OpenOCD/RPi Debug Probe Setup
I’m trying to help with the BP debugging. I hooked up a RPi Debug Probe to the 3-hole on the bottom. I’m following the directions the RPi site
Here are some tips
  • Use the right plug on the RPi Debug Probe - the one that says JTAG - See picture
  • Starting from the, edge,the color of the wires are Red, Yellow, Black (SWCLK, SWDIO,GND)
  • Plugging in the male connectors from the probe didn’t seem to fit well. I cut a female header down to 3 wires and used that in-between.
  • I had gdb installed. I also installed the multi-archtecture version using "
    sudo apt install gdb-multiarch
  • I installed openocd from github but the standard package might work
  • I started openocd using "
    sudo openocd -f interface/cmsis-dap.cfg -f target/rp2040.cfg -c "adapter speed 5000"
  • instead of using “cmake …” I used
    "cmake -DCMAKE_BUILD_TYPE=Debug ..
  • I copied the new firmware onto the BP
  • I started the debugger using
$ gdb-multiarch bus_pirate5_rev10.elf
target remote localhost:3333
monitor reset init
continue
Let’s see how this goes
Great contribution, thanks for sharing.
How do you like the debug probe? I got one, but haven’t figured out an adapter for the pins yet to fit my BP5. I have 3P milled pins that I solder to a little PCB breakout I use for debugging with a PICO.
The DuPont crimps on their cable are probably the cheapest stuff I’ve ever seen. My jaw dropped a little.
TBH, this is the first time I used it. For the adapter, I used a piece of female header. It worked.
PXL_20240409_131252097
But I also had some milled male headers, and made an adapter as well
PXL_20240409_125638914
The second one is where I plan to end up :slight_smile:
Really appreciate this post!
Once this is setup for cmd-line connection…
gdb-multiarch bus_pirate5_rev10.elf      \
    --ex "target remote localhost:3333"  \
    --ex "monitor reset init"            \
    --ex "continue"
I’m getting closer. I can get VSCode to build, upload, and appear to be debugging by adding the following contents as file ./.vscode/launch.json:
	"version": "0.2.0",
	"configurations": [
			"name": "BP5_Rev10",
			"type": "cppdbg",
			"request": "launch",
			"cwd": "${workspaceFolder}",
			"program": "${workspaceRoot}/build/bus_pirate5_rev10.elf",
			"MIMode": "gdb",
			"miDebuggerPath": "gdb-multiarch",
			"miDebuggerServerAddress": "localhost:3333",
			"useExtendedRemote": false,
			"postRemoteConnectCommands": [
                //{"text": "target remote localhost:3333"},
				{"text": "monitor reset init"},
				{"text": "load"}
The first time I run this, setting breakpoints in VSCode does not appear to do anything. I can break in after the fact, but … that’s not much use when I want to trace what’s happening within a function.
Except for the first time (even after restarting openOCD), attempts to debug just complains with:
ERROR: Unable to start debugging. Unexpected GDB output from command "-exec-run". During startup program exited with code 126.
The program './bp5/build/bus_pirate5_rev10.elf' has exited with code 0 (0x00000000).
Anyone else using this type of setup? If so, any ideas why the breakpoints are not being set?
Just a guess, is the PICO probe firmware up to date? They made some changes at one point and when I upgraded the VSCODE side I had to update the probe firmware too.
At the moment I have a zombie setup where I have to manually change stuff in the config because the vscode pico extension kind of messed up my whole toolchain.
Yes, it’s v2.0.1 (the latest release).
I’ve also been using the wrong term… I’m using the official debugprobe hardware (not a pico setup as a debug probe), because the debugprobe kit was the cheapest way (at the time) to get the RP2040 debug cables. :laughing:
Bummer. Still going to try to find a way to get this working.
OpenOCD server is working, and cmd-line I can break in, but doesn’t seem to have initial breakpoints working.
If I can’t figure this out, my ability to put together the more complex improvements will be severely impaired.
