FIX YOUR SIX (Bus Pirate 5XL/6 resistor fix)
I Fixed My Six!
Took a bit longer than I wanted. I used Caption tape to help keep the temps down on neighboring components and a hot air station with a soldering iron to help get the components off, used lead based solder to help clean up the pads with wire braid, and finally used solder paste dot method with the hot air to put the new ones in. Sprinkled on a little cleanup with wire braid and then some IPA. Here are the pics:
RN302
RN307
Terminal Output
