I’m trying to use a bus pirate 5 I bought a while back as a SPI flash programmer. I seem to be failing at the first hurdle because when I turn on Vout I’m told that I have an external voltage connected
SPI> W 3.3
Current limit:Disabled
Power supply:Enabled
Error: Vout > on-board power supply. Backflow prevention activated
Is an external voltage connected to Vout/Vref pin?
I saw the post about the batch 1 issues REV10 batch 1 errors, fixes, replacements I’m not sure if I have one of those or not and I’m not sure if that impacts using Vout
Bus Pirate 5 REV10
Firmware main branch (2024-08-05T11:03:16Z)
S/N: 32250A0B33CC62E4
https://BusPirate.com/
Configuration file: Loaded
Available modes: HiZ 1-WIRE UART HDUART I2C SPI 2WIRE DIO LED
Active mode: spi (baudrate, clock polarity, clock phase, cs)=(61kHz, 1, 1, 2)
Display format: Auto
Pull-up resistors: OFF
Power supply: OFF
Frequency generators: OFF
I have no idea if the serial numbers are ascending in order. FWIW, the serial number of mine (Bus Pirate 5 Preview Version, assembled PCB only, ordered Oct 25, 2023, for $27.85) is 32104F0B33CC62E4
Do you have a record when you ordered your BP? The introductory price of the was purposely kept low.
I think it is highly likely that is from the first batch and needs a hardware fix. There’s some examples around of how to fix it.
The only absolutely necessary step is to short two pins on U506 (?), which is pretty do-able for a short term fix.
Please open a support ticket and we will send a replacement. China just started the National holiday though, so you probably won’t get a reply until next week.
