Would it be possible to add a startup script that includes commands to execute on each power on?
Lets say for example currently I use the the bus pirate to generate a pwm frequency a lot, so I would place the corresponding commands in a script and everytime I apply power to the bp the script is executed and is configured for my pwm output.
I would still have to execute the script manually. Unless I put the script in an udev script or similar. Also the udev configuration would be needed on all computers.
I’m doing something similar for the button, and we have the basic scripting functionality. I think this can be done. It would be super useful for me as a dev doing repetitive debugging.
However, there’s two/three blocking bugs with stack overflows and some other ugliness in the fat file system that need to be solved first. We got a handle on the source last week and there are fixes pending. When that is tested and implemented it will be possible to add a startup script.
