We’ve been using a little metalized plastic button on the Bus Pirate prototypes, but the button also comes in a plain “rice white” version. We sent a couple bags to the ABS dye factory to be color matched with some classic arcade game buttons.
I think the result is excellent! The best dye job yet.
The “final” Bus Pirate will come with six button caps you can choose from to fit your mood: chrome, black, yellow, red, blue and a hydro foil dip dyed button.
Caps are primed, pushed through printed PVA foil floating in water, and sealed for durability. Dip dye is typically used to customize helmets, car parts, and sneakers.
Button caps are small, so we used the finest carbon fiber print available. We only test dipped one bag of caps, so there may be different patterns in the future.
Some suppliers can custom print foils, which is something I’d like to try just to see how it turns out.
