Linux script to connect to Bus Pirate
I wrote a simple script that connects to the Bus Pirate.
The usage is
BusPirate [-n] [terminal] [baud]
Currently it uses screen to connect but you can change it to putty or tio or whatever. (I use tio)
It does the following:
  1. It remounts the BP file system as read-only - to prevent problems. You might have to tweak this. On my system it’s /dev/sda1
  2. It looks for either /media/$USER/BUS_PIRATE5 or /media/$USER/RPI-RP2. If the second, it reminds you to reconnect your BP. If it doesn’t see the BP file system, it won’t connect. You can override this behavior with the -n option.
  3. You can specify a difference serial port (and baud) as an option.
    BusPirate.txt (1.6 KB)
I made a slight change - the new version only remounts the disk if the disk is there.
Here’s my updated script to connect to the BusPirate.
It has several changes.
If the BusPirate is in boot mode, it will check if it can find the proper *.uf2 file to install. (It detects if this is a BP5 or BP6, and selects the proper file). It looks in the current directory, or if the BPFW environment variable is set, use that instead.
If the file exists, it will ask if you want it installed.
If not, it will remind you that you can’t connect to the BP while it is in boot mode.
I also made it easier to customize the script, selecting the terminal emulator of choice. There’s also tweaks when you can use BP5XL or BP5 rev 8 firmware.
In Summary - you execute the command and either connect to the BP, or install the software to the BP. Or it reminds you to plug in the BP :slight_smile: - We’ve all been there.
BusPirate.txt (2.9 KB)
May I make a suggestion. You should consider having the script setup a folder structure and have a tool for first time users can also utilize to get up and running in no time.
I’m not sure what you mean. The only real “setup” is selecting which terminal program you prefer - tio, minicom, screen, or ???
Are you suggesting that the first time it’s run, I ask them to pick one of these?
Or are you suggesting something else, like step-by-step instructions for installing the firmware?
Or even more basic - like how to install and use a terminal program?
As a long-time Unix user - I always look at the first few lines of any script before I run it, where the tweaks are described. That’s why this is described in the front of the script.
I like the auto firmware loading :slight_smile: That plus a script on the Bus Pirate button that jumps to bootloader makes for fast development without a debugger.
Let me get some feedback to you in the next few days if its still relevant. Its been busy around here, but ill be back to catch up asap.
No Problem.
I was thinking of adding a test for a “profile” file. It it exists, use those defaults. If not, have it call a script called “BusPirate-setup”
and that file would ask for the profile:
  • Preferred terminal connection program
  • BusPirate model (5XL vs 6), BP5rev10 vs BP5rev8)
  • Location for firmware *.uf2 files.
It could even check if the terminal program is installed, etc.
This script would likely evolve over time. Having a separate script also keeps the main script smaller and simpler, eliminating frequent updates.
I suppose it could test if a BP is connected, and even download released firmware and install it for first time users.
I could of course make it one big complex script with frequent updates (and bugs). Comments?
I created a PR (if I did it right) that adds two Linux scripts to the hacks subdirectory.
BusPirateSetup.sh
BusPirate.sh
The first one generates a config file that lets you specify your BP variants, your download directory, and your terminal emulation program (i.e. screen, tio, minicom, putty).
The second script looks at the mounted file system, and either (1) connects via the terminal emulator, (2) installs new firmware, or (3) reminds you to plug in your BP. It prevents your from loading the wrong RP2040/RP2350 firmware by mistake.
BusPirateSetup.txt (3.0 KB)
BusPirate.txt (5.5 KB)
Let me know if you have any problems.
Reviewed, and every time I thought I found a bug, you’d already handled it (e.g., ensuring the directory exists before copying / creating a file in it). Merged.
I added this to the Linux setup page of the updated docs, thank you so much!
I just updated it with (a) better documentation, (b) The setup will backup the old config file, and (C) you can now specify alternate config files (i.e. If you want to use a different terminal emulator).
Nice!
Are you going to submit a pull request?
Is there anything you’d like to add to the Linux tab here, about your script or anything linux related? I didn’t flesh it out much, but I wanted people to be aware of the resources. You can drop any changes here and I will add them to the docs :slight_smile:
I think I did a pull request. The main thing about the two Linux scripts:
BusPirateSetup - This should be used once to set up your choice of terminal emulator, device type (especially if you have a BusPirate5XL, or 5 -beta), and directory where you store/build firmware (i.e. ~/Downloads ).
BusPirate - used to connect to your BusPirate. It verifies that it is plugged in. If the BP is in boot mode, it looks for the proper firmware and will install it for you. It makes it simpler (i.e. less error prone) to connect and/or install firmware for your BP. You don’t need different commands to perform different actions.
