docs_outline.md §7, plus src/lib/bp_args/bp_cmd_linenoise.c
  • Read the actual callback implementations
  • Cover: hint generation, tab completion, sub-definition awareness, collect_defs()
File: docs/bp_cmd_patterns.md
  • Source: bp_cmd_developer_docs_outline.md §9
  • For each pattern: name it, cite the example file, show a minimal code excerpt from that file
  • Read the actual source files: monitor.c, w_psu.c, flash.c, ui_mode.c, hwuart.c, freq.c, pwm.c
  • This should be a quick-reference “cookbook” page
File: docs/usb_communication_guide.md
  • Source: outline §4.5, plus src/usb_rx.h, src/usb_tx.h, src/spsc_queue.h, src/tusb_config.h
  • Cover: TinyUSB interfaces, SPSC queues, RX/TX APIs, binary mode data path, debug paths
File: docs/display_mode_guide.md (short page)
  • Source: outline §2.4, plus src/displays.h, src/displays.c
  • Read the _display struct and displays[] table
  • Show how to add a new display mode
File: docs/system_config_reference.md (reference page)
  • Source: outline §6.1, plus src/system_config.h
  • Read the actual system_config struct and document each field
  • Cover: when to read vs write, the .error flag for command chaining, .mode, .psu
File: docs/error_handling_reference.md (short reference page)
  • Source: outline §6.3
  • Cover: system_config.error, SERR_* codes, FRESULT, conventions
File: docs/testing_guide.md
  • Source: outline §5.1, plus tests/test_spsc_queue.c, tests/run_tests.sh, tests/hardware/, tests/pico/
  • Read the test file for the framework pattern
  • Cover: SDK mocking, building tests, extending to other subsystems
File: docs/system_monitor_guide.md (short page)
  • Source: outline §4.6, plus src/system_monitor.h, src/system_monitor.c, src/pirate/amux.h
  • Cover: voltage/current monitoring, AMUX, PSU control
Methodology
For each page:
  1. Read the outline section for that page to know what to cover
  2. Read the source files listed — extract real struct definitions, real function signatures, real code excerpts
  3. Read the approved guides (new_command_guide.md, new_mode_guide.md) if you haven’t already to match style
  4. Write the page following the style rules above
  5. Cross-reference: link to sibling docs and source files in the Related Documentation section
  6. Never invent code — every code block should come from an actual source file in the workspace
Work through the tiers in order. After each page, verify it follows the style rules before moving to the next.
File Naming Convention
All files go in docs/. Use lowercase with underscores:
What NOT to Do
  • Do NOT recreate new_command_guide.md or new_mode_guide.md
  • Do NOT include migration material (old API → new API tables, migration checklists)
  • Do NOT invent fake code examples — always read the real source
  • Do NOT write long prose paragraphs — use tables, code blocks, and bullet points
  • Do NOT duplicate content between pages — cross-reference instead
  • Do NOT modify any source code files — this is a documentation-only task
:speech_balloon: We’d love your input! Share your thoughts on Copilot coding agent in our 2 minute survey.
Created by: Copilot
This markdown will be used in hugo docs. Please add the header to each file:
weight = 90401
title = ‘’
Increment the weight so the pages are in order, add a title for each.
Added Hugo front matter to all 19 docs in 4d09bf7. Weights run 90401–90419 with titles matching each page heading. Order: bp_cmd types → parsing API → prompting → linenoise → patterns → syntax/bytecode → translation → build system → board abstraction → dual-core → BIO pins → storage → USB → system_config → system monitor → error handling → binary mode → display mode → testing.
Comment by: Copilot
