So my soldering looks good but it still indicates 5V with latest firmware even I set it to 3.3V. I think I might fry this part and one pin seems missing.
I thought bigger blob of solder will fix it but it didnt. I will try to replace it and fix again with new bridge
Is this part ok? I found it locally. Texas Instruments is doing good parts.
Right?
The fix looks good. Does the bridge wire also measure 5volts with a multimeter? Once the op-amp has feedback it should be ok.
The part is 5 pin sot-23, so that middle position should be empty.
MCP6001 is the part I actually prototyped with, but it will not work. The pinout is different.
The TI part links to a voltage regulator for me, but TI does make LMV321s. Basically any LMV321 in SOT-23 size should probably fit, it uses a “classic” op-amp pinout.
I can also mail you one from a donor board, and of course I’ll send a new board when I’m able in a few weeks.
That little resistor just above the opamp looks like it could use a hit of solder on the right hand side. Maybe it was disturbed during the repair? I’d try that first.
The part you linked is correct type, but the smaller sot 323 size. This is the correct part I believe:
Let me know how it goes with the resistor. If that is unsoldered, then you would see the same exact thing as without the bridge on the op-amp (op-amp stuck high).
I got the BP5 today. It’s great! Really nicely packaged too.
Regarding the mods, I removed the old MOSFET with a blob of solder and moving the iron above the part until the blob was able to heat all sides enough for it to just slide away. And then replaced with a larger SOT-23 Si2301 since I already had that.
After updating my BP5 to latest firmware, confirmed that I had the stuck 5V reading. Connected the pins with a bit of a through-hole LED leg bent to shape, now seeing the correct voltage on the LCD and UI.
No I was wrong I destroyed the pad underneat. The solder doesnt stick there anymore. Damn it. Is there other place on the board I could scratch a bit of mask and connect there? Or the hope is lost already?
Yeah now I know. I consulted the schematics and its clear that it isnt connected anywhere underneat the board so new opamp and wire will fix it. Hopefully
The FET part was much harder for me.
I cut the trace between the via and the drain and bridged the unconnected drain pad to the nearby trace. After this, i sealed the origin source pad and put a jumper wire from the via to the source of the FET.
