Hi there, theres any plan to add support to SWIM protocol for ST devices? thanks
Thanks for stopping by
I assume it is doable, what features are you looking for?
I had a quick look and it doesn’t seem there is an existing open source implementation to build off of, like there are for the CH32V chips.
If we target the ST’s debug/program tool chain, I assume it is more complicated than a simple serial port. So maybe imitating the original programmer’s USB IDs and USB interface? That gets a bit hairy.
If there is an open/alternative program software (maybe debug with GD or something?) then it is a lot easier.
If you’re just after program/erase/dump, that might be a lot easier to implement using the internal storage for the firmware files.
Well, i think i want all the features ![]()
Just program/erase/dump is ok and a god starting point. Combined with the programmable PSU it’s gonna be amazing to make dumps, and debug some failures in ST Micros that a cheap link isn’t able to do. Thanks
