I keep losing my connection to the serial port on my MacBook Pro i9 2019. Once that happens I can’t reconnect, and eventually the device disappears (and also the drive disappears with the usual popup scolding me for not unmounting it first.)
Sometimes it happens right away, sometimes it works for a while.
HiZ> cu: Got hangup signal
Sometimes I am able to reconnect but I receive no output and it eventually hangs up again. When it’s hung like that, pressing the One Button sometimes makes it produce a little bit of output and immediately hang up.
It seems like it started after I upgraded from ci-buspirate5-main-6f1e888.zip (April 13 2024 )to ci-buspirate5-main-a5d0e8a.zip (May 12 2024). (And now running a debug build on b1e8b90 that still has the problem.)
I haven’t used OpenOCD before, but I had been wanting to mess with it for some other projects anyway. (And I also wanted to debug the issue where I can’t connect after my Mac sleeps.)
I follow the instructions at OpenOCD/RPi Debug Probe Setup
I don’t have the debug probe, so I put it on a regular Pi Pico. I used the milled pins I ordered with the BP (and some female jumper cables I had laying around that I got from Adafruit a while back) to connect to the debug probe on the back.
I see some references in the code to a serial debug console but I haven’t figure out how to connect to that yet.
For whatever reason, I thought OpenOCD was a little bit more magical and it would send me errors or something. Seems like for the most part, it’s just a way to connect gdb.
Which is still pretty awesome, but I quickly remembered that I need to ask gdb the right questions to get useful answers. So I started reading through the code. And then I ran out of time.
I read through the code a little bit more before work this morning. I saw some references to IRQs, so one thing I’ll check tonight is that the IRQ doesn’t get stuck disabled somehow.
Any other tips for what to check would be helpful.
I did pull down the code and configured / built with
cmake -S . -B build -DPICO_SDK_FETCH_FROM_GIT=TRUE -DCMAKE_BUILD_TYPE=Debug
cmake --build ./build --target bus_pirate5_rev10
(I also setup VsCode for cmake. I might try to clean up my config and contribute that back.)
Also, I tried to get more logs from the Mac side. I was able to get logs using the Mac built-in Console utility. Does anyone know of a better way to do that? It crashed at least once, and it’s a bit of a firehose. (Or maybe I don’t know how to use it correctly).
I haven’t finished going through those logs yet, but one relevant piece is:
error 16:33:37.748986-0500 kernel AppleUSBIORequest: AppleUSBIORequest::complete: device 29 (Bus Pirate 5@14300000) endpoint 0x05: status 0xe0005000 (pipe stalled): 0 bytes transferred
error 16:33:37.749803-0500 kernel AppleUSBIORequest: AppleUSBIORequest::complete: device 29 (Bus Pirate 5@14300000) endpoint 0x05: status 0xe0005000 (pipe stalled): 0 bytes transferred
error 16:33:37.750632-0500 kernel AppleUSBIORequest: AppleUSBIORequest::complete: device 29 (Bus Pirate 5@14300000) endpoint 0x05: status 0xe0005000 (pipe stalled): 0 bytes transferred
