thread started Flashing bootloader on nRF52840 with BP6 - #24 by petaflot
after a number of tries, it mounted in a few seconds as expected. I copied bus_pirate6.uf2 on it, nothing happend after a while, so I did
gentx ~ # sync
gentx ~ # umount /mnt/usb/
unplug, wait a few secs, replug
gentx ~ # mount /dev/sde1 /mnt/usb/
gentx ~ # ls !$
ls /mnt/usb/
BPCONFIG.BP bus_pirate6.uf2
I then notice dmesg reports FAT-fs (sde1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. (which as you can see from the above, is not correct)
gentx ~ # fsck /dev/sde1
fsck de util-linux 2.41
fsck.fat 4.2 (2021-01-31)
There is no label in boot sector, but there is volume label 'BUS_PIRATE5' stored in root directory
1) Copy volume label from root directory to boot sector
2) Remove volume label from root directory
[12?q]? q
No changes have been written to the filesystem yet. If you choose
to quit, it will be left in the same state it was in before you
started this program.
