This was fueled by a user’s request to generate a 12MHz square wave output…
At 12MHz, the only most one reliable option would be a PIO program. I’ve dug into the PIO assembly and byte code in the past … so it got me thinking.
Could the buspirate allow dynamically adjusting and loading a (restricted) PIO program to control the plank outputs?
Overly-long details
The PIO byte code is surprisingly easy to parse. However, it would need to be restricted to a subset of instructions (at least initially), or else it’d easily mess up operation of the device.
Initial version restrictions
Restrict GPIO access in the incoming program to between 0…7
Restrict features (at least initially) to exclude…
- IRQs
- side-set other than pins 0…7
- write to a pin other than 0…7
- read to a pin other than 0…7
- etc.
Generally Permitted Interaction:
- Delay / side-set - all variations OK (Must map within GPIO 0…7)
JMP- address must be within program boundsWAITsourceof0b00– Allowed (abs. GPIO)sourceof0b01– Allowed (rel. GPIO)sourceof0b10– REJECTED (PIO IRQ, clears IRQ)sourceof0b11– Allowed (JMP PIN)
IN- All variations permitted except reserved sources0b100,0b101OUTdestinationof0b000(PINS) - ? see 11.5.6destinationof0b001(X) - Alloweddestinationof0b010(Y) - Alloweddestinationof0b011(NULL) - Alloweddestinationof0b100(PINDIRS) - ? see 11.5.6destinationof0b101(PC) - REJECTEDdestinationof0b110(ISR) - Alloweddestinationof0b111(EXEC) - REJECTED
PUSH- All variations permitted (verify all fixed bits)PULL- All variations permitted (verify all fixed bits)MOV to RX- All variations permitted (verify all fixed bits)MOV from RX- All variations permitted (verify all fixed bits)MOV Dest/Src
*destinationof0b000(PINS) - ? see 11.5.6
*destinationof0b001(X) - Allowed
*destinationof0b010(Y) - Allowed
*destinationof0b011(PINDIRS) - REJECTED
*destinationof0b100(EXEC) - Allowed
*destinationof0b101(PC) - REJECTED
*destinationof0b110(ISR) - Allowed
*destinationof0b111(OSR) - Allowed
*operation- All non-reserved variations OK
*sourceof0b000(PINS) - Allowed?
*sourceof0b001(X) - Allowed
*sourceof0b010(Y) - Allowed
*sourceof0b011(NULL) - Allowed
*sourceof0b100(reserved) - REJECTED
*sourceof0b101(Status) - Allowed
*sourceof0b110(ISR) - Allowed
*sourceof0b111(OSR) - AllowedIRQ- REJECTEDSET- Destination, Datadestinationof0b000(PINS) - ? see 11.5.6destinationof0b001(X) - Alloweddestinationof0b010(Y) - Alloweddestinationof0b011(reserved) - REJECTEDdestinationof0b100(PINDIRS) - ? see 11.5.6destinationof0b101(reserved) - REJECTEDdestinationof0b110(reserved) - REJECTEDdestinationof0b111(reserved) - REJECTED
WARNING! This presumes the eight plank outputs are contiguously numbered GPIO.
OUT/SET/SIDE-SET restrictions
To allow OUT, SET, and SIDE-SET, the following restrictions will ensure the PIO only affects the eight plank output pins:
OUT–PINCTRL_OUT_COUNTwill default to8(range 8…1), andPINCTRL_OUT_BASEwill default to the GPIO for plank pin0. (range +0…7). IfPINCTRL_OUT_BASEis increased,PINCTRL_OUT_COUNTwill be decreased accordingly.SET–PINCTRL_SET_COUNTwill default to8(range 8…1) andPINCTRL_SET_BASEwill default to the GPIO for plank pin0(range +0…7). IfPINCTRL_SET_BASEis increased,PINCTRL_SET_COUNTwill be decreased accordingly.SIDE-SET–PINCTRL_SIDESET_COUNTwill default to0(range 0…5 / 0…4 if optional) andPINCTRL_SIDESET_BASEwill default to the GPIO for plank pin0(range +0…7).PINCTRL_SIDESET_COUNT+PINCTRL_SIDESET_BASEshall be enforced to fit within the GPIO used by the plank outputs.
Those hidden details would be sufficient to support a large subset of the PIO commands, certainly sufficient for simple programs such as a 12MHz clock output on some (or all) of the plank outputs…
Not in my short-term queue, but putting the details out early, as enabling a “safer” PIO for classroom experimentation might be of interest to some folks…?
